Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Bike won't start
97 Roadking, after riding the bike to work after a few hours won't start. It will crank and everything is on but won't start.
    Genius:
  • 2,028 Answers
Start by narrowing it down to fire or fuel problem. Pull a sparkplug, ground it to the head, and crank the engine. If there is no spark, then test the plug wires, coil, then ignition module in order down the line until you find where the power stops. If you have spark, then check the petcock to carb for fuel. If there is no fuel from the petcock, then it will be the petcock filter or the petcock is bad. If you do have fuel to the carb, but no to the cylinders, then the carb may need to be cleaned and/or rebuilt. Try these and let me know.
Posted on Aug 19, 2008
97 roadking wont go into gear and starter just spins'
The starter clutch needs to be replaced. An alternator sgop will usually rebuild these for 1/2 of a new one.
.A thumbs up would be greatly appreciated if this answer is helpful to you. 97-roadking-wont-go-into-gear-starter-4d5i0utctl2htkxwobhufr12-1-0.jpg
Mar 26, 2014 | 2000 Harley Davidson FLHR-FLHRI Road king
I have a 1999 Yamaha Roadstar 1600. I ride the bike for minutes or hours and the bike stops running. The bike has no electrical power and wont start leaving me stranded. If i wait a few hours the bike...
Check if the charging system works ok.
At idle with lights off, you should see 13.5-14.5V on battery's terminals and 0.5V less with high beams on, at idle speed as well as at 4000rpm.
Use a fresh good verified battery to take the readings.
Oct 15, 2012 | Yamaha Motorcycles
When riding in 5th gear starting losing cylinders. and bike dies? then bike won't start electrical start. can' roll bump start bike if i let sit for an hour. thn bike dies quickly. is my m
More likely to be your ignition coils. They heat up and expand this can cause an open circuit which will close up again when it has cooled down. Although, a bad charging system may cause this problem. Check the battery voltage with engine switched off ( approx 12 volts) and with the engine running (approx 14 volts) If you are getting 14 volts then your battery is dead, if you aren't, then your charging system has a fault.
May 06, 2012 | Honda CB 750 Motorcycles
2000 gsxr600 when I'm riding when I hit the
bike will not start or stay running on a full charge battery/bought brand new battery, still same promblem,jump bike off,will crank ,ride bike for 30 min. park bike, leave bike...
Apr 02, 2012 | 2000 Suzuki GSX-R 600
I have a 883 harley davidson sporster, was riding the bike and road over a bump and bike shut down and won't start
I'd check the battery first. I've seen the post break loose from the batteries in many Sportsters and leave them dead on the road. I've only seen this happen once on a Big Twin. Why? I have no idea. If nothing on the bike works, this may be the problem. If everything else works but it just won't start, I need more information. Does the starter engage and the engine turn over?
Steve
Aug 13, 2011 | 2000 Harley Davidson XL Sportster 883
Bike started sputtering espeacially when cold after sitting thru the winter Would like to know how to change the fuel filter to see if thats the problem
Most likely the problem is not the fuel filter. Since the bike sat through the winter, it is probably fuel gummed ports/jets. This is happening more often especially with the ethanol blend of fuel. In the last few weeks, as riders bring their bikes out of winter storage, there has ben many with the same problem as yours. I recommend pouring at least 1/2 can of SeaFoam in the tank, lock down the front brake and rock the bike back and forth to mix the additive. Once it is mixed, crank the engine and run at high idle for a couple minutes. Let it set for an hour or so to give the SeaFoam time to work. Crank the bike, and ride normally. It should clear up. If it doesn't clear up in an hour or two, you may have water in the carb bowl that will have to be drained.
Apr 23, 2011 | 2005 Harley Davidson FLHR - FLHRI Road...
I have a 2004 kx250f. The first ride of the year I noticed my bike bogged in the air and a little when I landed. When I get on the gas hard I dont feel it. Whats going on?
If the bike sat up for the winter, it's a real possibility the carb jets and fuel passages are gummed up. If this is the case, I recommend 1/4 to 1/2 can of SeaFoam added to your fuel. Lock down the front brake and rock the bike back and forth to mix the additive with the gas. Crank the bike and run at high idle for a few minutes, and since it is rideable, ride like you normally do and see if it gets more responsive after an hour or so.
Apr 15, 2011 | kawasaki KX 250 F Motorcycles
CHARGE BATTERY, THEN START BIKE UP. AFTER RIDING
Sounds like you are not getting a charge from the alternator. You need to check battery voltage with a meter with the engine off, key off. Then again with it running, and the voltage should increase. If not, it's not charging.
Jan 26, 2010 | 1999 Honda GL 1500 SE Gold Wing
Bike won't start and head light won't come on
Battery probably! did it push start? because if it did,,,, you should continue to ride it for awhile to recharge the battery.... that is if the voltage regulator is working o.k. check battery voltage, if its only 12v the regulator is probably going out.
Sep 11, 2009 | 1997 Honda F6 C Valkyrie
Lands Phones Logo
263 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
