Question about PC Chips MB PCCHIPS M863G V5.1C w/XP2400+ Motherboard
Upgrading to 2 GB Memory - only one DIMM recognized?
I have installed two identical Kingston 1GB DDR400 memory modules in my M863G (v5.1c) mobo. System only recognizes one of them thus I'm only getting 1 GB.
Others have suggested a BIOS upgrade may fix the problem but I can't find anything specific to this version (i.e. v5.1c is specifically indicated on the PCB - the "c" is actually a sticker!),
Might it simply be that the DDRs I'm trying to use are too fast (DDR400 vs. DDR333)?
  • GIJon Aug 20, 2008
    Yes, I'm booting into BIOS setup everytime I've tried something new with this memory. The DDR400 modules are PC3200s (CL-3) so I also thought that I might need to crank up the CAS latency to 3T but this had no apparent effect. The BIOS/boot screen I get shows only the first DDR1 slot as being detected, even though both slots are occupied. I already had the other slot checked out at a local computer shop to make sure there wasn't a problem there.
    Problem Solver:
  • 5 Answers
I am using the PCCHIPS M863G v1.5a with 2 identical Kingston 1GB DDR400 memory modules and they are working fine. I also have another system with a PCCHIPS M863G v 5.1A motherboard and I will test the 2 Kingston modules to see If theyare both detected properly. Do both modules have the same chips on them. Many times the same manufacturer can use different brand chips on each module and that can sometimes cause an incompatibility between the 2. Maybe one of the modules Is bad.Test one at a time and switchem out.
Posted on Sep 25, 2008
  • 3,051 Answers
Have you booted your computer into bios and see what it tells you there
Posted on Aug 20, 2008
Memory support
  1. 2 DIMM memory slots (supports up to 2GB memory)
  2. Supports 1.8V DDR DIMM
  3. Supports DDR2 533/400 DIMM
Note2: Use of a Double-Sided memory module (the single chip is 512 Mbit) is required if you wish to install a 1 GB memory module
Only supports one gig per slot...
Mar 21, 2012 | Gigabyte GA-8VM800PMD-775 Motherboard
Hi everybody, I have a problem installing a dimm SDRAM Module on a MoBo Syntax SVX 400. User Manual says that till 4GB modules are supported. I bought a Transcend 1GB PC266 SDRAM module to increase the...
One long beep signals a memory failure - the stick you just bought is faulty. BTW there is no PC266 in SDRAM the maximum is PC133. PC266 is the first standard that appeared for DDRAM. so you most likely have bought something not right from the start.
Feb 07, 2011 | Syntax SVX400 (SYSVX400) Motherboard
2G RAM's for Elitegroup (ECS) L7VMM2 Rev 1.0A Motherboard
You're board can handel; DDR SDRAM up to 200 or 266MHz DDR SDRAM memory module. Accommodates two "unbuffered", 2.5V 184-pin slots. Each slot supports up to 1 GB with a total maximum capacity of 2 GB. Return the Kingston memory you have installed if it is less than a year old. They should allow you to trade up to the MB's supported memory.
Two reach the MB's max memmory of 2GB. Buy two Kingston DIMMS of, "unbuffered", 2.5V 184-pin
DIMMs. Here is one site that sells Kingston memory;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=235786&CatId=548
The next link is Kingstons site; http://www.ec.kingston.com/ecom/configurator_new/PartsInfo.asp?root=us&LinkBack=http://www.kingston.com&ktcpartno=KVR266X64C2/1G
Here is another site; http://www.buy.com/prod/kingston-1gb-ddr-memory-pc2100-266mhz-184-pin-dimm-kingston-1gb-ddr/q/loc/101/10348796.html
If you decide to search for you're self, use this as the basis for the correct model: Module - KVR266X64C2
Link to ECS web site; http://www.ecsusa.com/ECSWebSite/Product/Product_Detail.aspx?DetailID=62&CategoryID=1&MenuID=50&LanID=9
Mike
Jun 02, 2010 | EliteGroup L7VMM2 (L7VMM2 NO CARD READER)...
775i65G does not work when two 1GB DDR400 are installed.
I would venture to say one of the memory modules you have is bad..
Jan 25, 2009 | Asrock 775i65G Motherboard
Upgrade ECS FSB800 memory from 1 GB to 2 GB wont work
This board will support up to 2gb as shown below extacted from the website product page.Don't forget that if you have ddr 333 memory installed originally, you can only add the same clock speed memory, i.e. ddr 333. If you add ddr333 and ddr400 you will have problems as the clock speeds do not match. If you are matching clock speeds, the try bootin the system with the new piece of memory on its own to see if there is a problem with that stick, trial an error of both sticks individually, will give a positive result
MEMORY ecs_buttom_03.gif Single-channel DDR memory architecture ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333 DDR SDRAM
Nov 02, 2008 | EliteGroup ECS P4M800-M Socket...
2 x 1GB Samsung PC2100 appearing as just 1GB (2 X 512MB)
Hi Patrick,
I see you're point. I know this, you can not run "more than" 512MB in any DIMM slot. That is shown at the bottom of page 10 & the top of page 11. You can not run both types of memory at the same time, even though the chart looks like you could. The description term on page 10, states; Users only can install either 168-pin SDRAM Module or 184-pin DDR DRAM Module at one time. (You can't run both). You can run 4x512MB in all banks using184-pin DDR SDRAM. Or you can run 4x512MB in all banks of 168-pin SDRAMs. Total of 2GB.
So you can not run 1GB of memory in any bank.
Mike
Jun 29, 2008 | Jetway V266B Motherboard
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
K7VT4A-Pro Mobo
Greetings,
The motherboard will read 1GB DDR400 memory per slot only.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Asrock K7VT4A-Pro Motherboard
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Computers & Internet Logo
216 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
