Hi
Sorry for late reply
In windows Right Click My computer go to manage then Disk Management, Right Click the Drive which u need to format and delete or format the drive with NTFS partition
Thanks
T.Boopathy
Hai
In mac go to MAC HDD then Application then Utilitys then Disk utility there u can format the HDD by using erase option select the partition as EXT journaled
Thanks
T.Boopathy
Hai
Thanks
T.Boopathy
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer you should see your usb drive
right click then select format
another way is to control panel administrative tools computer management disk management right click on your drive select format
hope this helps
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
once you have removed the write protection you can delete these files or format your drive
click start right click on my computer select open you should see your drive
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps don
What about the same problem but with Mac OS?
thank you so much!
