Question about HP Compaq 6720s Notebook
4gb ram wont work
Got brand new 6720s abd it wont accept 4 gb in XP , all is cool until the login screen shows =total freeze
both dimms are
HP 2GB 667MHZ DDR II SODIMM
PN 395319 - 544
Why does this not Work ?is the 6720 unable to use 4GB under XP ?
fair winds Lars
  • ssddandersso Aug 20, 2008
    This modell should fix 4Gb according to HP
    Lars
Hi i know these machines quite well. even though it states that the maximum ram is 4gb . it sometimes will not take it. if you have 667 ram in it change to 666 that usually works. these machines can be fussy now and again.
Posted on Apr 26, 2012
    Problem Solver:
  • 30 Answers
I did have the same issue - instead I installed 1 x 2gb stick and 1 x 1Gb stick. 3Gb is better than 2Gb anyway so its all good :)
Posted on Jan 14, 2009
    President:
  • 2,961 Answers
Its not XP it will be the maximum capabilities of the amount of memory the laptop can handle, please refer to manual for max amount, i would suspect 2GB max
Posted on Aug 19, 2008
  • Jon Faulds Jul 08, 2011
    Sandrew - the unit can handle 4Gb Max as I am using Windows 7 64 bit edition on mine and its running without problems seeing the 4Gb. The limitation is most definitely with the XP operating system as it affects various hardware platforms (even units that can take up to 8Gb). Windows XP 32 bit will see no more than 3.5Gb of any available physical memory.
Have a COMPAQ PRESARIO SR2020nx want to upgrade the memory it have 512mb how high I can go up on the memory
  • Two 240-pin DDR2 DIMM sockets
  • Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs
  • Non-ECC memory only, unbuffered
  • Maximum HP/Compaq approved memory is 2 GB
Feb 28, 2013 | Computers & Internet
How can I find out exactly which model of MPC ClientPro I have? The model # on the sticker is D865GLC-0DYD (note, that is a "zero," not the letter O, before the DYD at the end). I can't find...
System memory for D865GLC-0DYD
The Desktop Board D865GLC has four DIMM sockets and supports the following memory features:
  • 2.6V (only) 184-pin DDR SDRAM DIMMs with gold-plated contacts
  • Unbuffered, single-sided, or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported
  • 4 GB maximum total system memory
  • Minimum total system memory: 64 MB
  • Non-ECC DIMMs
  • Serial Presence Detect
  • DDR400, DDR333, and DDR266 SDRAM DIMMs
Jul 06, 2011 | Computers & Internet
I have intel(R)pentium(R)4cpu 3.00GHz(2cpu) & intelD945GCR motherboard & 512mb DDR2 ram this is my pc , this will be work slow for me how will reduce this problum i think do some cheanges in...
You can install a total of 2Gb or 4Gb RAM on this motherboard.
The specifications for the RAM are as follows -
Memory
• Two 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets
• Support for DDR2 533 or DDR2 400 MHz DIMMs
• Support for up to 4 GB of system memory
May 13, 2011 | Intel D945GCCR Motherboard
Dell precision 670. Adding 8 gb total memory. Using Kingston KX1563-NAB; DDR2 2gb 2Rx4 PC3200 EEC, registered. Accepts 4 gb in dimms 1 and 2 (2 gb modules) and boots fine. Adding 4 more gb in dimms 3...
glenn_mullin
From what I can tell the Dell Precision Workstation 670 does support over 4GB of RAM. However when you have over 4GB of RAM installed in the system you have to have the Memory Cooling Shroud connected to keep the memory cool. Also this is only shipped out when the system is ordered with over 4GB of RAM originally. If you do not have this part you can order it from Dell buy calling 877-671-3355.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jan 27, 2011 | Dell Precision Workstation 670 PC Desktop
Blue screen with 4gb, OK with 3gb of RAM on 6720s laptop Using windows 7 (32 bit) there are 2x slots, but the top slot seems only capable of recognising 1gb of RAM without giving the blue screen at startup...
A 32bit OS and Processor is able to Identify and work with upto 3GB of memory.
That may be the cause of the issue
Even if any computer has more then 3gb of ram it will showup only upto 3gb.
if you install 4gb or more then also it will not show up.
.........and second reason, may the ram that you are using are not identical or one of them is not working properly.
Check the specifications of the ram and also try using one a time.
Thanks and Regards
Jan 03, 2010 | HP Compaq 6720s Laptop
Upgrading My hp530 laptop
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
Sep 12, 2009 | HP Compaq 6720s Notebook
How much memory can this product of hp take i have cone some test and i think it should be up to 2gb per slots i have try to upgrade it to 4gb and fail i have even try 3gb and fail but it works with 3gb if...
If you are using the XP or Vista OS, if you are going to install more than 3 GB of Memory then it fails to show up on the computer properties.
Once you install the memory then you may check the BIOS for the memory installed in the system, the BIOS shows the exact amount of memory installed in the system.
You system is capable of 4 GB of RAM.
Sep 10, 2009 | HP Compaq 6720s Notebook
Upgrading memory to 4GB failure
try to see if that memory is supported with your motherboard. The memory has something to do with that problem.
Jun 16, 2009 | Acer Extensa 5620 Notebook PC
Toshiba Satellite A215-S7407 ram upgrade
Try to disconnect the new ram you just bought one at the time to see which one is defective. Also, 32 bit operating systems won't detect 4 Gb or ram, but they will show 3 Gb (even though they will use all 4 Gb). To resolve this issue, make sure that if you are using windows Vista to download the latest service pack 1.
Apr 03, 2009 | Toshiba Satellite A215-S7407 Notebook
SAMSUNG 1GB RAM 400MHZ PC3200
RAM has to be
Four 184-pin DDR DIMM sockets
Supports PC3200 (400 MHz) /PC2700 (333 MHz) / PC2100 (266 MHz) DDR DIMM type
Maximum HP/Compaq approved memory module is 1 GB
Maximum HP/Compaq approved memory is 4 GB
It has to be the same.
• If you are replacing a memory module, put the
new memory module in the same memory slot
from which the old memory was removed.
Or
• If you are adding a memory module, install the
new module into the socket nearest the
preinstalled module, and install additional
modules in the next available sockets
Jan 14, 2008 | Computers & Internet
HP Compaq 6720s Notebook Logo
272 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
