Flat data cable has become detached - Office Equipment & Supplies
I need sandisk refurb 2.0 data cable
Posted on Mar 05, 2009
Owner bought a new printer.
Posted on Aug 20, 2008
Wont stop when hot when throttled back
Assuming that the engine is supposed to stop when the throttle is pulled right back (not all of them are), then either the wire on the STOP terminal has become detached, or the cable is not moving the lever on the engine far enough - cable adjustment required.
Aug 06, 2013 | Garden
Starter motor cable coming adrift
I'm sure it is the solenoid connection. Replace the push on connector.
Oct 10, 2012 | Cars & Trucks
My car hood latch cable has become detached so how do I get my hood open?
Go under the dash and cut the outer sheath back over the inner steel cable, pull that inner cable with a pair of vise grip type pliers to release the hood latch.
Jun 06, 2012 | 2004 Suzuki Forenza
New toshiba tv connect to sky plus box and perfect picture but no sound
The first thing to do is check the connections between the Sky box and the TV. If you are using a SCART cable, it's possible that one of the pins in the SCART plugs has bent or become detached from the wire inside. If you have another SCART cable from a VCR or DVD player, try switching them over.
If this doesn't work, or if you are using another connection method between the Sky box and the TV, please post back and I will try to assist you further.
Regards,
BElectric
Nov 29, 2010 | Toshiba Televison & Video
I have a hp presariocq62 laptop and when i turn it on it doesnt boot up it reas error has occured press ctrl alt del to restart what should i do ty
Either:
* the "data" cable between the motherboard and the disk-drive has become detached
* the "power" cable between the motherboard and the disk-drive has become detached
* the disk-drive has "died"
* your installation of Windows is corrupted
Either way, Windows cannot "start" nor "complete" the boot-up process.
Take your desktop/laptop to a qualified technician, for proper trouble-shooting, replacement of "dead" parts, and repair.
Take the original HP "System Restore" CDs, too,
so that Windows can be re-installed, if necessary.
Oct 19, 2010 | Computers & Internet
PTO cable is real loose. My deck blade will engage on their own after running for awhile. I could not see where PTO cable attaches to idler pulley on belts?
Sounds like the belt is stretched or the tension spring has become detached or stretched. Also check that the pulleys are mounted solidly and run flat and do not wobble. Also check that the idler are has not cracked and twisted (mine did last month and then threw a chukof steel out sideways).
Sep 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rubber lining all 'twisted'? on front loading LG washer -- the washer was moved down the stairs by someone -- now the rubber appears all twisted and not lying flat like it was before. Do I need to remove...
Sounds like the suspension spring or springs have become detached, or the suspension legs have become dislodged.
Redmove the top to check for detached spring, if o/k, then check underneath the washer, and see if the suspensions are o/k.
Please rate my solution.
Thanks.,
Jun 22, 2009 | LG WM-1832C Front Load Washer
I have a Imation DC 6250 Data Cartridge where the tape has become detached form the spinlde therefore tape not winding. Any solutions?
Those cartridges can be disassembled (carefully) then re-attach the tape to it's original location with small piece of clear packing tape or even Scotch tape trimmed to same width as the mag tape.
Oct 25, 2008 | Imation Computers & Internet
44 people viewed this question
jasbo
jasbo
