Problem vith lap-top
Several things you need to check before replacing actual parts.
First, check the connection to the inverter for the lcd. Sometimes the connection can become loose causing a blank lcd but the motherboard is working fine. Next would be to actually replace the inverter if only the lcd does not power on at all. Even if lcd is blank you can see that the lcd is on but no picture in which case your video card could have failed and in many cases requires changing the motherboard because video is integrated into the board. Good luck.
yes thanks, but when I suces turn on my lap-top he work properly
    Problem Solver:
  • 58 Answers
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
29
Posted on Jul 26, 2009
SOURCE:
Why is my replaced lcd screen not lighting up?
1) Wrong LCD screen
2) Video Cable (LCD Cable) is not connected tightly.
Motherboard side, or LCD screen side; or both.
3) IF, a screen Inverter is used, the small cable from the Video Cable, that connects to the screen Inverter; is not connected, or has a loose connection to it. (screen Inverter)
4) An LCD screen, and a screen Inverter are a Matched unit.
If it's the wrong LCD screen......................?
5) IF, a screen Inverter is used; the diagnosis was wrong, and the LCD screen was replaced.
90 PERCENT of the time, the fault is a bad screen Inverter.
A) Laptop's LCD screen uses a CCFL, (Or more than one), for a Backlight; the laptop uses a screen Inverter.
Diagnostic flowchart leads from Graphics Chipset, to Video Cable, to screen Inverter, THEN, LCD screen.
Expensive LCD screen was replaced, instead of the actual part that needed replacing;
Video Cable: $9 to $22
Screen Inverter: $9 to $22
LCD screen: $60 to $245
B) Laptop's LCD screen uses LED backlighting, and does NOT use a screen Inverter:
Diagnostic flowchart is;
A) Video Cable;
A Video Cable should have it's connections PHYSICALLY checked.
You have to try to push the connectors in tighter.
Visual inspection alone will NOT do.
Making sure the Video Cable connections are tight, and this does not fix the problem, then the Video Cable needs to be removed; and every wire in the Video Cable checked for Continuity with a multimeter set to OHM's. (1K)
Not feasible, then take the Video Cable down to the nearest small computer shop; and have the resident tech check it for Continuity.
Should only be a few bucks.
Or just replace the Video Cable.
(Parts changing I know, but...........?)
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or more than one), or a series of LED's.
(Light Emitting Diode)
A CCFL is a Cold Cathode Fluorescent Lamp. (Bulb)
Similar to Fluorescent lighting used in homes, and businesses; but on a MUCH smaller scale.
Average thickness is 2mm. That is a little large than 1/16th of an Inch.
Average thickness is almost as long, as the LCD screen is in height.
View the last 8 photos,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
A screen Inverter is used to convert the power, (Electricity), from the laptop; for the LCD screen, and Backlight.
As previously stated, Backlighting that uses CCFL, uses a screen Inverter.
LED backlighting MAY, or MAY NOT use a screen Inverter.
When the LED backlight technology first came out, it seems some did use a screen Inverter.
It also seems as the technology advanced, LED backlighting does Not use a screen Inverter.
Regards,
joecoolvette
May 14, 2013 | Sony Computers & Internet
Lap top comes on but screen want come on it is a toshiba 5976
1.- Connect to external monitor thru VGA port.
2.- If show image, the failure can be LCD Screen, backlight or inverter board
3.- is more easy replace the backlight.
Sep 14, 2011 | Computers & Internet
Lap top screen blank
hi
try connect yr laptop to external monitor and see result. if display come that mean yr lcd or connection to yr lcd or inverter problems. but, if prpoblems still same, most likely yr problems is motherboard or display chipset
regards
Feb 19, 2011 | Toshiba Computers & Internet
Lap top can not start even button lights
do static discharge
disconnect battery and all peripherals. disconnect from mains. press power button and hold for 30 sec.
Connect to mains and try to turn on again
If it will not start - mainboard needs replacement
thanx
Sep 14, 2009 | Toshiba Satellite M40-S417TD Notebook
Lines on LCD
Once you see lines on the lcd that defitinely means the lcd is bad. As far as the board to the lcd, that would be behind it but with all the delicate tiny IC's on it, its would be near to impossible to troubleshoot it and start replacing components cause its done by machine and the legs of the IC's have match up perfectly with where your going to solder it into place. Inverter is good, when ineverters go bad its either you get a dim screen, weird colors, or even a white screen. My suggestion, definitely get a new lcd put in there since your getting lines in the lcd. Also your lcd cable could be flaky as well but those are cheap so getting one of those isn't a problem. Get those two things replaced and your laptop should work like new.
Jun 13, 2009 | Toshiba Portege M100 Notebook
I have a broken monitor. where do i buy a replacement acer notebook?
Visit eBay.com and do a search with the exact make and model. There are several listings, and several prices. The hard part is doing the actual replace. And... next time you need to hide the laptop don't sit on it!
Apr 15, 2009 | Acer Aspire 5050-3242 Notebook
Can i connect a presario v3500 laptop to an external momitor. @I think the display inverter is gone and i need to get some files off the lap top for work.
Yes, connect the external monitor to the port it corresponds on the laptop, usually the blue port. When you boot the computer hit the FN key located on the bottom right hand side of your keyboard and the LCD/CRT key i believe this will be the F4 key located on the top part of your keyboard this should activate the external monitor.
Tang
Feb 23, 2009 | IBM ThinkPad T23 2647 Notebook
Please help me agian
So, if your motherboard is turning on and the fan comes on than for now you can check to see if your back light turns on for your lcd panel by going to a dark place and turn ont he laptop there. Than check if you see a faint light that stays on or a flicker. If you see a faint light or the display is dim than it is the inverter on the lcd panel otherwise you may need to replace the video card which can be integrated onto the motherboard and may require a new motherboard. All depends on the model you have.
Aug 19, 2008 | Computers & Internet
I have problem agian
Aug 16, 2008 | Computers & Internet
Open Questions:
-\&;-OPTONLINE Customer Care Phone Number #{+ I8OO-828-O294 } AB .U.S.A This Optonline USA phone number is ranked #2 out of 2 because 7,728 Optonline USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Optonline USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Optonline USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Optonline USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Optonline USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Optonline USA Calling Optonline USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Optonline USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Optonline USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Optonline USA's phone numbers against each other. Contacting Optonline USA in General While I8OO8280294 is Optonline USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Optonline USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Optonline USA.
Oct 16, 2019 | Best Computers & Internet
-\&;-COMCAST Customer Care Phone Number #{+ I8OO-828-O294 } AB .U.S.A This Comcast USA phone number is ranked #2 out of 2 because 7,728 Comcast USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Comcast USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Comcast USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Comcast USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Comcast USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Comcast USA Calling Comcast USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Comcast USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Comcast USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Comcast USA's phone numbers against each other. Contacting Comcast USA in General While I8OO8280294 is Comcast USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Comcast USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Comcast USA.
Amazon Best pHoNe NUmber #{+1-85O-8I2-4OO9 how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere.
Oct 16, 2019 | Amazon Computers & Internet
Computers & Internet Logo
83 people viewed this question
Ekse
Alun Cox
