Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Problems with connecting my ps3 to my sony bravia KLV-32S400A
When I connenct my PS3 trough the HDMI cable to my tv the picture comes in off color and distored. Mainly where the screen is black. It does it both with Blu-ray and games. I have tried changing thesetting on the tv and PS3. I have also used the default setting on both. My friend has the same setup and have tried all the setting he has on the the tv and PS3. I have also tried a different HDMI cable. I have also tried all 3 HDMI hook ups. When I hook up through the cable that comes with the PS3 it worked fine. There is like a green tint to the screen and you can see the pixles. I am out of ideas.
SOURCE:
  • 18 Answers
SOURCE: Games run on hdmi, but not Blu-ray movies
You most likely have the updated drivers. You may have to go and change a setting. I found an answer on the PS3 website that may be of some use to you. I hope this helps you: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1662191 From the site: "go to bd/dvd setting and set the "108024hz" option off"
Posted on Aug 19, 2007
SOURCE: Ps3 not playing blu ray on my samsung LCD
Change the frame rate on your tv to 60hd, that should solve it. Basically, your tv might be set to theater mode which is playing 24hd..
Posted on Jan 02, 2009
leme
  • 25 Answers
SOURCE: PS3 will not display on TV
WHEN YOU START YOUR PS 3, KEEP YOUR FINGER ON THE START BUTTON UNTIL YOU EAR A SECOND BEEP ( BETWEEN 5 & 10 SECONDS); THIS WILL RESET AND SELECT THE RIGHT CONNECTION . I HAD TO FIND THIS PROBLEM WHEN WE WERE SWITCHING FROM THE LIVING ROOM TO MY KID'S ROOM.
LET ME KNOW, HAPPY NEW YEAR.
PIERRE ( MONTREAL)
  • 44 Answers
SOURCE: PS3 No signal to the TV
To solve this, when the ps3 is in standby (solid red light), just hold the power button. It should beep on, then beep again in about 5 seconds. This will automatically search for the optimal audio video output. if if beeps on then turns off, just try again, it takes 1 or 2 tries sometimes. the reason this is happening is because your ps3 is set to one AV output, ex. composite(red yellow white), HDMI, and then you changed the cable to a different one. another way to fix it is plug both cables, HDMI and composite, into the tv and ps3, then go to settings and change the output to the desired one.
Posted on Jun 02, 2009
  • 317 Answers
SOURCE: PS3 WILL play games but NOT Blu-ray or regular DVDs
hold the power button down when it is red till you hear the quick beeps then select the file restore. this is a diagnostics screen...you may have to hold the power button in for several seconds....does your ps3 work on a non hidef tv?
Posted on Nov 03, 2009
Testimonial: "Thanks, restoring the original settings worked. A picture will only display up to a resolution of 1080i, not 1080p."
Hi. Please help. I'm using sony Bravia klv-s3210,
Change the resolution for the picture to match the resolution from the PS3. It probably will never work as VGA does not support HDMI resolution.
Jul 25, 2017 | Televison & Video
Sony Bravia Klv-32s400a Im looking for this parts Parts No A1527471G I do have this part on sale.
Tries websites like Shopjimmy.com,Ebay.com to buy refurbishes Sony LCD tvs PCB boards.These two websites have very extensive Sony LCD tvs PCB boards.
Apr 16, 2011 | Sony KLV32S400A 32 in. LCD TV
I have a sony bravia lcd tv of 32 inches bearing the model numner KLV- 32S400A.. the prob is the pictures colour is turning into a negative image after 10 mins of switching on the tv. could you pls let me...
This seems like a T-con board problem as its responsible for several picture functions including color convergence. Or it could be a bad LVDS cable (inside the TV) I can ship you a new T-caon board for $150.00 or take it too your local shop repair shouldn't cost more than $250.00....
http://tvtechwork.webs.com/
Oct 18, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
8 blinks from a sony bravia model klv-32s400a tv
8 blinks in KLV-32S400A shows Audio Error
Check audio voltage supply from power supply board, if OK, replace GP Board (main board)
and if audio volts are not available, check/ replace power supply board.
Feb 09, 2010 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
PS3 to sony bravia
If you have an HDMI cable hooked up to the PS3 and the TV, you have to set the TV to the HDMI channel.
Oct 26, 2008 | Philips 19PFL5622D/37 19 in. LCD...
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Bravia KLV-S40A10 HDMI input
I agree with your solution and you are correct in that you lose very little quality by using component instead of HDMI. there are A/V receivers that transcode HDMI inputs to component; as far as I know that's the only other option
Dec 25, 2007 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
HDMI into sony bravia
plug in hdmi cable turn ps3 off then on wait and a message will apera click yes then another message appers then click yes then it should work if not connect with the red white yellow plug and then change the settings to hdmi and plug the hdmi cable in
Sep 06, 2007 | Sony Playstation 3 (PS3) Console
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
203 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
