Question about Kenmore Oasis HE 27082 Top Load Washer
How do I get the white cover off?
I am replacing my interface board but am having some difficulty removing the white cover. It seems kind of delicate I do not want to break it but it doesn't seem to want to come off. Any suggestions?Thank you.
  • 5,911 Answers
There may be several small screws holding it in place. Make sure those are all removed first. Then, take a small screwdriver and place it at the point where the plastic tabs meet the circuit board. Give the screwdriver a slight twist with one hand and gently pull up on the circuit board with your other hand. Repeat this process along one side of the circuit board, one tab at a time. Once you get one side of the circuit board loose, the rest of the tabs are easy to get loose. Once you get the old board removed, insert the new board in place, securing one side of the board first. Then, snap the board down, making sure the remaining tabs snap in place. Do not touch the surface of the circuit board with your hands. Handle the edges of the board only to avoid the possibility of damaging the board. I hope this helps answer your questions. If you are still having difficulties, please reply to this thread and let me know.
Posted on Aug 19, 2008
  • Jeff Rockwell
    Jeff Rockwell Aug 21, 2008
    By the way...great advice you posted about the recall information. I lot of owners of this washer will be relieved to know something is being done about this problem.
Cabrio top load washer (WTW6600SB1) start button broken - I can feel that the device behind the "Start" display has broken. It doesnt depress like usual. I removed the entire control panel. When...
Unplug the machine or disconnect power then remove the three hex-head mounting screws from the rear of the console. Tilt the console forward toward the front of the machine then disconnect the user interface board cable connector from the machine/motor control and lift the console off the cabinet.
Carefully pull the cycle selector knob off the shaft then turn the console on its face for access to the user interface control board. Unhook the wires from the clips then remove the three screws securing the board. Using a flat-blade screw driver, pry the cover's two locking tabs out then unclip and remove the cover from the console.
Lift the locking tab of the encoder then turn the encoder counterclockwise and lift and remove it. Carefully pry the font edge of the user interface board up then pull the board forward and remove it from the console. You may glue the broken part back in place or replace the console with part number W10070060.
Jul 18, 2011 | Washing Machines
1100 nokia no ringtone pls help me
There are times when the phone dropped on the ground,the buzzer mechanism sometimes dislocated,and when damage by water,corrosion gets along the buzzer interface.
To be able to fix this problem,you can DIY
* remove back cover and the battery.
* remove front cover
* unscrew 6 screws on all edges using T6 precision screw driver or any tool that may release the screws.
* lift up the entire module (lcd frame and the mainboard)
* you can see a small round circle on upper part attach on the back cover.seems to be the buzzer or speaker.
* clean and re-align the pins of the speaker or buzzer,make sure that the metal pins and the board interface are well clean.
* assemble the phone and be guided from what pattern on dis-assembly.
If still does not work,might need a buzzer replacement or fixing the board components,you can ask assistance to any mobile service shop near you.
Hope that this method helps you. Thank you for visiting FixYa.
Jul 10, 2011 | Nokia Lands Phones
How do you change battery for casio 1174 CMD-40?
I like these little RC IR watches. They're great fun!!! For this tutorial, you will need....
  • A small Phillips heads screw driver
  • A pin (or needle)
  • A replacement CR2032 battery
Instructions :
  1. Remove the 4 screws from the back of the watch
  2. Carefully remove the back plate, do not damage the delicate rubber seal
  3. Carefully remove the delicate rubber seal
  4. Use the pin to remove the small rubber block from the battery cover clasp.
  5. The pin should then be inserted in the gap of the white plastic lug, where the rubber block was removed.
  6. Use the pin to gently pull back the clasp of the battery cover.
  7. The battery cover will then open with a 5mm gap approx. It does not need to be removed.
  8. Use the screwdriver to remove the battery.
  9. After the battery has been replaced, just follow the instructions backwards.
I hope this little tutorial has helped.
Feb 10, 2011 | Casio Watches
I have cell phone lg kp170 with a display prpblem. the set only gives white light and doesn,t show any display and seldom lcd light flickers with intervals and seems as set is going to be restarted
First of all, you need to understand that the phone has a problem that is why it is having the flickers, white display and tending to look like it wants to restart.
The first solution to try out is for you to flash the phone with the appropriate software and cable be cause the phone might have contacted some kind of virus, either by file transfer from other devices or downloading of corrupt files. By flashing, all forms of viruses will be erased.
Also, the flexi ribbon that connects the screen to the main panel might be faulty, and to repair this kind of problem, you will have to unscrew the phone open and replace the ribbon. To replace the ribbon, follow the process below:
  • Remove your back cover, battery and sim. Remove the four screws you can see.
  • Run something like a credit card all the way around the join of the battery compartment to release it from the rest of the phone.
  • A number of clips, such as those by the upper left, lower right and that which is connected to the camera, hold the circuit board and front cover together. Release these clips to remove the front cover.
  • Turn the circuit board over. Release the clips that hold the grey part to the circuit board but make sure you don't break the two wires soldered to the circuit board. Top right is the ribbon from the LCD screen. To release this first remove the blue sticky tape then flick the black latch up.
  • That is the ribbon that needs to be replaced.
  • After replacing the ribbon, then you can reverse the process the reassemble the phone together.
Take care and good luck
NB: If you are not familiar with such process, i will advice you seek the assistance of a professional phone repairman, in order for you not to further damage any component of the phone.
Oct 30, 2010 | Cell Phones
Oasis washer kenmore elite, the end of cycle signal button toggles back and forth from soft to loud all on its own continuesly. what could be the problem?
