Question about Cell Phones
How to replace the nokia N70 keypad. I was advised to also purchase the T6 Torx screwdriver (which I have, and I was wondering the best way to tackle this without damaging the phone. Thank you
  • 199 Answers
You don't need a screw or t6 just to replace your keypad, you only need your bear hands
here's a link
showing how to dismantle your n70 phone
Posted on Aug 20, 2008
My phone sony erissson c902 can't sent msg
things you'll need:
* Phillips-head screwdriver
* Torx T6 screwdriver
* Credit card
Hold down the phone's power button until it shuts off. Place the phone so the back side is facing upward. Remove the back cover and remove battery pack from its compartment inside the phone. Slide the SIM card out of its slot inside the battery compartment. Set it aside.2
Loosen all screws from the phone's back casing. Depending on your exact phone this will include either Phillips or Torx T6 screws. Remove the back casing to reveal the internal circuit board.
* 3
Remove all screws fastening the circuit board to the phone's casing. Unplug all ribbon cables from the visible side of the circuit board. Lift the circuit board out of the phone's front housing and unplug the the ribbon cables from the opposite side of the circuit board. This disconnects the keypad and LCD screen from the circuit board. Remove the board from the phone's casing completely.
* 4
Flip the phone over, and insert a guitar pick or credit card into the gap along the outside edge of the phone's front housing. Use the pick to pry the front housing from the phone to reveal the keypad and LCD screen. Remove the two to four screws fastening the keypad to the phone's frame. Lift the keypad out of the phone and set it aside.
* 5Use the guitar pick to gently pry the LCD screen out of the phone's frame. Set it aside.
Apr 23, 2011 | Sony Ericsson Cell Phones
How hard is it to change the housing on a k750i thats the chassis and the facias?
Sony Ericsson K750i LCD replacement (below)
If you require a new screen, phone cover and screwdrivers, they can be purchased here:
Tools required: plastic shim such as a guitar plectrum, Phillips screwdriver and T6 screwdriver
  • Remove the battery cover, battery and sim card. Unscrew the 2 x Philips and the 2 x T6 torx screws you see. Use the shim to skim around the edges of the back cover, whilst gently lifting the cover to prise and release the clips (as pictured below).
  • Below is how the phone will look once you have removed the front cover. Now remove the keypad
  • Next, remove the plate below the keypad and black plastic backing. Lever this part gently from the left side of the phone as pictured. You’ll see a connector on the right hand side of the phone (circled). Using a small flat screwdriver, unplug it and lift away the plate.
  • WARNING: There are 2 tiny brass-like clips on the black plastic backing plate (circled). DO NOT lose these! In fact, try not to even dislodge them from the plate.
  • To replace the LCD, remove the 2 x T6 torx screws from the top of the screen. Unplug the screen connector from the PCB (circled in yellow).
  • Then, easing it over the joystick, lift the screen free. Replace with the new screen. Reverse the procedure for disassembly and it's finished.
Nov 24, 2009 | Sony Ericsson K750i Cellular Phone
How to change full cover on nokia E71? step by step guide
Nokia E71 Housing Fascia Replacement Faceplate Cover, Restore your ... or alternatively use the corresponding tools to change it by yourself.) Package include: Full Housing Replacement Cover for Nokia E71
Full Housing Replacement Cover for Nokia E71 (Grey) * 1
Front Cover
Back Cover
Middle Cover
Accessories as the picture shows
Keypad *1
T6 Screwdriver and an opening tool
Aug 12, 2009 | Nokia 6085 Cellular Phone
My nokia 7270 its keypad is malfunctioning
open your unit using T6 screwdriver, check the keypad connector if it's properly connected to the keypad and also clean the unit.
Oct 26, 2008 | Nokia 7270
Broken screen
I have the same problem......I NEED HELP!
Jun 09, 2008 | Nokia 5300 Grey Cellular Phone
Broken screen
replace the lcd..
Apr 07, 2008 | Nokia 6288 Cellular Phone
Nokiya 1600
I didn't fully understand the question; however, I assume that you have a key pad that is cracked or makes creek noises when buttons are being pressed.
If this is NOT and accurate understanding of your question, you can stop reading now; however, If this is an accurate understanding of your situation, see "Change the cover" on page 11 in the User Guide. It's under the "1. Getting Started" section in the guide's table of contents. You can view the User Guide online for free at Nokia's website.
Once you have removed the front cover, you can remove, clean and/or replace the keypad as needed.
If you need further help with finding the user guide on Nokia's website, I'd be glad to help - just let me know.
Dec 22, 2007 | Nokia 1600 Cellular Phone
Hi .... The steps to replace a keypad:
1st , you will need a t6 Torx screwdriver
2nd you will needd a replacement keypad
Here we go , you now remove all the screws with a t6 torx screwdriver after that the front of your phone will ease off if you get something in the middle of it , after that you just switch keypads and ther u go !!
Oct 17, 2007 | Motorola Mobility L6 Cellular Phone
Well there are quite a few things here that might be faulty :
Your lcd screen
Your buttons
And your network connection ,
For your lcd screen i would look on ebay there about 15 pound , you will also need a t6 torx screwdriver ,
For your buttons you can just purchase a full housing case , You will also need a t6 torx screwdriver to perform this operation ,
For your network connection i would consider speaking to your network provider , hope ihelped :)
Oct 16, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Cell Phones Logo
52 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
