Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Speed Control Unit test?
Does anyone know how to test the viability of the speed control unit? My mixer stopped turning on. The power cord appears to be fine (according to my voltmeter), and the motor/gears all appear to be in working order.
  • 3 more comments
  • pokenmeister Aug 19, 2008
    :) Allow me to mention that whatever the problem is, it's keeping the mixer from running.
  • pokenmeister Aug 21, 2008
    The switch is working properly.
    also working properly.
    Both spin properly. I think the problem is in the control board itself (one of the resistors burnt out, etc). When I posted earlier that the switch was working, I was referring to the switch that closes the circuit on the speed control plate, which does drop when the speed lever is moved to the 'on' position. I'm getting strange resistances, when I try and check them against the color code, but I'm not certain how they're wired (parallel vs. series), so I don't know what values I should expect.
  • 45 Answers
Take off the back cover. there should be 2 screws on top of a piece of metal, 1 on bottom. Start on turn. it should go about 1x a second. Turn the top scrws. Then go to 6. it should be 3x a second. Use the bottom screw to adjust that. When turn and 6 are corrrect, all other sppeeds are right. There might be something else in between the back cover and the 3 screw panel.
Posted on Aug 19, 2008
  • 2 more comments
  • ae_7fam Aug 21, 2008
    Is the switch (the speed control) working? Check that.
    How about the cables from the motor to the switch?
    So does the motor spin but not the planetary?
    That is the "spinning part"
  • ae_7fam Aug 28, 2008
    Ok. See what you can do.
My mixer stopped working. Nothing happened, just went to use it one day and it wouldn't turn on. What could the problem be?
The problem could be anywhere and it should be checked through by a competent person using test equipment.
There is a slightly higher chance the power cord has an internal break but other common problems are with the internal safety device, the speed control, the switch or the motor brush gear.
Nov 21, 2016 | Food Mixers
The unit will not power on. There is no noise when the the speed selector is in the on position. The electric socket works, the beater can be turned by hand, but the unit won't power on
This model as configured for NZ will not start unless you move the speed control from the off position to any one of the speeds. In other words it will not start if you turn it on at the wall when the speed control lever is already in any on position. You must start from the off position first. I have also seen one fail to operate because the power wires from the speed control to the motor had come slightly unplugged inside the housings.
Apr 09, 2016 | KitchenAid Professional Heavy Duty Series...
My KitchenAid KSM90 will not turn on at all.
First make sure that the mixer is plugged into a working outlet. Were there any symptoms the last time you used your mixer? Check the cord on the mixer for damage. If the cord shows any wear replace it immediately.
At any point in time have you removed the brushes or adjust the speed control plate? After checking the cord, remove the brushes from the mixer, check to see if they are pitted, if they are replace the brushes. Please pay extra attention when putting the brushes back in the mixer, there is a dog-eared side of the brush, match this up to the brush holder to make sure the brush is inserted correctly.
If the brushes are not the problem check the speed control plate. If you remove the end cover from the mixer you can gain direct access to the speed control plate. There are 3 screws on this plate, the top two are used to adjust the speed of the mixer, the bottom one spaces the on/off switch contact. Try adjust the bottom screw to see if the mixer will turn on, it is possible the on/off switch was out of place.
Try these first, if none of this works let me know and we can continue trouble shooting.
Here is a link to the cord for your mixer: http://www.mendingshed.com/mixercord2.html
Here is a link to the brushes: http://www.mendingshed.com/kitchenaidbrushes.html
Here is a link to the speed control plate: http://www.mendingshed.com/speedcontrol.html
And here is a link to the service manual for your mixer, it has more troubleshooting ideas on the last few pages: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Thank you,
Colleen
Customer Service
MendingShed.com
customerservice@mendingshed.com
800-339-9297
Apr 13, 2013 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer only runs at one speed
if it runs only at high speed it needs a new phase control board if the mixer is post 1978, if the mixer is pre 1978 then you will have to replace a capacitor on the end of the power cord inside the mixer. if the mixer only works on one speed that is not high speed then you need to adjust or replace the speed control plate on post 1978 mixers and the capacitor on pre 1978 machines. Hope that helps
Jan 30, 2013 | KitchenAid Food Mixers
Kitchenaid deluxe 5 edition stand mixer runs on speed 10 and after 30 sec stops I thought it was the speed control pannel then I order one online and change it but that work 2 times and i have the original...
