Question about Canon PIXMA MP830 All-In-One InkJet Printer
Large black streak down the back of the paper
We have a large black streak printing down the back of our copies. After alot of copies of something it gets lighter. but the next copy down the road it's worse again. How do we clean the copier to remove it? Ee also tried changing the large black cartridge to see if that was the problem but it didn't work either. Help!!!!!!
  • robm804 Aug 20, 2008
    We get the same problem.
    We use genuine Canon cartridges. Our machine is just over a year old. Tried emailing Canon but they were not interested.
    Any thoughts?
  • 4 Answers
This is a fairly common problem. More common when you use junk cartridges from printcountry.com.
1) you will need some cotton swabs, isopropyl alcohol and "canned air" or any pressurized computer cleaner.
2) lift up the top console while the unit is on and wait for the cartridges to reset to the center position.
3)Release the grey lock on the LH side of the cartridges and remove cartridges.
4) take alcohol soaked swabs and clean bottom of ports and nozzles.
5) blow out with air.
6) go into program and run clean and align programs. (if you don't have them go to google and type canon mp830 support)
7) retest.
8) if this doesn't work, give to someone you hate or throw out window.
Posted on Aug 20, 2008
Printing a large black streak of toner on rt side of page
Hello! Malik Muhammad Mehran Here... your problem solution is that you must replace the cleaning plates in the cartridge...
Mar 28, 2010 | HP LaserJet 6L Printer
Large Black streak on outbound fax/copy
1 or 2 LEDs are burned out in the scanner unit.
Sep 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Black streaks on paper
Most leasing companies will not provide financing unless you have a maintenance agreement by an authorized servicing agent. These parts should be covered under that agreement. If I can help, contact me at www.Xippa.net.
Apr 10, 2009 | Panasonic Workio DP-2330 Printer
Dirty copies.
Does this streaking problem occur when printing (not copying)? If it does then you are probably looking at a consumable issue. Alot of times black streaking is caused by a defective or spent drum. Is your drum new? There is also a blue piece on the drum unit used to clean the corona wire that cleans the drum. Have you tried moving it back and forth several times?
If the problem only happens when copying and the streaks are as bad as you make them out to be then you problem have a bad CIS unit (scans your originals for faxing or copying)
Inkworks
866-381-0541
Nov 21, 2008 | Brother IntelliFAX 4100 Laser Fax
Black smudges on printed page
Are you sure this is a Designjet 450 (large format printer) and not a Deskjet 450 (portable printer)? The following assumes you have wispy black streaking on the printed side of the paper. If the streaking is on the back side then post more details of the printer model and the issue.
In either case the most likely cause is a buildup of fibers on the underside of the printheads or carriage, causing wisps of black ink to be dragged on the paper when the carriage reverses direction. You can clean the printer as shown at the following (though the details will be somewhat different for the Designjet or Deskjet....).
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 16, 2008 | HP DesignJet 450c InkJet Printer
Black streaks are appearing on printed page when scanning
Do the lines only show up if you use the document feeder? If so, there is something on the strip of glass where the page is scanned. Open the top to reveal the large glass area. Then open the part where the paper feeds in when using the document feeder. It will flip open from right to left. There are two pieces to this, so make sure you grasp it as low as possible. You should see a small strip of glass. Clean all the glass with a SOFT cloth. Don't spray any cleaner onto the glass, rather, spray it onto the cloth if you need any.
Apr 19, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Black smudge streaks on rightside of printed/copied material
Can only be two things the drum or the fuser. More than likely drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine.
Dec 17, 2007 | Brother MFC 7420 All-In-One Laser Printer
Large grey streak down center of page
It is the fuser at rear giving you grief! The upper heat roller has a teflon coating that wears away allowing toner to stick to roller and smudgin prints as they pass threw it. The fix is to replace fuser assembly, take to brother dealer to fix.
You can prove it to yourself by timing the print to stop mid way threw machine then remove print cartridge and look at paper, you should see a image is good untill it hits the fuser,( pre fused image "rubs off" paper.) If you have changed drum and toner thats all it can be. They all do it in time.
Fuser is hot bit at rear, pull out drum and look in the back with a small torch you will see upper heat roller is worn, guestimation $90 for fuser plus labour to fit.
Nov 16, 2007 | Brother IntelliFax-2820 Laser Fax
Black streak on one side
Stop the print with a little practice, half to 3/4 of the way threw machine by opening door at right time. You want the paper to be jammed/stopped after the drum (has image on paper) but before fuser (print should still rub off)
fuser is blue green 300 thingy
If print is line less where stopped then mark is from fuser, replace
If print has line before fuser then it is drum/cartridge
..probally drum..need more info to know for sure, ie you say mark when faxing I guessing you mean receiving, what happens in copy mode is same as printing I'm assuming too
Nov 08, 2007 | Canon imageRUNNER 1370F All-In-One Laser...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
214 people viewed this question
old marine
old marine