This is a common and very well known problem with the Oasis. You will need to replace the operator/user interface board inside the control panel to resolve this issue. The board is located directly behind the control knob. You can usually order the part at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Just type in your model number and look under the "Control Panel Parts" heading. If you do not find your model number listed at some of the websites, use the part number you obtain from the Sears websites and do a Search by Part Number. You should find the part listed at the other sites. Sears tends to have a more extensive data base of model numbers, but may not always have the better price.
To replace the user interface board, follow these steps:
1. Unplug the washer.
2. Locate and remove the retaining screws in the back of the control panel. With the screws removed, the control panel will lift from the back first, then off. NOTE: Be careful when lifting the panel, there is a small interface cable plugged into the control board.
3. Remove the interface connector and pull the control knob off.
4. Lay entire panel face down on a soft surface (such as some folded towels).
5. Remove the user interface cover (this is item 10 if you use the drawings in the Sears website).
6. With the cover removed, take a small flat blade screwdriver and pry back the tabs that hold the board in place. There will be several around the entire perimeter.
7. Once the old board is removed, carefully insert the new control board making sure you don't put it in upside down. Mark the location of the interface connector plug as a reference. NOTE: Do not handle the surface area of the board with your hands. This can cause damage to small components of the board and render it unusable. Hold the board by the edges.
8. Reinsert the interface cover and flip the control panel over to its upright position.
9. Reinstall the control knob and make sure you plug the interface connector back in.
10. Reinstall control panel by inserting the front edge of the panel into the grooves on the washer top casing and lower it back. Tighten all mounting screws.
This is a pretty simple repair job. The hardest part you may encounter is removing the old board. The small tabs can be difficult to bend sometimes. Also, use care not to apply too much pressure on the new board when you install it. They can be difficult to snap back into place at times. Just take your time.
If you have questions along the way, please let me know. I hope this corrects your problem.
PS You may also try unplugging the washer and removing the control panel and try cleaning the interface connector to see if this helps BEFORE you order parts. Sometimes it helps.
Feb 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Circuit board
Un plug the unit remove the cover and remove the plugs by depressing the locks with your thumb. Plug one at a time each plug from the old board to the new board. Be careful as they are delicate.
Nov 25, 2009 | LG LSC27950 Side by Side Refrigerator
Kenmore Elite Oasis Model 110.27072600 Wigging out
The user interface is covered by a cover plate. There are a series of tabs that hold this cover in place around the perimeter of the control board. Use a small screwdriver to carefully pry the tabs back (one at a time). Also, you have to remove the control knob form the front panel, first, before the board will come out. There's an illustration you can use at searspartsdirect.com. Just type in the model number you provided and look under the "Control Panel Parts" heading for item number 10. This is the user interface cover that I'm speaking of. There is only one small wire harness to speak of that goes to this control board. Is this what you are talking about?
Dec 29, 2008 | Washing Machines
I have the same problem... could you send me instructions, too?
Okay...Fixya discourages us from having direct contact with customers outside the realm of this website, so I hope you will accept my reply in this forum.
If you are talking about replacing the operator interface board, its very simple. Just follow these steps:
1. UNPLUG the washer.
2. Remove the three screws in the back of the console.
3. With the screws loosened, the console will come of by lifting from the back first. Use care not to damage the small wire harness under the console.
4. Remove the wire harness from the User Interface board and remove the knob (by pulling) from the front panel. Lay the entire control panel face down on a soft surface (like a stack of towels).
5. Carefully remove the white plastic cover plate that is installed over the control board.
6. Once the cover is removed, carefully remove the old interface board by prying gently on the series of tabs around the perimeter of the board. There may also be some mounting screws to remove as well.
7. With the old board removed, carefully install the new board by inserting the control knob shaft through the hole first. Then, gently snap the board in place, making sure all the tabs around the perimeter of the board are in place. Reinstall any small mounting screws. NOTE: Do not handle the surface of the board with your hands. Handle the edges only, to avoid electrostatic discharge from your body causing damage to the board.
8. Reinstall the protective plastic white cover over the interface board.
9. Flip the console upright and reinstall the wiring harness and control knob (The knob only goes on one way).
10. Carefully insert the console in the front grooves on top of the washer, first. Then lower the back and reinstall the screws.
The repair is pretty straight forward. However, if you have questions, please post back and let me know. I hope this helps you.
Now...it was recently brought to my attention by a consumer on this website that there is a recall on this circuit board. The following paragraph is the direct direct quote:
"I too had the misfortune of dealing with the continuous beeping on my washer (model # 110.27062600). No code was given.I called the Sears hotline and asked for the manufacturers warranty department. I then called the recall line at (800)659-7026 and after giving my model number and serial number they discovered is was indeed recalled or being "upgraded"! They have ordered the part and are sending someone out. For those who have already paid to have it repaired I would call Sears and ask for a refund. Good luck!"
-joycdex
If I understand this correctly, you may not have to purchase a new control board. Or, if you did, Sears may refund the cost and provide someone to install it for you. It may be worth your while to contact them to find out. I hope all this information is helpful to you.
Aug 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis Washer
The problem is the User Interface board behind the control panel. This is a noted problem that often occurs with this model washer. The only option, I hate to say (unless you want to listen to the washer beep all the time) is to replace the board.
The part(s) you need are available at searspartsdirect.com. Simply type in your model number and look under the "Control Panel Parts" heading for item number 7 (User Interface - part #8564393). You may also consider item number 12 (User Interface Harness - part #3407184) to rule out the possibility of a bad wiring harness. You can try to do end to end continuity checks before considering a replacement just to be sure. The contacts are sometimes difficult to get to with a multimeter, though.
This is a fairly simple repair to accomplish on your own. Just follow these steps:
PS I tried to find parts for this washer at others websites, but could not find a listing for it.
Jul 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
67 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
