I'm not a certified anything. Don't mind talking to you, though.
In the olds days to see if computer is awake, turn on the key, check ref voltage to any sensor that uses a ref voltage. If no ref voltage anywhere, have to check out the computer and wiring circuits, voltage and ground. I'm sure you know at the datalink connector, pin 16 is voltage and pins 4 and 5 are grounds.
Just about any relay that you can unplug, if you use a jumper wire between terminals on load side of relay, in diagram, the load side is that line with arrowhead, it will send voltage to anything the relay controls, the you check control side of relay, that coil symbol in diagram, for voltage and ground.
Just my opinion.
SOURCE: 2003 Caravan No Crank, 3.3L
This is a bad PCM. Try to disconnect the security system first and if it still does not start then it is the PCM.
SOURCE: 2000 ford explorer 4.0 x-engine is stalling, missing and lose power while driving
Exhaust might be stopped up. Check the catalytic converter and or muffler.
SOURCE: 1996 Ford Escort 1.9L hatchback engine cranks but doesn't start.
if the fusebox is above accelerator pedal its relay number 1 .best of luck.
SOURCE: I have a 1996 dodge neon the car starts for about
check power distribution center.if ok you have a faulty ignition component.
