Question about GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo...
GE Profile compactor
Thanks, I had already taken the compactor apart before I read your response, and found pretty much what you guessed.
When I took the compactor apart, I found I could not budge the ram, but that I could spin the motor rotor (?) by hand. I spun it down a little, then put things back together, and the compactor operated correctly...for about three compaction cycles. After that, the motor just buzzed again, and the ram again refused to move. My sense is that your idea about the top sensor is correct, and the ram cycles too far up, gets 'stuck'somewhere past the sensor, and the ram can't engage to spin down to compact the garbage. My problem is that I couldn't identify the sensor when I had it apart, and don't know how to proceed now. Have any further suggestions?
Dan
  • 706 Answers
Here is an assembly drawing of your compactor.. Please note item # 102 ( direction switch) ..That may be affecting the perfomance of your motor or your motor may have a dead spot on the windings.. Here is a link to a website for parts that coincide with this drawing.. There isn't an awful lot to a compactor in terms of hardware so good luck.. Hope this helps..
Here's the link for parts... http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
Posted on Aug 20, 2008
  • 1 more comment
  • paulcynergy Dec 04, 2010
    I was having the same problem. When it was at the top and I hit the foot switch to start it, it would just buzz. I took off the top and found a pair of shut off switches that get hit by an l-shaped bar on the ram. I took off the back cover over the motor and saw a switch handle on this white round plastic, spring-loaded ring. That seems to be what switches the direction of the motor when the pressure builds. I found on mine, when it reached the top, the white ring was stopped in a place where the switch pushed on a place where it didn't have support. I could adjust this by bending the L shaped bar on the top of the ram to get it to stop a little earlier. The reason why turning the worm screw made it go again was because it moved the white plastic ring to a better position under the switch on the motor. If this isn't clear, you can email me at [email protected] and I'll try to explain. From this picture, it looks like part 103 that I bent up a little bit to get it to stop a little earlier.
  • colorado970 Apr 03, 2011
    I had the same problem - motor buzz, but no action. I took the back motor cover plate off and spent about 30 minutes observing how this thing works. On mine, there is a spring activated mechanism on the top shaft of the motor. When the cycle is over, the springs push a black nylon ring up to push up on the white direction switch. The hum happened when the black nylon ring got stuck on one side and it was cockeyed, not level as it should be. That caused the direction switch to be stuck between its up and down positions. I will order new parts, but for now, I sprayed the nylon ring and shaft with WD-40 and it is working for now.
  • Ric Holder Sep 20, 2013
    same problem here, but my compactor press is stuck half way (either on the way down or the way up) motor is humming. How do i get the
SOURCE:
Ge profile trash comapctor loud banging noice
You have something wrapped on the compactor screw assembly (The assembly is a threaded rod about 24 inches long and 3/4 inch in diameter. ). Most likely it is plastic bag or some other plastic. Pull the entire compactor out (remove the hold down screws first). Then look for the obstruction on the screw assembly, cut it off and try while not in the compactor hole to make sure it works.
Jun 18, 2014 | GE Profile GCG1580LSS 15" Built-In Trash...
I have a GE trash compactor I have to hold up the foot pedal for it to work. When I let it go the compactor stops. thank you
There is a spring that holds up the pedal. It is broken or has come apart. By the pedal in the up position it is a safety switch allowing the compactor to run. You may have to repair this or simply put a small block under the pedal of the unit to run.
I hope my suggestions helps and all the luck to you.
burdfrenzy
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Dec 23, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Compactor ram stuck partially down & door open 2 inches. How do I get the ram to go back up & get the door closed?
We just had this same problem. Your problem is most likely abroken plastic gear found at underneeath the bottom of the compactor. Pull out the compactor and turn it upside down. Remove the bottom panel and that is where we found the broken gear. We were able to retract the ram and open the drawer by manually turning the drive chain using an ajustable wrench. Clockwise is compact, counter clockwise is retract.
Feb 03, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Compactor continues to run when cycle is complete
the little white swiitch that the foot petal pushes is bad.
it may help if you push it in and let it snap back.
That was a temporay fix for me, but I ended up having to replace the part.
$63 online
took about 30 minutes to repair
Jan 23, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Trash Compactor Model GCG1500LOBB. the foot
I also found that after 2 years my GE Profile Trash Compactor (purchased in June '07), the pedal was hanging down on the left side. I searched the internet and called GE to no avail.
After a few attempts, I finally solved the problem by removing the screw on the left side and adding a metal "L" bracket, with the bottom of the L flush against the back of the front panel. That way, when you depress the pedal, the screw can't pop out of the metal it's attached to.
Dannys00
Dec 21, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Sure is... The motor drives a ram up and down to compact your trash... Like most drive systems.. it needs to find a refrence position near the top of the stroke.. that position is normally sensed by a switch.. so it is possible your motor is bad or.. it is also possible your top sense switch is bad too.. For $400.. the GE tech should come out and stomp on your trash until it is compressed.... In either case.. if you are handy.. you may be able to open the compactor up ( with power unplugged) and check the position of the ram.. if it is near the top.. you may be ableto reposition it down a little then try cycling it.. It may buzz if the motor is bad ( windings shot) or it may work OK.. if it does and the problem comes back after you cycle it.. there is a good chance the top sense switch is bad or the windings in th emotor bad too.. Hope that helps...
Aug 16, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo... Logo
1,765 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
geapptech
Audie Bogus
Audie Bogus
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
