Sport and Outdoor
Problem for Sport and Outdoor
Generic problem for all Sport and Outdoor
Evinrude 225 fitch ram injection
By coveproject1 on Aug 19, 2008
The motor runs perfect except between 2500-3000 RPM's. When I run between 2500-3000 RPM,s it runs rough and produces some dark smoke.
Same Problem
Sep 27, 2008
-   my 225hp envirude works perfectly at low rpm's or high rpm', but accelerating between 2500 and 3000 rpm's the engine chokes/vibrates/misfires and the engine light comes on ,the alarm also goes off, if i turn the engine off the alarm and engine light turns off but if try to go fast again the problem happens again(somentimes if i accelerate all the way im able to skipp the misfire and the engine respons fine), now it only occours in the water/ outside the water i can play with the trottle up and down all i want/with the prop engaged and nothing happens?? any suggestions-   zohany
Solution #1
posted on Jul 18, 2009
Not Rated)
bmurphyi
Rank: Apprentice
Rating: 0%, 0 votes
Mine does the same thing and I have spend $3500 trying to fix it and I am fed up. Put in new lines, impeller, thermostats, EMM. Still does it.
Was this helpful?
Yes
No
Popular Solutions for Sport and Outdoor
Questions and Unsolved Problems for Sport and Outdoor
Answer
I have a choice between Sta-rite Max-E-Therm SR400 Propane heater and The Jandy Lite 2 LG 400... (More)
Answer
Who should I contact to became a dealer? I am retail store in sports and I am looking at running... (More)
Answer
a friend blew up his 440f touring le 98 w/ rer, found a brand new crate engine 440f without rer,... (More)
Answer
I have a Hi STD Double 9 W104 and the trigger sticks and will not return to the ready position after... (More)
Answer
The sound has stopped working when changing mode and the alarm, the watch is a polar CS 300 (cycle)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sport and Outdoor:
Top Sport and Outdoor Experts
Rank: Guru Guru
Solutions: 756
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Sport and Outdoor Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
