Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Thank you Hello Many thanks for answering my querry! I have managed to read the error it seems to have. It starts with BAD_POOL_CALLER and techincal info is: ***STOP:0x000000C2 (0x00000043, 0xD9564000, 0x00000000, 0x00000000) It also says If problem continues disable or remove any newly installed h/ware or s/ware (havent installed any) Disable BIOS memory options such as cachingor shadowing. If you need to use safe mode to remove or disable components, restart comp, Press F8 to select adanced startup options and then select Safe Mode. (like you said but nothing happens) HELP if you can as I am at a loss now! I havent installed any h/ware or s/ware - only listened to a radio station through it last night and I go on Second Life - but been on Second Life since January 08.
  • 477 Answers
Hi
Ok one thing you should download and run is http://www.memtest86.com/ to test the Ram Memory.
to fix the startup problem you need a windows XP CD thats the only solution I got for the moment.
boot witch winxp cd. wait until a welcome to setup messages appear.
press R for console.
write in that window when C:\> appears "chkdsk /R" let that run and your problem should be solved.
good luck
Posted on Aug 20, 2008
SOURCE:
My 1.0 Sta-rite Dura Glass pool pump will not start
could be a simple fix, take the motor down to your local pool pump motor repair shop that has free testing. it might be a bad thermal protector or a dirty start switch
always check for power first, could be bad breaker or bad or dirty timer contacts..jay
Oct 21, 2012 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Battery is not charging. Test of electrical system seems to show a problem with voltage regulator. Where is it located?
Hello pkbanta: My name is Roger and I will help with your answer. The voltage regulator is located on the back of the alternator. You must remove the alternator in order to replace the regulator. I would have the alternator tested before just replacing the voltage regulator. If the brushes are bad you could receive the same reading of a bad regulator. Should you need further help please just ask. Please rate the answer. Thank You for using Fox Ya. Roger
Jun 24, 2011 | 1998 Ford Windstar
Hayward Heater Problem ''AO'' error. H400IDH
Thank you for posting your question here on Fixya.com.
It sounds as if the air activated switch the tube you mention attaches to is not working. Pull the two wires from it and connect them to simulate the switch closing. Start up the heater to see if you get ignition. If so, replace the switch.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Feb 14, 2010 | Hayward H Series Pool & Spa Heater 400k...
Compal fl92 notebook will not POST. DVD/cd rom works, lights come on power button and hdd starts, cpu fan spins then nothing happens from there. before this i had checksum errors,memory management...
well try to remove the RAM from its sockets and clean up the contact area of the RAM using eraser and repalace it and try to reboot it.
Good Luck.
Jan 07, 2010 | Computers & Internet
How do I turn off the talking caller ID?
I finally figured out how to turn off the talking caller ID by carefully reading the instruction booklet and checking on line with Panasonic to get further information.
Please remove our name and e-mail address from your records.
Thank you for your messages. It's good to know that there is someone out there to help with such problems.
Ruth Lappin
Dec 17, 2009 | Panasonic Lands Phones
My acer aspire 5310 gives blue death screen (Bad pool caller) plus it does not detect the hard drive
If you are getting a blue screen in your Windows operating system that says something about a bad pool caller, you are in for a tough ride. The bad pool caller error means that some piece of software somewhere on your computer has done something wrong. For this reason it is important to write down the error codes that you receive with this message to help in determining what exactly is going on.If you have successfully been able to record these error codes in some way and have access to a computer that is working, the best place to start is on the Microsoft website. Once you get to their website, try entering the error codes that you have written down to see if they can give you more detailed information about the software that is causing the problem and any possible solutions to correct the issue.If you have not been able to find a solution to your bad pool caller error using the above method, then there are a few things that you can try. Often a hardware device can also cause problems that result in the bad pool caller error message, especially USB devices. Start by removing all of your peripherals including printers, scanners, external modems, USB hubs, etc. if you do not receive the error message once you have done this, then add one device back at a time, until you find the source of your problem. If this works and you know what device was causing the issue, you can try reinstalling the software for that device or replacing the USB cable that is connected to that device to see if that will solve the problem. If the problem still persists, it would be a good idea to run MemTest86, which can be downloaded online, to test your RAM for errors. A bad hard drive can also result in bad pool caller messages.If you have recently purchased your computer or have warranty on your computer, perhaps the easiest way to deal with this difficult problem is to take it back to them. Because of the nature of a bad pool caller message, which can be caused by almost anything, it is easier to have them deal with it rather than trying to isolate and correct the issue on your own.If you have built your own computer or are working on an older computer that no longer has a warranty, then you may also be able to get some clues into what is causing the problem by looking through the Windows Event Viewer for error messages or information. If you do not know how to do this, then a quick search online will explain how things are logged in the Event Viewer and how to interpret the information provided.Finally if all else fails and you are sure the problem is not related to a peripheral or other hardware device, then you can reload the Windows operating system on your computer. This can be done without losing your personal data and files, but be sure that you perform a complete backup before attempting this step just in case. There are the odd situations in which a bad pool caller error will occur during the installation of Windows in which case you will need to try and completely reformat your hard drive and start from scratch.
Apr 20, 2009 | Microsoft Windows 2000 Professional for PC
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
130 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
