Question about Pioneer Car Audio & Video
I have the wiring harness for the cd player hooked up to the harness for the car, i plug it in and turn on the car and the cd player wont turn on. my air conditioner wont work either. i have a 1996 pontiac bonneville and a pioneer deh-2000mp cd player.
  • aaron_moelle Aug 19, 2008
    went and checked the fuses, all seemed to be fine....even checked the on in back of the stereo....this problem has me bamboozled...all the colors match up except a brown mute coming out from the cd player has no mate going into the car
  • aaron_moelle Aug 21, 2008
    checked and there is no light green wire from the pioneer deck
You may have popped a fuse during the installation process. Have a look at the fuse box under the dash.
Posted on Aug 19, 2008
  • Just Dex Aug 20, 2008
    Some Pioneer decks have a light green wire which connects to the parking brakes - a safety design - if this wire is not connected the unit will not work.
I am tring to put a cd player on my 2004 pontiac but it wont work the sterio wont turn on so i ran a wire from the fuse box on the side of the dore and it turn on but it has no sound wat am i doung wrong
hook up all your wires to the harness and the cd player EXCEPT the ground take and run both wires to the firewall or something metal instead of hooking them up together
Aug 30, 2011 | 2004 Pontiac Grand Am
I wont the speakers hooked to the cd player no the amp
check were the speakers are installed for pre existing wiring they probly left it there.. if not then you will have to run speaker wire from your stereo wiring harness to your speakers. if the speakers were hooked up to the amp then the wire in the harness should be vacant and you can use it if all the wires are connected then that means that you just have to find were that wire leads and hook your speakers up to it.
Jun 03, 2010 | Pioneer DEH-P6400 CD Player
How to wire up a pioneer car cd player?
no matter what the car there is an aftermarket wire harness to hook it up, no wires to cut just plug it in.
contact this web site for help on selecting the correct adapter wiring harness for your car.
www.crutchfield.com
Sep 16, 2009 | Car Audio & Video
Wont play throught speakers only crakles everything hooked right maybe needs new wireing harness but everything works but sound
If everything is hooked up correctly, you may need to wire harness. It could be a bad capacitor in the audio outputs. Easy to try wire harness first. Sometimes turning off and back on again works.
Jul 08, 2009 | Pyle PLDVIN7 Car DVD Player
Trying to put a cd player in a 2002 sable ls
i think its factory fitted ?? so you might not have the wiring loom pre installed
Apr 02, 2009 | 2002 Mercury Sable
WIRING CHANGE FOR 2002 DODGE CARAVAN
Your best bet on that one is to go to a place that sells car audio systems or even some autoparts retailers have them,and get the proper adapter harness already made up. A few more dollars but, a whole lot less headaches.
Mar 06, 2009 | 2002 Dodge Caravan
CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32492d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock01.pdf Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32493d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock02.pdf
Let me know if you need more assistance =)
Feb 01, 2009 | Kenwood KDC-MP238 CD Player
I replaced the cd player in my accord, the one before worked when i took it out, the radio i put in works as well tested it with hot and ground wires and a speaker to every terminal before i hooked it up...
On many cars there is an exterior amp that the sound goes through before it is sent to the speakers. If the remote turn on wire isnt connected after you take your previous cd player out then the amp wont know when to turn on and therefore no sound will come from your speakers although your cd player is doing its job.
Jul 20, 2008 | 2004 Honda Accord
Wireing harness
you can buy the proper harness for any vehicle at most stereo shops or even some at WalMart, but you have to hook it to the one that plugs into the radio. The colors on each harness will be identical- just match them up.
Dec 06, 2007 | Xtreme Sound WMS303 CD Player
Car Audio & Video Logo
124 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
