Question about Gateway GT5220 PC Desktop
Computer won't turn on.
My mother's computer will not turn on. The power button has an orange light (like in standby mode) but nothing happens when you push it, move the mouse or tap the keyboard. The monitor is on but does not get a signal from the computer. I've checked all the connections and nothing has been unplugged. The only way to turn the computer off is with a switch on the back of the tower. It turns on with the power button in the front but the light stays orange and nothing appears on the monitor. It is a Gateway desktop, I do not know the model (sorry) and the operating system is WIndows ME.
  • 1 more comment
  • jeloroc Aug 19, 2008
    No I have not tried that. Thank you. I will visit my mother tomorrow and I will let you know how it went.
  • jeloroc Aug 22, 2008
    ok i thought i posted a response here 2 days ago but i dont see it...so here we go again!
    i tried your suggestion and it didn't work. with the case open though i could hear that the drive motor was working. also i made a mistake in my initial description, the computer can be turned off with the front power button.
    Thanks.
  • girthwoodman Nov 13, 2008
    arrgggg!!!!!!!! welp i have a similar problem,..my gf's pc,..when ya turn it on you can here things run,..but no keyboard,..mouse or monitor,..sOooo,..i took it apart cleaned it with air,..and changed the power supply,..it worked! then the next day it crapped out again,...so this time i flashed the bios(took the battery out and put it back in),..then it worked,..so i shut it off and ,..welp it crapped out again same thing,..so0 i changed the battery and it worked!then it crapped out again,.. then i REFORMATED and it worked!!! so i turned it off and back on a few times then in crapped out again this is driving me nuts allready!!!!so im beggining to think its ether the proccessor or the motherboard,...and she would leave this thing on for days and weeks at a time so im guessing its the motherboard,..but i dont wont to rip this thing apart and rebuild the whold dam thing!!!!! anyone have a fore sure answer out there?????
  • 3 Answers
Hello!
I have a Gateway 500GR and was experiencing all sorts of shut downs, no boots, fans run but no blue power button light and black monitor etc. Plugged in and unplugged this and that, it was driving me nuts! Finally this worked for me. Running Windows 7 Ultimate. Control Panel/Hardware and Sound/Change when the computer sleeps/Change advanced power settings. I set HDD turn off after to NEVER. Monitor turn off after to NEVER. I did this about 5 days ago and PC has been running flawlessly since! No more troubles whatsoever. I hope this helps someone else!! Good Luck!
Posted on Jun 11, 2012
  • Gateway Master
  • 3,051 Answers
Have u tried to unplug the power cord and open up the case aand unplug the power supply from the motherboard and then pressing the power button then plug the powersupply back into the motherboard and pluging in the computer and see what happens please keep me posted so i can help you more if needed ok best regards mike
Posted on Aug 19, 2008
  • 1 more comment
  • Michael Thomas
    Michael Thomas Aug 19, 2008
    ook thankyou regardcs mike
  • Michael Thomas
    Michael Thomas Aug 23, 2008
    hey just wanted to know the power supply is working right
  • Michael Thomas
    Michael Thomas Aug 29, 2008
    ok it looks like you are going to do a process of elimination ok first try to unplug the powercords from the harddrive and the cd rom and mark them and then try to boot and see if it will come up. also the power supply is working right
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
Poweredge SC 1420 won't come on, it keeps blinking an orange light on the power button and the lights below the power button the first 3 indicator lights are orange. I tried unplugging and plugging it...
hi,
I have several of these and most often there power supplies blow. since they come by default with only one powser supply. the system won't start
I would start there as most other problems will generate beeps.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 17, 2011 | Dell PowerEdge SC1420 (SC1420MIN) Server
Hello, Hi, I've just got myself a brandnew Dell desktop with windows 7 32 bit on it. Everything seemed to work fine, but my computer enters Power saving mode at completely random times while im actually...
The simplest thing to do, as it is a desktop computer, is go to the control panel, power options and set everything to never so the computer never goes into standby mode.
If this does not prevent the machine going into standby mode then we need to perform further troubleshooting.
Jan 29, 2011 | Computers & Internet
LCD Monitor will power in and when connects to modem the power button is green then turns orange, what is the problem?
When the monitor button turns to yellow that means the monitor is on standby mode. Try rebooting the the computer after you have connected it to your modem. If the light goes to yellow again check that the computer is on and that all the cables are connected properly. HP Computer monitors are a little confusing, Sometimes depressing the power button again while it is yellow will turn it on and should so green.
Jul 21, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Looking for power up issue help please. Attempted to put comp. in to sleep mode by pressing keyboard button. Nothing happened. Went to windows xp start button and hit standby, nothing happened. Did this...
few things to try you can disconect the hdd the dvd rw drive and anything elce conected to it appart from the motherboard and moniter then try again (just becouse you tryed to check the psu it my well still be completly broken ) i would probly suspect the motherboard in this case thought i would try a new psu first as this cost less (10 pounds from ebay) hope this helps ps reset the bios and cmos too
Jul 10, 2010 | HP Pavilion a1250n (EG194AA) PC Desktop
Sleep Mode Lockup on Dell Inspirion 530 w/ Vista
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
Hope this helps.
Mar 08, 2009 | HP Media Center m7060n PC Desktop
Screen will not power on
most generaly capacitors on main power supply board
Dec 15, 2008 | Computers & Internet
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
Gateway GT5220 PC Desktop Logo
325 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
