Question about D-Link DI 514 Wireless Router (DI-514)
Wireless connection I go on the rt click wireless connect and click the linsky unsecure net. I click connect and it never connects and shows no error. if I go to the connectivety doctor it says IP problem. I have changed settings and took it to the Geeks and it works fine there but they are not linsky. My operating system is XP and this is my Tobishi lap top. I believe I have changed a setting that is not allowing me to connect. BJ bjnewit8@yahoo.com
  • 14 Answers
You need to edit you're router's wireless settings, maybe there is a conflicting default network w/in you're range. Make sure you change the SSID (wireless name) to a unique name, the channel I advise you to set it to CH11, and enable wireless security as well, you can go for WPA-Personal it will be supported by XP and it's a good encryption method. And try removing all the network's listed on the "preferred networks list" on windows to make sure there won't be any conflicting wireless profile.
Posted on Aug 20, 2008
Connecting notebook to linskys wireless router
click on start >> go to control panel >> double click on network and internet connections >> right click on wireless network connection >> click on properties and go to wireless tab >> check the box at the top that says use windows utility >> click on ok and then right click on wireless network connection and click view available wireless networks. It will show you your network name. click and connect to your network.
Feb 27, 2010 | Linksys Wireless-G Broadband Router
My wireless network connection status in connected Speed is11.0 and my signal strength is good, but I cannot connect to the internet connection godd but internet explorer cannot display the webpage
You are getting local access only.
Right click on the icon in the system tray and click repair....
If it still happens you need to connect to a different network..this usually happens if you are connecting to an unsecured network (I assume yours).
Alternative: Unplug the network adapter. Turn off the computer. Wait approx 2 minutes.
Power on computer with net adapter connected....
Dec 18, 2009 | Sony Computers & Internet
It connects to a unsecured net gear but wont to my linksys g i have a 16 diget key could this be the problem thanks barry
Yes.
If your wireless adapter connects fine to an unsecured access point, but will not connect to your secured access point, the problem is in the security layer. Either you are not feeding your adapter the right key, or your adapter doesn't support the encryption type your access point is demanding.
Sep 17, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Y linskys is unsecure, how do i secure it?
need to reset a new WEP code go to their website to find out how
Aug 16, 2009 | Linksys Wireless-G Broadband Router
Blue Ray connection to Belkin G router
your wireless router is encrypted. To remove encryption, go in your computers web browser: http://192.168.0.1
That will take you to your LAN Administrator.
Follow the simple wireless setup for an unsecured connection or setup your blue ray connection and create your own passphrase or WEPKey.
Hope that helped!
Jun 23, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Excellent Wireless Network Connection, cannot access internet
The unsecure public network nay be using mac address filtering. In this case, the network will show as being unsecured, and will even allow you to connect in some cases, but then will not allow you to surf once connected.
May 28, 2009 | D-Link Air DWL 650 802.11b Wireless...
Wireless network problem
go into ur wireless network properties.click internet protocol.check settings .if obtain ip auto is checked.connect to the unsecured network to obtain details..ip,gateway , dns etc.
disconnect go back to wireless properties and select use the following ip/dns in internet protocol and type in the details..this will get u connected..once connected left click on connected icon in sys tray and select repair this should make changes to ip and dns..it may change it may not ..if not it doesnt need to.
Jan 14, 2009 | HP Compaq Evo n610c Notebook
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
Wireless internet connectivity problem
On an unsecured access point (not WEP or WPA) it should work.
Try here for advice http://forum.eeeuser.com/
Presumably you don't need to set a proxy in Mozilla?
Aug 06, 2008 | ASUS Eee 4G Notebook
Linksys wireless card with ASUS WL520g Router - encryption error
you have changed the network key, but why update the username and password as it should always be the same which is the one supplied to you to connect to your service providers connection, assuming you mean the security key, go to your pc and search for your network again, as it will be trying to connect to a non existant unsecured router. When it searches and finds the networks in your area, choose yours click connect and the enter password window should pop up to be entered. Go to your browser and clear old temp files and cookies in tools, internet options, restart pc and you should assuming you have put the correct settings in be online.
Sep 13, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
D-Link DI 514 Wireless Router (DI-514) Logo
75 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
