Question about Mitsubishi VS-50501 50" Rear Projection Television
Power interrup I have a similar problem with the power cutting out on my 12 year old Mitsubishi projection Model # VS-50501A. I first noticed it while playing video games. I stopped using it for that and it was ok for awhile (although white letters on the Tv started to blur with a reddish tint.) Yesterday my daughter played the Wii for two hours without trouble. After sitting for over three hours, the TV will not turn on. I unplugged it overnight and it still will not start. I have the TV apart and have blown out all the dust. Where would I find the board that has the liquid on it? If the part is available is it affordable to replace myself? Thank you.
  • qfd333 Aug 19, 2008
    Thank you,
    Kevin
  • 927 Answers
Good Day, qfd333;
To find suspected liquid the PCB's, remove the front speaker cover and the small board held on by 5-6 screws. Look at the first 3 to 5" on the PCB. Use bright light it's not always easy to see. If fluid is spotted remove the boards from the back of TV. Use small brush, like old tooth brush, and acetone. You can get acetone from hardware stores
Look for rusted wires or parts and replace as necessary.
Good Luck, big IRISH.
Posted on Aug 19, 2008
HOW DO I ADJUST THE COLOR ON MY MITSUBISHI VS-50501A WITHOUT THE ORIGINAL REMOTE
You can order the remote for your model through www.tvrepairworld.com they can get any remote for any television. and the remotes dont require any programing since theyre designed to operate a specific model number TV.
Jan 06, 2010 | Mitsubishi VS-50501 50" Rear Projection...
My Mitsubishi VS50501A Rear Projection TV turns on then off!
Hi name is Ernie, and i have a mitsubishi vs-50501a .... my problem is that the picture is out.. i got sound but no picture.. the problem started with the tv turning off after 15min. then i would turn it back on, 15min later it turned off again. So now it stays on but no picture.. let me know if i can fix it myself.. im mechanically incline.. thanks.
Sep 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Gradually lost picture; Mitsubishi VS-50501A
you need to buy a new lamp and replace the old one thats your only problem its about $200 for the lamp
Mar 27, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Model VS 50501A TV. Works fine for awhile then screen goes black
most likly its your lamp you just need to get a new one off the internet or you can bring it to a repair shop and they will be able to replace it for alittle bit more then the lamp itself will cost
Mar 14, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi projection Model # VS-50501A (Power cutout)
they are fairly similar to each other, did you get a error code from the led by pressing menu and input both in together and holding for 5 seconds?
Aug 19, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi vs-50501a rear projection tv
This is a high voltage problem that is going to be very costly.Sorry!
May 20, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Won't start
12 year old Mitshubishis usualy only need a dozen or so capacitors to get them running again but at 12 years old bet the CRTs are worn and the picture quality will be low, We have a saying in the TV repair business that might help you out, TV's age like cats, so you have a 12 year old cat what do you do?
Apr 02, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi big screen tv
The VS5043 shuts down for many reasons. The most common are power supply issues. Bad caps, open resistors, shorted regulators, and missing voltages will cause the set to shutdown.
In my notesI have a location of components known to cause your problem( R5A03,L5A00,D5A21,Q5A04,Q5A03,C5A19,L902,IC900.IC700) All the parts listed are available. As I stated above there are many reasons for shutdown such as a bad flyback transformer that may not be available anymore. However, this type of failure needs to be properly diagnosed by a qualified technician. Good luck!
Sep 23, 2007 | Mitsubishi VS-5043 50" Rear Projection...
MISTUBISHI VS-50501A - top 3/4 of screen displays ok, rest does not
Check the vertcle yoke pins for solder cracks. Check verticle output circuitry resistors and transistors. And also check for Coolant leaks from the CRTs this happens alot. Check capacitors for any signs of sweeling or heat as well.
Sep 15, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Televison & Video Logo
155 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
