Switched the tele on and the top half of the screen is in a thick green and red band across it, its not sky i pulled the plug on it bottom half is ok. other teles in house work
  • 138 Answers
Bring upthe menu and see if it id affective also. If not replace the small signal baord.
Posted on Aug 19, 2008
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Picture shows double images in red and green with red and green bands across the bottom of the screen
convergence ICs need replacement there are two STK392-110 Convergence ICs in that model, Also check the 2.2 ohm 2watt resistors there are 6 of them in that model.
Jan 22, 2010 | Panasonic PT-53WX53 53" Rear Projection...
KP57WV700 - Blue Lines Across The Screen
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Sony KP-57WV700 57" Rear Projection HDTV
Magenta band on lower half of screen
You have a bad optical assembly part #A-1606-008-A.
Feb 08, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
Hitachi 32" Plasma TV fault on screen thin pencil type line on left hand side of screen from top to bottom. Line thickness is approx 1mm TV is 5 years old Thanks Tom
iav a sky 42 inch plasma model number pd54250 when i swich it on i av got a green lined picture sometimes it comes on with a full picture can you help
Nov 22, 2008 | Televison & Video
Switching on the tele this morning, the normal blue background is now half red and half blue.....(top half red) so that while watching a program now people have green faces.......weird!!
Good Day, deejay268;
Try resetting the entire system by unplugging the tele and the boxe. Unplug from power source for 3 to 5 minutes, then re- connect. Good Luck, big IRISH.
Sep 01, 2008 | Televison & Video
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
GE 46GW945
Your problem is a bad main filter, a regulator IC ,and or a combination of a convergence problem along with a vertical IC going bad. This set is not something you should mess with unless your a trained tech. Please seek a pro to assist you with this repair. good Luck
Jul 28, 2006 | GE 46GW945 46" Rear Projection Television
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
