Most likely it will be the ignitor,even though it glows it doesn't mean the ignitor is good.it works on amps.a flat ignitor takes 3.2 amps to open the gas valve and a round ignitor takes 2.5 amps to open the valve,the only way to check it is to replace it and i would or if you have an amp meter with a clamp on it you just stick one of the wires going to the ignitor inside the clamp and it will tell you how many amps are coming out of the ignitor.buy a new ignitor and you should be fine.it calls for ignitor part number 31940001 and it's around 50 dollars.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Calendar April 2018
good
