Question about Canon DR-3080CII Path-Through Flatbed Scanner
I have a Canon DR-3080CII scanner that is making a lot of noise.
We have had the scanner for over a year and no parts have been replaced and the scanner is used daily. Do you think the rollers need replaced and is this something that we can do? Also, where can I purchase the rollers?
Thank you.
Bonnie Gillen
Cleveland Brothers Equipment
Phone: 724-325-9312
Email: [email protected]
  • 32 Answers
If you haven't had problems then they are probably fine. The feed rollers are rated for 500K pages, and usually last at least half that even under severe duty.  Regular light cleanings by the operator are recommended. Once a year a service tech should do a more thorough cleaning of the transport rollers & sensors. When the rollers do wear out, you can purchase them from online retailers like ScannerSolutions.com, but they aren't designed for easy user installation. Call your local dealer for a quote; the extra expense is worth the saved effort, and they should do a complete cleaning at the same time.
Posted on Apr 07, 2009
SOURCE:
Will Only Scan Color and single sided
Once I had a similar problem with CapturePerfect 2.0. No amount of setting will change the scan output. I hit the default option and then changed to the setting I wanted. It worked. May be there is a bug in the Scanning software.
S. Mohan, India
Jan 09, 2014 | Canon DR-3080CII Path-Through Flatbed...
Color duplex doesn't work
The Canon DR-3080C is only color on the front side. The back side is monochrome only. The next model, which was the DR-3080CII will do double sided color scanning
Sep 13, 2012 | Canon DR 3080C Path-Through Scanner
Who to replace rollers?
hi. the rollers on this scanner needs to be replaced by an engineer. Try paralogic if in the uk, they are very good :-)
Jan 18, 2012 | Canon DR-3080CII Path-Through Flatbed...
Hello, I am getting the following error message Scanner is busy, operation can not be completed. Canon DR-6080/7580/9080C Driver Version 1.3.10502.17001 (-4437) I need some assistance. Thank...
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer, reinstall drivers and scanning software. Pls run scandisk on the Computer and ensure the OS is okay.
S. Mohan
Feb 22, 2011 | Canon DR-3080CII Path-Through Flatbed...
When scanning, there are lines on the image I have scanned.
Use a blank sheet of paper (as white and clean as possible). Put it in the scanner landscape ( you will need to cut off about 1/2 inch of the paper to make it fit. The run the DR-3080CII Shading tool (DR3KUserSh.exe) C:\Program Files (x86)\Canon Electronics\DR-3080CII\DR3KUserSh.exe
May 19, 2010 | Canon DR 3080C Path-Through Scanner
Need the adjustment sheet to calibrate my canon dr3080cii, where can I download?
I'm sure the adjustment sheet is printed when you do a print test with the Canon control program, look in the windows programs menu for the Canon group and you should find the right program to run.
Mar 01, 2010 | Canon DR-3080CII Path-Through Flatbed...
How do I clean the rollers on a canon DR-3080CII The paper seems to be slipping a little.
Lightly dampen a cloth with water or rubbing alcohol. Gently rub across the roller side-to-side, rotate a little, and continue until you've gone all the way around. The most important rollers are the 3 at the paper feeding area  (2 top & 1 bottom). The bottom roller will be harder to turn than the top 2. Just be gentle & patient to avoid tearing the rubber. Frequent light cleanings are better than waiting for problems to crop up.
Apr 06, 2009 | Canon DR-3080CII Path-Through Flatbed...
Canon DR-3080cii paperjam
The 3 paper sensors are located along the center of the paper path. They are: Registration (lever type) on the bottom between separation & registration. Look for lever damage or torn paper. Scan Start (reflective) on the top between registration & front reading roller. Clean the sensor window with qtip & alcohol. Delivery (lever) at the eject roller. Same as reg, but harder to see due to location.The feed roller exchange kit is 6915A001. The rollers in this machine are not considered user replaceable.
Oct 09, 2008 | Canon DR-3080CII Path-Through Flatbed...
Canon DR-3080 CII Scanner
I recieved this error when trying to scan pages in using our new Kofax scanning solution with a DR-3080CII. I discovered that the latest canon driver for that scanner was not compatible with the software and it made the application hang in the background. I found an older driver that was compatible and installed it, no more error.
Sep 10, 2008 | Canon DR-3080CII Path-Through Flatbed...
Canon DR-3080CII Path-Through Flatbed Scanner Logo
441 people viewed this question
Clive
Clive
old marine
old marine
Ekse
