Need correct settings in setup
I can't seem to get cable to be recognized, what are correct settings in setup, and how do I get clear and erased from staying in settings?
ge tv model# 31gt660
I have the same problem only mine is with satalite. The TV doesn't seem to want to recognize it and I've tried all that I know in setup.
Posted on Nov 18, 2008
Pin nombel
Posted on Aug 21, 2008
Acer Aspire one 722 windows 7 netbook. "Check cable connection" and "no bootable device--insert boot disk and press any key" are two common things appearing. The computer recognized hardrive, hardr
Hello, it looks like somehow the master boot record was erased from the hard drive, maybe viral? You mentioned the hard drive was recognized in the bios correct? If you need data from the hard drive the easiest way would be to pull the hard drive out and use an external hard drive enclosure to remove the data before you erase everything from the hard drive. If you dont need anything thing you can proceed to do a new install of Windows 7. Turn the computer on then hold alt and the f10 key to perform a factory recovery. This will erase everything and reinstall Windows 7. If this doesnt work then you will need a new hard drive and a bootable usb drive with Windows 7 on it. Hope this helps.
Feb 22, 2013 | Computers & Internet
I have a compaq s5100nx desktop with a crashed 80 g ide hard drive.i am trying to replace it with a 500 g drive but the drive is not recognized by the bios i have tried 2 different drives already. However...
did you configured the Hard drive jumpers correctly?
Was the original HD set to master or Cable select?
if so please set your new hard drive to the same jumper settings as the old one.
Mar 19, 2011 | HP Compaq Presario S5100NX (DM172A#ABA) PC...
I inherited a Sharp LCD 32" flat screen TV that's only about 2.5 years old. It worked fine at its previous location. Upon bringing it to my house, I've tried disconnecting the cable from my TV &...
Try going into your setup menu. Look for a setting for "Cable/Air". Try switching it to Cable and then doing a channel search. If you are using a cable box try setting channel to 3 on tv. Those are the two easiest things I can think of off the top of my head without seeing it.
Jul 09, 2010 | Sharp LC-32SB21U 32 in. LCD TV
6U214 Motherboard Failure??
1. try clearing your bios setup using the jumper provided on your motherboard. make sure that the computer is shutdown and power cable unplugged before doing this. make the jumper settings and wait for 3 to 5 minutes before returning the jumper settings back to its normal position.to locate the bios clear jumper; it's always near the cmos battery of the mainboard. after doing so, plug back your power cable and power "on" your computer. select bios or cmos default settings when you are prompted. save your settings and restart your computer.
or
2. or try flashing your motherboard again using the latest bios file available for your board downloaded from dell website. and select to bios or cmos default settings when you are prompted. save your settings and restart your computer.
Jan 26, 2009 | Dell (6U214) Motherboard
How can i restore factory setting in motorola v3i without sim card
Master Reset
Reset all options except unlock code, security code, and lifetime timer:
Go into Settings > Initial Setup > Master Reset
Master Clear
Caution:
Master clear erases all information you have entered (including phonebook and datebook entries) and content you have downloaded (including photos and sounds) stored in your phone’s memory. After you erase the information, you can’t recover it. Clear all settings and entries you made except SIM card information, erase downloaded pictures and sound files, and
reset all options except unlock code, security code, and lifetime timer:
Go into Settings > Initial Setup > Master Clear
Jan 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Reset A1200
What exactly do you want to reset?
There is a master reset that resets all default phone settings
except for the lifetime timer:
  • Tap the button that looks like a square cut in fours.
  • Tap "Setup"
  • Tap "Master Reset"
There is also a Master clear that erases all information you have entered (including address book and calendar entries)
and content you have downloaded (including photos and sounds) stored in your phone’s memory. After you erase the information, you can’t recover it. It clears all settings and entries you made except SIM card information, erases downloaded pictures and sound files, and resets all options except for the lifetime timer:
  • Tap "Setup"
  • Tap "Master Clear"
What is the problem that you are trying to solve with the reset?
Jul 09, 2008 | Motorola Mobility A1200
We have an internet modem(connected w/an ethernet cable) that also includes a phone line which also connects to a fax machine. We only have one phone number and we were told if we put our fax on auto...
Most fax machines do not operate well on digital lines.
Contact your provider and see what fixes they have for your specific fax machine.
Most fax machines still require an analogue line.
May 02, 2008 | Office Equipment & Supplies
Channel Setup
it's saying that because the antenna is hooked into the same thing, the coaxle jack. It shouldn't memorize any chanells that don't come in on the antenna. It's been a long time since I had mine hooked to an antenna but I know it'll work if you let it go through the auto setup. If need be unplug the unit for like two minutes so it's memory is erased and then fo form there. I hope this helps
Jan 02, 2008 | Emerson EWD2202 DVD Player/VCR
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
