Question about LG CHOCOLATE VX8500 Cellular Phone
Slider has seperated
Is there a way for me to reconnect the face portion of the phone back to the base? The phone still works completely, but it is just in two pieces. Bring it to the tech counter at verizon, or can I don something myself?
  • 31 Answers
If the actual sliding mechanism has broken, then the phone most likely needs replacement or a trip to the manufacturer. If you have insurance on your phone, Verizon will cover it. Even if you don't have insurance, take it to the nearest Verizon shop.
Posted on Aug 20, 2008
How do i turn light on or off
If you're referring to your display brightness, you can control this in your Settings. Use the Settings App and Open the Brightness &Wallpaper menu. Select the brightness level on the slider and flip to auto-brightness if you like. This will adjust brightness based on ambient lighting detected by your front-facing camera. If that's causing you problems, disable the auto-brightness and just control it manually from the slider.
Mar 29, 2014 | Apple iPhone Cell Phones
N95 slider problem . LCD goes blank on sliding . it appears that there is problem in Strip. do u get separate strip or it comes alongwith slider....
No the Slider strip doesn't come separately because the strip is merged permanently to a circuit that has your earpiece ,light sensor,and front camera you cannot seperate it in any manner because the only unlockable part over there is the LCD screen .i would recommend you to get your phone serviced from nokia care only because the strip is the most important part in a slider .. even if you get a local strip installed from a local mobile repair center it wont last for a month ..even i had the same problem 4 months back ..because quality of the strip matters .......
Dec 28, 2010 | Nokia N95 Cellular Phone
Slider sticks
had this happen on my samsung impression press together the front and back portion of the phone to see if the case became misaligned. You should have 8 corners to ensure are snug. If that does not work you might have a broken spring.
Jan 02, 2010 | Samsung Propel A767 Cell Phone
Load default Delta file message
Problem My handset displays either LOAD DELTA FILE or LOAD DEFAULT DELTA FILE. What should I do?
Solution(s) Tip 1 of 2
If the handset is not responding normally, you may need to reset your telephone system. Complete the following steps to reset the telephone system:
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
Nov 16, 2009 | AT&T 650530003417 Cordless Phone
I just want to completely disassemble my phone. how do i do it?
Start by removing the battery and the four small Phillips-head screws around the battery. Next, remove the plate on the back of the phone, below the battery panel. The panel is stuck in place with sticky foam and might be hard to peel off. Then remove the two small phillips-head screws. Next use a tiny (glass repair kit) flat-head screwdriver to pry the two halves of the base apart at the seam.
This is where it gets tricky. Gently take each piece off one-by-one. But to separate the screen you have to slide it half way and hold it in place while you unplug the ribbon cable from the circuit board in the base of the phone. Then disconnect the arm from the slider and slide the phone open to remove the two screws behind the silver stickers on either side of the camera "shutter". Now pry the slider housing apart as with the base.
Oct 21, 2009 | Samsung SPH-m520 Cell Phone
One side of my slider came off it's track
take to the shop an get sliding key cover fixed
Sep 03, 2009 | Samsung SGH-E900 Cellular Phone
No link to base
This may help. It's from the Panasonic help page:
You may try to:
Disconnect AC power adapter from the back/bottom of base unit, then connect it again properly.
spacer.gif OR, to resolve this issue, you have to re-register the handset.
  • To do this on a non-expandable cordless phone:
    Press and hold the LOCATOR/INTERCOM button on the Base until a beep sounds.
    Press and hold the FLASH/CALL WAIT button on the Handset until a beep is heard.
    When registration is complete, a beep sounds from the handset.
    Wait for 20 seconds after registration is complete to allow the handset to establish communications with the base.
    If this fails to help:
    Remove the AC Adapter from the phone base or wall outlet for a few seconds and reconnect. It may also be necessary to remove the battery from the handset for a brief moment.
  • To do this on a expandable cordless phone system:
    Press and hold the LOCATOR/INTERCOM button for the extension that is displaying "No Link To Base" on the Base until a beep sounds.
    Press and hold the FLASH/CALL WAIT button on the Handset that is displaying "No Link To Base" until a beep is heard.
    Remove the AC Adapter from the base or wall outlet for a few seconds and reconnect. It may also be necessary to remove the battery from the handset for a brief moment.
Jun 24, 2009 | Panasonic KXTG5632BP Twin Cordless Phone
How do I remove the LCD screen from a Samsung Blast?
you must take the back cover of and remove the six screws to access the lower portion of the phone. Once you've done this remove the qwerty keypad. When you slide the phone back down you should see the back of the slider and two additional screws. Good luck.
Feb 25, 2009 | Samsung SGH-D600 Cellular Phone
Searching....
The problem of searching.....
After trying all the technician's suggestions had failed; I disconnected the base to return it to the store for replacement. Then I decided to try disconnecting and reconnecting power and phone line, placed handset back on base and the phone reset itself and is working fine...
Recap:
Disconnect power and phone line from base for about 30 seconds and reconnect both power and phone line to base and place handset back on base; it should reset...
Linda
May 05, 2008 | Uniden DECT 6.0 Cordless Telephone...
Faceplate
Found this on Howard Forums. Sorry no photos.
CHANGING HOUSING/FACEPLATE:
Take off your battery, unscrew the screws on the back of the phone with a T6 screw driver.
Pry off the back plate,lift up circuit board gently(be mindful of flex cable) remove the flex cable from mail board by lifting brown part by the connector,
Unscrew then next 2 set of screws(be careful of flex cable!) remove the LCD board from the faceplate.
Now put the LCD Panel into the new faceplate. Find the new back slide and put your sliding rails on.(you may also put the slide magnets on from the old housing) carefully thread your flex cable through the opening.
Snap the Back slider on and then screw in the screws, then take the keypad housing and screw it into the slide rails.
Reconnect the flex cable by putting the brown hatch up(gently with finger nail) gently feeding the cable into the connector until the white line is about to the end of the connector.
Then put the brown thing down and apply little pressure.
Put the mail circuit board back into the phone with the headset jack going in first.
Then snap it back into place.
Transfer your speaker over the the new back housing with the prongs facing up.
Then screw on the back housing.
Replace battery and your DONE!!!
Best of Luck.
Please RATE my solution BELOW.
Nov 25, 2007 | Kyocera Slider Remix KX5 / Sonic Cellular...
LG CHOCOLATE VX8500 Cellular Phone Logo
59 people viewed this question
Top LG Cell Phones Experts
IT Solution
IT Solution
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
