Question about Nintendo DS Console
DS repair I have a problem with my ds because when you turn it on the top screen appears with a kind of a ball a hole I don't how you call it but if you know how to fix it please tell me
  • n1n10doh ds Sep 13, 2008
    when I turn on my ds the top screen is half broken and when i turn it on the screen is all white
  • Anonymous Feb 09, 2009
    my top sceen is
No i dont know because my daugthers fell in the toilet and it want come on and im trying to fix it.
Posted on Aug 30, 2008
I recieved my ds lite from a friend he had it for years and when i got it the top screen was dangling by the copper ribbon. I had for like 3 weeks and then my cat knocked it off a dresser and the top...
Hello there! i think your nintendo ds still can't be fixed ....you can fix it yourself if you have some soldering skills but if you don't then you can hand your nintendo ds lite in to the professionals to work on at the nintendo repair shop
Sep 25, 2011 | Nintendo DS Lite Console
When i turn on my DS the top screen is blank then it turns white and stays like that, i don;t know what's wrong
what normally happens is the conection from bottom to top becomes worn, is kinda no repairable happens to them if they are old. if u open close it a few times does it blink or change ? if so you know for sure its the conection gone.
Nov 28, 2009 | Nintendo DS Lite Console
If your booting to a GBA game, there us a setting in the machine BIOS to tells it to use the top or bottom screen. You can access it by taking out the games and booting the unit.
If your booting a DS game, it should display on both. If not, it is possible a wire has come loose on the display (or the screen went bad).
You can try and check for the wire yourself or take it to a repair shop. If you bought it recently call Nintendo.
Nov 01, 2009 | Nintendo DS Lite Console
Damage on the back of my ds
Your cable is destroyed. It will have to be repaired. Look online for VIDEOS on how to replace the top lcd. It requires rolling of the top lcd to fit into a small hole and I've torn a number of those my first time. Good thing it wasn't my money I was spending ;)
Look on Amazon and you can get top lcds for under $20.00!
Any more questions, good luck
May 29, 2009 | Nintendo DS Lite
My original nintendo DS has little white lines in the top screen!
Well, if the lines stay on the screen even when the DS is turned off, it means the LCD screen is broken, thus the crystals are flowing and blotching. This means the screen must be repaired, however you don't have to buy a new one.
Nintendo has a page about original DS repairs Here. They also offer certain warranties, I'd see if one applies to your situation. (They also have a more broad repair page Here.)
If you feel like doing the repair yourself, it is apparently very easy and costs about $40 to replace the screen. There are many different repair tutorials online. (I just did a Google search for "DS top screen repairs") Here is one of those sites.
I hope this was of assistance.
May 02, 2009 | Nintendo DS Lite Console
Discoloration on Nintendo DS screen
It might be able to be repaired but the reason that happened was because of a magnet or from him pressing really hard down on the screen
Apr 29, 2009 | Nintendo DS Lite Console
Nintendo ds lite top screen has lines
sounds like possibly the ribbon, should get it checked incase it dies for good.
Apr 06, 2009 | Nintendo DS Lite Console
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from http://wiinewz.com/forums/nds-general-discussion/72805-ds-top-screen-white-blank.html this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
DS Lite Turns off when moving top screen.
ITS AN INTERMITTENT CONTACT with the ribbon belt that connects from the main unit to the upper screen , I believe you need to take the DS for an authorized repair shop, but before doing anything , give a call to a tech support at NINTENDO , THEY would gladly help you out and inform you whats the next step , hope this helps , AJ , in case you dont have the LINK, let me give it to you : http://www.nintendo.com/consumer/ ,
hope this helps AJ
May 10, 2008 | Nintendo DS Lite Console
Top Screen has turned white
It can be repaired but you need to take it apart with a triwing screwdriver and need to get a new screeen. http://store.videogamecentral.com/ds-top-lcd.html
May 03, 2008 | Nintendo DS Console
Nintendo DS Console Logo
55 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
