Question about Sansui COM0953 Combo
Analog/digital? Hi! Just wondering if this tv (Sansui COM0953/A) will be affected by the analog/digital switch. Thanks, Cheryl
  • Sansui Master
  • 520 Answers
Sorry it's not digital.
Posted on Oct 24, 2008
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
Jun 21, 2011 | Sansui VHF6010 VHS VCR
Trouble getting digital on a sansui 27"
your antenna is not strong enough to receive
digital or your in a area where large
structures are blocking the reception.
you could try turning the antenna slightly
and rescanning .
Jun 12, 2009 | Sansui DTV2760 27" TV
How to update digital channels correctly
the information I needed was in the FAQ's area. Thanks
Jun 05, 2009 | Sansui 19 in. LCD TV
Is it digital? will I need a converter box?
The conversion to digital affects off air reception. Since you have Comcast analog cable, you will not be affected until Comcast decides to discontinue analog cable, which is not likely any time soon.
When that day comes, your old VCR will probably grace a landfill anyhow, and you will need a converter box from Comcast.
May 13, 2009 | Mitsubishi HS-U446 VCR
Switching singnal
If you are using an antenna or regular cable without a cable box, put the tv on an analog channel. Go into the menu. Select the middle icon at the top of the screen. Go down to the TV/CABLE line. Select either TV (for antenna) or CABLE (for regular cable) on the right. Go down to AUTO CH MEMORY and press the volume+ (right arrow) button. Wait for the channel search screen to clear. Check all of your channels using the channel up button until you come back to the channel you started on.
Feb 28, 2009 | Sansui 27" TV
Sansui tv dtv2784
No this TV is not HD ready. However it is digital (ATSC) ready meaning now that most of the analog brodcasts have stopped it will receive the digital broadcasts so you don't need a converter box. Since it can only display 480i resolution it is not HD ready. You would need a TV that can display 720p or better to be considered HD ready.
Jan 04, 2009 | Sansui 27" TV
Wish to record on analog VCR and not affect digital TV reception
I don't think it will affect the digital TV reception, but if you try to use the VCR built-in tuner it is still analog and you won't be able to record digital channels that way. If your digital TV converter has video-out and audio-out connectors, then you can connect those to the corresponding connectors on your VCR to record.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Help for Sansui URC-3605 one for all remote control codes. Need T.V code.
try these codes 0000, 1479, 0479 - from our control booklet
Aug 12, 2008 | Televison & Video
Durabrand D41901
Are you wondering if this Durabrand TV is going to be ok in 2009 when Television goes all Digital?
This will not affect cable TV users only people trying to recieve TV over the AIR UHF/VHF will be digital signals now and will require a special tuner to recieve them.
Most durabrands have Analog/Digital tuners but they are analog TV's.
May 10, 2008 | Durabrand DWT1905 TV
Televison & Video Logo
89 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