In the Artisan mixers the problem can be caused by two different parts. First the speed control plate. When you remove the end cover from the mixer the first thing you see is the speed control plate. There are 3 screws on this, two at the top, one on the bottom. Try adjusting the top two screws, to adjust, turn in the control plate adjusting the screws an equal amount.
Also check to see if the control plate spring is unhooked. Remove end cover, and check control plate spring. If unhooked, attach to bottom of the control plate and squeeze the spring end.
It can also be caused by incorrect wiring, check the wiring, the last page of the service manual will be a wiring diagram for your mixer. Here is a link to the service manual. http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Last, if the control plate is properly adjusted, the control plate spring is hooked correctly and the wiring is correct you will need to replace the speed control phase board. With the line cord disconnected, pull the t-bar contacts to open and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run. If it operates at full speed, the phase control is defective and needs to be replaced.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 27, 2013 | KitchenAid KSM150PS Artisan Series Stand...
My kitchenaid mixer run on high at all times
If your mixer only runs on high speed there are 3 things that can cause that. The first thing to check will be the speed control plate, Remove the trim and end cover on the mixer, the first thing you should see is the speed control plate, this has 3 screws on it, try adjusting the top two screws 1/4 turn, this should slow the mixer down, do not over tighten. Also check to see if the control plate spring is unhooked. If the spring is unhooked, attach to bottom of the control plate, and squeeze the spring end.
If this does not fix your mixer, check the wiring of the mixer, you can locate a wiring diagram on the last page of the service manual.
If the speed control plate is adjusted correctly and all the wiring is correct it will be your speed control phase board. You can test the speed control phase board to see if it is shorted. With the line cord disconnected, pull the t-b ar contacts to open, and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run. If it operates at full speed, teh phase control board is defective and needs to be replaced.
Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
This will aid you in taking the mixer apart, troubleshooting and putting it back together, remember the wiring diagram is the very last page.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 07, 2013 | KitchenAid K5SS Mixer Speed Control Plate...
I have a vintage hobart kitchenaid k4-b mixer and the problem is with the speed level lever when you operate it sometimes it will turn off the mixer and you have to push it back to off and re select each...
Hello Mark,
The problem is at the back of the unit. The speed control (black thing that all of the wires attached) is not functioning properly it has to sets of contactors. You will have to take the back of and play with the contactors. Unplug the unit and adjust the contactors then plug in and try it. You may also want to purchase a new speed control.
The part costs 27.95, part # 1394070 and is located at http://www.repairclinic.com/Kitchenaid-Switch-Parts?z=100&gclid=CKSD5NriuKcCFUVqKgodIE2b_g
Jan 13, 2011 | KitchenAid 32685 Mixer
Mixer will not come on. is there a reset buton?
Most of the sets come with a reset trip /load trip which can be seen on the side or underside of the unit.
so please check your power cord to leadd to the unit .If there is none it wil go to the power switch or the speed control unit.
Check the switch trace power to the motor, if power comes in , the motor must be checked.
Sep 29, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Mixer only operates at high speed regardless of the speed setting
the triac solid-state component on the board for the motor speed control is shorted and you need a new control board, unless you can find an outsource replacement triac,most companies won't sell you parts because of liability issues on internal parts of the unit
Apr 02, 2010 | KitchenAid K45SS Classic Stand Mixer
The speed control doesn't work well
This problem could be due to a worn or broken speed governor. this part is located on the motor shaft of the unit and works by way of centrifugal force. This however when gone will usually make the mixers speed go up and down, not just one speed. The most likely cause of this problem is the main control board. if this has become faulty, it can make the mixer stop completely or in your case, run full speed when turn on. part number for the board is W10119326. this part can easily be changed by disconnecting all power and removing the back end cover. Once removed make note of the adjustment screws at the bottom of the board. As these are your motor speed adjustment screws, and can be very finely tuned. Once these and the spring has been removed. you can now replace the board. Hope this helps
Thanks
Nov 01, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
189 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
