Question about Dell Dimension 4100 (-JM0TB01) PC Desktop
No video A few motnhs back our Dell Dimension 8400 MCE crashed. To try to sabve the data, the dell tech. asked me if i had an older computer or another computer in our house I told him i have a dell dimension 4100. He said that is fine. So i plugged it in and turned on the computer. He then noticed this model is to old to for the dim8400 hard drive. (i only plugged in the 4-prong power by the way) I then took the hard drive from the 8400 and took it downstairs... A few minuted later i came back to my 4100 and turned it on. There was no video. I called Dell (even though it is out of warranty) and they didn't know what it was. They didn't want to replace it even though it told them a Dell tech told me to plug it in. Now i am stuck with a delldim4100 that used to be perfectly fine and now has no video. (Specs: DVD-ROM, CD-RW, 384MB RAM, XP Pro, Floppy, USB 2.0. ---- sound, video, LAN, and modem are standard.)
  • neetfreek Aug 20, 2008
    i've aleady tried that
  • Dell Master
  • 3,051 Answers
You can try to hook up everything back up and then take out the video card and clean the place that it llides into and the card itsself and reinsert it and see what happnes but please make real sure that u connect everything back just like it was cause if there are cablkes that are switched there will be problems
Posted on Aug 20, 2008
Dell dimension 8400 pc desktop when pressed power botton orange light comes on and system not booting up
Needs attention from a tech. Could be anything at this point, bad ram, bad/dirty ram slot, failing power supply or motherboard, bad video card... I'll put my money on bad motherboard otherwise I hope you would have wrote that you are hearing beeps. Hope that helps you some.
Aug 10, 2014 | Dell Dimension 8400 PC Desktop
How do I replace the graphic card on a dell dimension 4600 desktop
open left side of computer (after shutting it down and disconnecting it)locate the graphics card, its the one your monitor connect to,disconnect monitor cable from board remove little screw holding card to back frame and ease card out replace with new one put it all back together and start pc up if it asks give it the software disk that comes with new card and follow the instructions.
Jul 06, 2010 | Dell Dimension 4600 Video Card (M9 TVT...
Dell 8400 No Boot, not even POST
It sounds like your bios were improperly flashed or went bad. The X300 SE message is your video card. So your video card works, the system mostly works, but the BIOS isn't starting up. You should contact Dell and tell them the situation.
Apr 19, 2010 | Dell Dimension 8400 PC Desktop
I have a Dell Dimension 8400 P4 3.2G w/XP Media Center V2002. Just replace the HD due to a crash of orig HD. Cannot get the TV to work. Get the following error msg - Decoder Error - The video decoder has...
Sounds like the driver for the TV Tuner is not installed, or the video and audio drivers may not be installed properly.
Mine was always a bit wonky in XP, works like a charm in Vista or Windows 7 though
Jan 26, 2010 | Dell Dimension 8400 Desktop P4 630 3G 1GB...
Sonic, Dell Dimension 8400, Philips DVD +- RW burner
are you copying ,copy writed material?then you need dvd descripter.
Jun 14, 2009 | Dell Dimension 8400 PC Desktop
Dell dimension 8400 beeps 6 times monitor dosen't turn on
Below is a link to the beep and light codes for a Dimension 8400. Check your codes and reply back if you need further assistance.
http://support.dell.com/support/edocs/systems/dim8400/SM/adtshoot.htm
Jun 03, 2009 | Dell Dimension 8400 PC Desktop
Dell 8400 runaway fan no diagnostic lights and very ocassionally it starts normally
Which fan?, the cpu fan or the cpu fan?
Most Dell pc come with a below average power supply. I recommend replacing your power supply with a better one. Do a search on Google for a good replacement power supply for you Dell 8400.
Please rate response.
Feb 17, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension 4100 (-JM0TB01) PC Desktop Logo
78 people viewed this question
Alun Cox
