Question about Fuji FinePix S304 Digital Camera
Fujipix A400 ZOOM ERROR
  • 6,831 Answers
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Posted on Oct 07, 2010
The zoom won't come out when I try to turn my camera on, it just turns a little bit, then turns back to the original place, and the screen says zoom error. I've tried different batteries, and taking out...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 14, 2010 | Cameras
I copied pix to laptop using Nikon Transfer. I
Try formatting the memory card in the FujiPix 2800 camera. See if that helps..
Oct 01, 2009 | Fuji FinePix 2800 Zoom Digital Camera
Hello- We have the Kyocera KM 1510 and have an error message A400 coming up on the printer. No functions will you have a suggestion or what would cause this problem. The toner cartridge was just...
Inside the printer, in the laser assembly, the zoom motor is not working anymore. Try to open it, stay clear of the lens, remove the little board with the motor atached to it, open the motor and clean it. Normaly it should run smoothly. i had the same problem, solved it, but now i get the A100 message. Any ideas?
Jan 29, 2009 | Kyocera KM-1510 Copier
Fuji fine pix A400 zoom error
the camera may not be dropped but the lens may have initiated incrrectly, like it was turned on inside the case that the something prevented the lens to fully mount (telescope out) to default capture position.
it is repairable with Fuji Techs, but if the cost of the repair is worth 3/4 to the original price when you got the unit and is out of its warranty, then it will be best to get it replaced, and you may use this camera for harsh environments, like outdoor trekking or a helmet cam perhaps, it just a personal idea.
Jun 22, 2008 | Fuji FinePix A400 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Cant take a picture
This is a common problem with this camera and it needs to be sent back to Fuji for repair.I've been through it three times and then they replaced the A350 with an A400 and now I'm having the same problems with the A400.
They want to swap it with a E500.
Both of these replacements are less of a camera then the A350.
If they won't repair it under warranty I suggest you stay away from Fuji cameras in the future,I know I will never buy one again
Nov 21, 2007 | Fuji FinePix A350 Digital Camera
Zoom error on finepixA400 camera
I had the problem with the lens being stuck out. I ended up pressing gently but with a lot of force and it collapsed while making some load clicking noises, I figured that I’d busted it, but I turned it off and back on and it worked great. I know it’s not a great fix but it might work for some of you.
Oct 19, 2007 | Fuji FinePix A400 Digital Camera
Zoom lens won't retract
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
May 09, 2007 | Fuji FinePix A400 Digital Camera
Fugifilm FinePix A303 Digital Camera
hi this error indicates that the delicate mechanism of the zoom had gone bad there is no way you can fix this by yourself leave it for an expert have a good 1
Apr 02, 2006 | Fuji FinePix A303 Digital Camera
Fuji FinePix S304 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
