Question about HP PSC 1210 All-In-One InkJet Printer
Page print How do I adjust the print width? Only prints left side of page.....is this a printer problem or a PC problem? Thanks
    Genius:
  • 3,422 Answers
HI,
Please click on the below link to view the user manual:
http://www.fixya.com/support/p378669-hp_psc_1210_all_in_one_inkjet_printer/manual-3473
Posted on Aug 19, 2008
I have a stupid question where the heck do Iload the paper in my Lexmark X2350 printer??
Facing towards front of the printer, on the back of it you have raiser - paper support panel, with side slider on the left hand, push slider towards left in full.
Paper accepted by this printer is all standard grades, like A4, L4 and fall in these dimensions:
width min/max - 76mm to 216mm (3" to 8.5")
lenght min/max - 127mm to 432mm (5" to 17")
Printer will accept paper weight between 60g and 180g, that meant that all standard weight of paper including cardstock will be accepted, printer as well will print photo and envelopes.
• The paper is loaded against the right side of the paper support.
• The paper guide rests against the left edge of the paper.
1. Put paper long way vertical on raiser (paper support), about 80 to 100 pages of standard paper will fit there (depends on thisckness),
2. Push paper against right side
3. Adjust width with left hand slider. Do not buckle the paper!
After print paper is ejected at front bottom slot, printer side up. if you use photpaper or gloss paper, remove it immediatelly as need longer drying time and will get smudget by next printsheet.
You can find information with pictures in your manual on page 13/14.
Hope this will help you print beautiful pictures!
Aug 11, 2010 | Lexmark Z2300 InkJet Printer
Horizontal alignment ok, but right half not printing.
One of two situations exists:
1. If the printing stops with clear stopping edge, then the PRINT WIDTH setting has been changed from the default full width setting of 104mm.
Check this by pressing MENU and then the NEXT button until you see a setting for MAX WIDTH. It should be set to full width of 104mm. Anything less will stop printing beyond whatever the setting is. Change it back to the full width setting.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles that press down on the printhead and the pressure can be adjusted by moving the right toggle to the right so that more pressure falls on that side of the printhead.
Hope that helps !
Jul 20, 2010 | Zebra 140XiIII Plus Thermal Label Printer
My zebra only prints the left half? I have tried calibrating, it does nothing. Can you help me out? Thanks
Best way to check this is to take your tallest and widest label and print out a configuration label. This is done by turning off the priner, pressing the CANCEL key and holding while turning on the printer. Release the button when the calibrate led turns off. A config label will print and you can check the setting for PRINT WIDTH.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles the press down on the printhead and the pressure can be adjusted on each by turning the knob on top. Readjust the right side until printing returns across the label.
Hope that helps !
Apr 26, 2010 | Zebra Stripe S600 Thermal Label Printer
How do I increase print size in lexmark 1150 all in one printer
Hi
You can try the scaling function and check the page setup or go to print properties and adjust the slider on your printer to adjust the width before you start printing.
Thanks for contacting fixya.com
Dec 08, 2009 | Lexmark X1150 All-In-One InkJet Printer
My epson rx420 only prints the left hand side of any document ??? Can any one help please . many thanks
have you set the page setup in document is same with page setup at print setup. Some new epson printer use paper sensor to measure the paper width. If page setup wider than actually paper inserted, the printer will print only half page. example : Your document 10 cm wide, page setup 20 cm, and you insert 10 cm paper wide. It will print only half of 10 cm, 5 cm.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
HP laserjet 3050 prints skewed vertically
250-sheet input tray (tray 1)
The input tray holds up to 250 pages of 80 g/m2 or 20 lb paper or fewer pages of heavier media
(25 mm (0.9 inch) or less stack height). Load media with the top forward and the side to be printed
facing down. To prevent jams and skewing, always adjust the side and rear media guides.
NOTE When you add new media, make sure that you remove all of the media from the input
tray and straighten the stack of new media. This helps to prevent multiple sheets of media
from feeding into the all-in-one, which can cause jams.
Hope this helps if not you may have a registration roller problem.
Dec 15, 2008 | HP LaserJet 3050 All-In-One Printer
Only left side of page is being printed. Just had cartridge refilled as I thought the ink was low. Unfortunately, it still prints the same? What does this mean? Thank you.
check 2nd transfer roller or pc drum, open door when printing and check pc drum, if there is the whole printed page, then adjust 2'nd transfer roller
Jun 07, 2008 | Konica Minolta PagePro 1350W Laser Printer
140XiIII left side print right side completely blank
Verify your LCD Display Print Width setting is set wider than your actual label width. The printer will only print to the width of the PRINT WIDTH setting. Also verify any driver or software settings as these override your printer settings.
Jun 30, 2007 | Zebra 140XiIII Plus Thermal Label Printer
Left hand side prints faintly
inside the toner unit, there is a stirring device to broadcast toner over full width of drum. I will guess this is the culprit, the stirring device is not turning. Try this test: remove the toner cartridge and shake it rapidly back and forth. Then try a print, any change?
Jun 07, 2007 | Minolta magicolor 2400W Laser Printer
HP PSC 1210 All-In-One InkJet Printer Logo
24 people viewed this question
Seeker5211
Seeker5211
