Question about Mitsubishi CS-26201 TV
Horizontal line across my tv
I wake up one morning and turned on my tv and see an horizontal line across my tv. The audio is still good . What has happen tp it?
  • Mike Andrew Oct 26, 2008
    I have the same trouble with the same TV model. I can solder, and I have some experience with digital electronics, but none with television receivers.
    Where is the vertical circuit located, and how can I access it without disturbing any of the adjustments?
  • Mike Andrew May 11, 2010
    I found the vertical deflection circuit - got the Sanyo LA7837 datasheet from the web so I knew what to look for - and re-soldered it as suggested. The TV now work perfectly!
    Thanks much, Dan!
  • 4,234 Answers
This is a problem with the vertical circuit and is relatively common. If you can solder you can fix this yourself. First try resoldering the pins on the vertical IC. If that fails to resolve the problem, replace the IC. This IC is a small flat IC attached to a heatsink having about 11 pins or so. Is will be marked LA7837 or something similar. Post the marking here and I'll confirm the part.
Keep us posted.
Dan
Posted on Aug 19, 2008
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Tv has horizontal line in middle of screen,sanyo ds25390
hi if only a horizontal line across with no video anymore, you have bad either vertical ic or no dc supply b+( vertical ic ) or no output dc coming from the ic. if it is not totally a horizontal white line and you can see a video you must check leak or bulged capacitors at the vertical section near the vertical ic. hope this can help good luck.
Oct 02, 2012 | Televison & Video
Thin horizontal line across the screen
you need to replace the electrolytic capacitor in the horizontal section of of your tv sets,cause the capacitor is weak.need to repair
Jan 11, 2009 | Sharp 27C-240 27" TV
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Oct 06, 2007 | Akai PT4799HD Rear Projection Television
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
Televison & Video Logo
200 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
