I have iertutil.dll problems and i want to know how to fix it
  • 790 Answers
Hello!!!
Fix it using ur xp's recovery console... u need xp cd for it!!
Posted on Aug 19, 2008
On my windows 7 gateway laptop I am receiving the message "the ordinal 572 could not be located in the dynamic link library iertutil.dll. I ran a cmd scan and did not find anything. Any suggestions?
How To Fix Iertutil.dll Errors
Important: Do not download iertutil.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of iertutil.dll, it's best to obtain it from its original, legitimate source. Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the iertutil.dll error.
  1. Restore iertutil.dll from the Recycle Bin. The easiest possible cause of a "missing" iertutil.dll file is that you've mistakenly deleted it. If you suspect that you've accidentally deleted iertutil.dll but you've already emptied the Recycle Bin, you may be able to recover iertutil.dll with a free file recovery program.
    Important: Recovering a deleted copy of iertutil.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
Feb 10, 2014 | Gateway Computers & Internet
The ordinal 120 could not be located in the dynamic link library iertutil.dll
iertutil.dll is a dynamic link library used by Internet Explorer. Ordinal 120 refers to something inside the dynamic link library. These errors typically occur when the file is corrupt or there is a version mismatch (eg. IE 9 using iertutil.dll from IE 8). A reinstall of IE should fix this problem
Ericthecmh
Oct 05, 2011 | Microsoft Windows XP Professional for PC
Theres A Problem of My Computer How To Fix MY Computer The Eror Name is iertutil.dll Thats My Problem Eror
Iertutil.dll Error MessagesThere are several different ways that iertutil.dll errors can show up on your computer. Here are some of the more common ways that you might see iertutil.dll errors:
  • "Iertutil.dll Not Found"
  • "This application failed to start because iertutil.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\iertutil.dll"
  • "The file iertutil.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: iertutil.dll. Please install [APPLICATION] again."
Iertutil.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the iertutil.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Iertutil.dll ErrorsIertutil.dll errors are caused by situations that lead to the removal or corruption of the iertutil DLL file.
In some cases, iertutil.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Iertutil.dll ErrorsImportant: Do not download iertutil.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of iertutil.dll, it's best to obtain it from its original, legitimate source.Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the iertutil.dll error.
  2. Run a virus/malware scan of your entire system. Some iertutil.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the iertutil.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the iertutil.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the iertutil.dll file. If the iertutil.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the iertutil.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to iertutil.dll. If, for example, you're receiving a "The file iertutil.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The iertutil.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if iertutil.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the iertutil.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The iertutil.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause iertutil.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual iertutil.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair iertutil.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid iertutil.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the iertutil.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the iertutil.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any iertutil.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Any doubts you can contact a technician through the website
www.thebestpcdoctor.com
Toll Free: 877 407 8229
Aug 11, 2011 | Microsoft Windows 7 Ultimate for PC
In my computer says u have a missing a file, The file name is IERTUTIL DLL thats why i am searching this file
hi,
You can go to this site ..
http://www.fix-all-dll-errors.com/IERTUTIL.dll/
as I registered few dll's from this site as it is free...worked in my case :)
Feb 13, 2011 | Computers & Internet
Iertutil.dll not found yahoo messenger
Oct 19, 2010 | Computers & Internet
Failed to start because iertutil.dll was not found.
You can get it free from
http://www.dll-files.com/dllindex/dll-files.shtml?iertutil
click the free download link midway through the page and then click download in the popup window and unpack the file inside the archive to Windows/system directory
Sep 06, 2010 | Computers & Internet
The ordinal 685 could not located in the dynamic link library iertutil.dll.
the ordinal 685 could not located in the dynamic link library iertutil.dll.
Oct 28, 2009 | Dell Computers & Internet
Ibm think pad
File iertutil.dll is located in the folder C:\Windows\System32. Downloading the file and copying into the specified folder will solve this problem.
Sep 28, 2008 | IBM ThinkPad T42 Notebook
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
