Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
My dell ultrasharp 1800fp monitor keeps flashing on and off, its not a power problem as the power button stays on and when i disconnect the the monitor cable from my pc the no signal message stays on the screen fine. it used tostay on on if left for about 10 mins. now it just blinks constant. any help on this would be great
  • 5 more comments
  • 1337runner Sep 13, 2008
    Build date August 2003 Same problem, noticed that when it flashes on intermittently, it displays 2-3 different resolutions. Tried analog and digital inputs. same problem. I suspect it is the board that the inputs connect to.
  • Anonymous Oct 01, 2008
    I've got the same exact problem and I'm going to try replacing the inverter board with one off of eBay. I do have another 1800FP that actually needed power supply board replaced and that fixed the problem with it. This one is different though. I'll let you know if the inverter board fixes this one.
  • Lori Edwards
    Lori Edwards Oct 22, 2008
    Mine does fine through the boot up then when gets to the XP login screen, the image gets distorted and the screen begins to flash at different intervals. When booted up in safe mode there is no distortion & no flashing, only when booted up in normal mode does this happen... is this a monitor problem or could it be something else?
  • Anonymous Nov 20, 2008
    Im calling Dell again & making them take it back !!!! Its only like 5 months old!
  • llbandit Feb 02, 2009
    My Dell 1800FP is flashing on and off, power cord. I tried another monitor on that pc, and it works fine. So I am not sure what I can do to fix this monitor?
    Any Ideas?
  • Johnny Morris May 11, 2010
    My dell 1800fp keep flashing what is the problem!
  • eric rust Sep 22, 2012
    I have one with same issue, tried replacing pwm controller but it did not help.
  • 558 Answers
Inside there is a IC chip on the power pack that goes bad, replacement is called for also look for bad capacitors when you are inside looking around, those need to be replaced as well
hope this clears things up. dells third party who built these units did a rotten job on this model. that chip always fails.
Posted on Apr 05, 2009
Does ultrasharp's 1800fp monitors have built-in speakers?
No built in speakers. There is a sound bar that you can get the attaches to the bottom of the screen to add speaers to the unit but it is sold separately.
Sep 26, 2012 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Video on 1800FP flashes on and off.
You need to check the output voltage of the power supply module to see if the 12vdc output is swtiching on and off, it can be power supply failure or it is sensing short circuits, it can also be the inverter board.
http://www.lcdrepair.us/1800fp-power.html
http://www.lcdrepair.us/1800inverterKUBNKM045A.html
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell ultrasharp blinks on and off
It could be a setting problem, power saver setting, or a mode that the monitor does not really support - things like refresh rate - or actual hardware.
Easiest way is to borrow another like monitor, and say another video cord and see if the problem remains, or if a newer monitor says 'out of range' or similar.
Then, if you have a fancy video card,remove it and use something primitive. Not reading instructions is a big cause.
If its not a setting issue, and as the inverter board is ok; if the above description is correct, reseat the inner board connecting cables.(wood fires and seaside locations) If not that, a lucky guess might be the electros on the logic board.
Aug 20, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP is black on start up but green light is on
i had the same problem i found out it was the inverter i replaced it and it was like new. i do have 2 inverters if you are intrested
Jul 30, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell Ultrasharp 1800FP Power Saving Mode
go to control panel>power option>power scheme.
adjust the hard drive to 30 mins and everthing else 20 minutes.
also, go to display and adjust the screen saver to be longer. up to 9999min.
Jun 30, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
ORANGE FLICKER ON POWER LED
Is the orange flicker on the screen or on the button?
Does it always stay on or does it go off?
What kind of monitor is it? Flat screen LCD or CRT?
Mar 23, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP, green power light, black screen....
Its probably the inverter that lights up the screen that went bad.I have replaced inverter before with much sucess. If you feel comfortable opening the unit up I found one on ebay. Here is the link.
http://cgi.ebay.com/1800FP-LM181E06-FPD1830-18-LCD-Inverter-KUBNKM045A_W0QQitemZ300179625342QQihZ020QQcategoryZ74936QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Dec 09, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP - display leak - blue craziness
That one is going to take component level troubleshooting. It could be the power suply, but I might first suspect the video board.
Jan 02, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
1,135 people viewed this question
Alun Cox
