Question about Epson TM-T88III Thermal Printer
Can't install epson tm-t88iii serial
Can't intall my epson tm-t88iii serial
i use a rs232 null modem cable
i traing ATM_302E driver from epson and not working
i traing an erlyer version for a Tm-t88ii and not working
i using windows xp sp2
i run a self test and works good, but i cant print a test page from windows
any ideas?
  • 1 more comment
  • Anonymous Oct 08, 2008
    No drivers for VISTA, WIN XP and lover only
  • Anonymous Dec 15, 2008
    can't install
  • Anonymous Mar 21, 2014
    hej
Unistall the epson driver.
reboot your system.
connect and turn on the printer.
reinstall the driver, v3.02, selecting for create a serial port.
choose the right setting os serial interface.
after install, reboot your system.
it works to me.
Posted on Sep 02, 2008
How I can transfer my files from a Acterna 5100E OTDR to my laptop? It only has a standard internal flash drive and 9 pin output. I have the original software.
This devices interface is extremely old technology the 9 pin connector is most likely a rs232 serial interface . If your laptop has a 9 pin rs232 interface you may need a DTE to DCE adapter .
if you do not have this old rs232 port on your laptop I think this device a usb to null modem rs232 DB9 Serial DCS Adapter Cable with FTDI.
http://www.startech.com/au/Cards-Adapters/Serial-Cards-Adapters/USB-to-Null-Modem-RS232-DB9-Serial-Adapter-Cable-DCE-FTDI~ICUSB232FTN
https://en.wikipedia.org/wiki/Null_modem
from my reading of the manual a null modem may be needed
Nov 16, 2015 | Cell Phones
Epson TM T88iii printer not printing
Since you are using the USB-to-serial converter, you need to select the serial interface in the printer driver installation.
  1. Uninstall the driver in Control Panel > Add or remove programs
  2. Restart the computer
  3. Install the printer driver again, this time select serial in the interface list
  4. Set the properties for the serial port to 9600 for the data rate
  5. Print a test page!
Sep 07, 2017 | Epson TM-T88III Thermal Printer
I have a Epson TM-T88III as a networked receipt printer, we have a new machine that has windows 7 and I can not get a driver to install that works. Any suggestions?
Dear Clark, it seems you have a lot of money when you suggest to waste a printer 240€ value.
The solution:
Link www.epson-pos.com and register, after that, follow this path:
Thermal line printers
Choose your model
Epson Advanced Printer Driver for TM Series (the first option for Windows7)
Install it, it Works properly.
Jun 29, 2010 | Epson TM-T88III (C420863)
I have an Epson tm-t8iii receipt printer and have been trying to get it connected to my computer with no luck. I have downloaded the advanced printer driver but it still won't work. I have a RS232 port on...
I had the same problem. The issue is that you have to use a "Null Modem Cable" to get it to communicate with the computer. The serial cables that Staples carries have a different configuration than a Null Modem Cable. I bought mine on eBay. Hope this helps.
P.S. - You may continue to have problems after you replace the cable. If you do, just change the port speed setting in the computer to 9600 in the Printer Properties dialogue under the Ports tab.
Aug 23, 2009 | Epson TM-T88III Thermal Printer
Do not suceed to print with usb-to-serial cable
use a null cable and is ok.
Diego.
compuzonic.com
Jan 18, 2009 | Epson TM-T88III (C420863)
Epson TM-T88III - Always showing as not avaliable
I had the same with XP .... I had my home inkjet (Parallel port) on LPT1. The Epson TM software and printer worked fine after removing the ink jet from LPT1 and re-installing the TM driver.
May 08, 2008 | Epson TM-T88III Thermal Printer
How can I connect an Epson TM U220D Printer to a PC?
You can connect it using a SERIAL NULL MODEM cable, You can download the driver from epsonexpert.com after you register they will send you username and password to login, go to technical resources and select printer model and download the APD304E driver
May 02, 2008 | Epson TM U220D Printer
VeriFone Tranz 330 Printer Cable to Epson TM-T88iii Printer
Absolutely not. The Tranz 330 port is an RS232 serial port.
Mar 12, 2008 | Televison & Video
Epson TM-T88III Thermal Printer Logo
4,798 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
