Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer rear projection model # SD-P6093-K
Wont turn on. Fuses check good. Relay operates. Red LED on the one pcb illuminates but no sound or picture or glow on the crt.
Please help
My email is jsamulcek@hotmail.com
thanks
jerry
    Scholar:
  • 167 Answers
HELLO. IT SOUND LIKE YOU HAVE NO HIGH VOLTAGE.!! COULD BE THAT YOUR HORZANL TRANZOR IS BAD & MAY BE YOUR FLY TRANSFORMER ALSO. !!! THEY WELL NEED TO BE REPLACED.!!! "GOOD LUCK" HOPE THIS HELP'S YOU!
Posted on Aug 20, 2008
My SD-P6093-K Pioneer has recently stopped turning on. It makes a click noise as if it was turning on, but about 3 seconds later it makes another click noise and then then nothing. No picture no anything....
STK ICs 2 of them,example STK392-110.also CK hori out put transistor and little blue capacitor 2Kvolts it feeds back to Hori Transistor. Mats has STKs
1-800-628-1118 $10.95 each they retail for $55.00 each in repair shops.
Mar 16, 2010 | Pioneer SD-P62A3-K 62" Rear Projection...
Pioneer sd-532hds. the red light is on but when
STK ICS 2 of them replace Both STK392-110 use 180s Mats Electronics has them $10.95 each
1-800-628-1118
Feb 25, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
Sd-533hd5 53
aj6404: what you described is what I understand to be referred to as an overload protection fault circuit kicking in. Sounds like you might have a fuse blown. Check the fuses on the PCB's. Unplug the power cable from the wall and allow it to sit for about 30 minutes before removing the back cover - till will allow the circuits to discharge before you go poking around - don't want to get shocked or popped by an arch.
Jul 02, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Power problem (switches to standby)
its the problem of the ics on the main power supply board
Do the IC heat sinks get warm??
If they do not, check fuses F852 - 2AMP, F853 - 1.25AMP, F850 & F851 - ALL 5AMP on the power deflection pcb. THESE ARE NOT GLASS FUSES. They are usually about the size of a 1 watt resistor and either green or orange in color. They are soldered in. The nomenclature is printed on the component side of the board. They are all about centered on the opposite edge of the PCB as the high voltage transformer.
If you have cleaned up the mess you describe you most likely have one of these fuses blown.
if dont have any technical knowledge its advisable to call a technician as it is worth getting it fixed.
thanks.
May 19, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Convergence board diodes
how about looking at the output resistors... also look at the fuses feeding the stks ussally if the blow the two fuses blow
Dec 21, 2007 | Televison & Video
Pioneer 610HD Rear Projection
Check all solder joints on the deflection board.
Dec 10, 2007 | Pioneer SD-582HD5 58" Rear Projection...
How to open pioneer sd-582hd5
from back good luck most problems are cold solder connections and i some models you have to replace three small caps in the video circuit
Oct 31, 2007 | Pioneer SD-582HD5 58" Rear Projection...
4a fuse blown
1)pull chassis.remove power PCB==the one with large heatsink w/convergence IC's on it 2)Observe four regulators also on same heatsink Remove solder from all reg. pins-clean PCB 3)Resolder 4)solder any/all bad connects 5)replace 4 amp fuse 6)reassemble & test
Oct 05, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
244 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
