I have managed to delete my MBR.....HELP! - Computers & Internet
    Master:
  • 397 Answers
You will need to run the FIXMBR command from your Windows installation disk.
Please see here for instructions:
http://www.ntfs.com/mbr-damaged.htm
Posted on Aug 19, 2008
    Genius:
  • 3,422 Answers
HI,
Can you please describe your problem?
  • Priya darshan Aug 19, 2008
    Repairing a Damaged MBR
    Your Windows XP setup CDROM has a tool called the Recovery Console,
    which is designed to help you repair a damaged master boot record or
    boot sector. To start the Recovery Console and fix your damaged MBR,
    follow these steps:
    1. Restart your computer with the Windows XP Setup disk in the CDROM drive.
    2. If you are prompted to press a key to start the computer from
      CDROM, do so quickly. Otherwise it may try to boot from the hard drive.
    3. After a few minutes, you'll see a prompt to press the R key to start the Recovery Console.
    4. When Recovery Console starts, it will prompt you to enter a
      number corresponding to the Windows XP installation that you need to
      repair. In most cases, you'll enter "1" (which will be the only
      choice). If you press ENTER without typing a number, Recovery Console
      will quit and restart your computer.
    5. Enter your Administrator password. If you don't enter the correct password, you cannot continue.
    6. At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed.
    Your damaged MBR will be replaced with a shiny new one, and you
    should then be able to boot your system normally. In some cases, you
    may need to repair the boot sector in addition to the MBR. If your
    system still doesn't boot properly, repeat the steps above, but issue
    the fixboot command instead.
    NOTE: These procedures assume that you have only one operating
    system installed. If you are an advanced user and have a multi-boot
    system with more than one operating system, you may need to do some
    additional reading about the fixmbr and fixboot commands at the
    Microsoft website.
    For more fixes,please click on the below link:
    http://www.ptdd.com/mbr.htm
Is my WD My Book 4064-7-5107-020 using MBR partition
This does not depend on the housing of the drive, but on the way the disc has been formatted.
To check (on a Windows computer) : Right-click on "My PC", select "Manage" : this opens a "Computer Management" new window ; in the lower part of the window, right-click on the label part of the disc you want to check (the place with the capacity) : one of the lines will say either "convert to GPT" (if the disc is MBR), or "convert to MBR" (if the disc is GPT).
P.S.: the wording of the messages could slightly differ depending on your version of Windows)
Apr 24, 2016 | Computers & Internet
I've dual booted win8 with linux, to remove i used "easyBCD" to restore MBR, and deleted the partition. the deleted partition was lost and my harddisk capacity (showing as online) reduced to 300gb fro
erase your drive and deallocate and repartiton your whole drive using fdisk(windows) or utility softwares like killdisk
also one thing is to be noted that Linux systems recognizes the windows fat32 and ntfs partitions but windows doesn't recognize file systems like ext4 or swap which are the prime type of file systems partitions used in Linux systems!
May 31, 2014 | Computers & Internet
I had deleted my compaq610 laptop's d drive data which is recovery drive,now my computer have did not start normally.where i get agian my data.?
Its due to MBR problem... please follow below link..u will get help
http://www.sevenforums.com/tutorials/20864-mbr-restore-windows-7-master-boot-record.html
Aug 04, 2011 | Computers & Internet
I removed Ubuntu from a dual Vista/Ubuntu boot system. Now I am left with a free space. When I try to create a new simple volume using Vista Disk Management tool, it comes back with a message "there...
it is very hard for me to help someone that wants to get rid of LINUX :( ...but I'm a proffessional and I'm letting my feelings aside ha!
Firs is your MBR was created with UBUNTU or Windows (in other words when you boot is it a windows menu or a LINUX menu) that lets you choose the boot options? if it's LINUX you have to use a LINUX base partition editor to edit the MBR (the way the system will boot), if it's a Windows MBR then you normally ave to delete the LINUX partiton... (if Windows can not delete it you can use a LINUX base disk partitioner) be extra prudent using disk partition editors, if you do not understand what you do you can LOSE data...
Jan 12, 2011 | Computers & Internet
I had booting problems with my HITACHI_DK23FA40-40GB. I suspected MBR was corrupt and used MBRwiz tool I down loaded from internet. And the problem became worse. I cannot even access my hard disk. Disk...
you have to backup the mbr before edit. also try use command Fdisk /mbr command to repair mbr.
also pls try to use bootable recovery disk like hiran boot disk, you can use hbcd menu and disk tools and choose disk genius or data recovery
Dec 25, 2017 | Hitachi TravelStar DK23EA Series DK23EA-40...
My Verbatim 4gig store and go usb stick in stuck in RAW Format
right click my computer, manage. go to disk management and delete any volumes on the flash and set back to basic disk if it's dynamic. format fat 32
Mar 14, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
How tp convert a GPT hard drive to a MBR hard drive? thanks
Boot off your Vista disc and go to the Recovery options. Once inside there access Command Prompt (It is a choice in the Menu) type Diskpart.exe and hit enter. Then type Help you will see many options.
What you want to do is type 'List Disk' select the Disk you wish to convert and so forth. Basically the way to convert from GPT to MBR is in there. You can also clean all data off the disk from inside Diskpart and start over with MBR.
Commands to Convert Disks
convert mbr [noerr]
Use the convert mbr command to set the partitioning style of the current disk to MBR. The disk may be a basic disk or a dynamic disk but the disk must not contain any valid data partitions or volumes.
convert gpt [noerr]
Use the convert gpt command to set the partitioning style of the current disk to GPT. The disk may be a basic or a dynamic disk but it must not contain any valid data partitions or volumes. This command is valid only on Itanium-based computers; it may be unsuccessful on x-86-based computers.
convert dynamic [noerr]
Use the convert dynamic command to change a basic disk into a dynamic disk. The disk may contain valid data partitions.
convert basic [noerr]
Use the convert basic command to change an empty dynamic disk to basic.
http://support.microsoft.com/kb/300415
Mar 11, 2010 | Compaq Presario 1692 Notebook
How to remove a bootloader from MBR
Boot from windows startup disk (CD or floppy), enter command prompt mode. Make sure you have fdisk program. Then run `fdisk /mbr` to restore your MBR (Master Boot Record).
Dec 25, 2008 | Red Hat Enterprise Linux ES 3 Standard...
Unreadable fujitsu 160 gb mhy2160bh
Some HD manufacturers provide utilities for Disk Recovery. You can usually download these from their site. If you are lucky it is just the drives Master Boot Record that is damaged. The fact that the drive is recognizable is in your favour I think. Unfortunately when power is restored after an outage there is often a power surge or spike on your AC which can damage electronic equipment. Many devices these days work on such low voltages and current that it doesn't take much. A good surge protector is a must for computer equipment.
Dec 08, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
HM160JC
skogkatt
sorry for late. the massage say that mbr of ur hard diskt have problem. pls one time again give fixmbr then restart ur machine then give fixboot c: then restart ur machine. after this if a massage say that ntldr missing then copy it c: from i386 folder (windows installation cd). if problem not solve then try to reinstall windows xp by removeing all partition and then creat new partion. if their was any improtent data pls do not try to install windows xp. just remove hdd. from ur laptop then use a external harddisk casing then attached with a pc then recover data by a recoveray software( like pc instector file recovery). then delete all partitition write new mbr by using fixmbr if it fail again, then use Disk manager v10 to write mbr.
(Mbr is a record which contain master boot coad and partition table if this coad not execute properly then system can't access hdd. system halted after DMI pool data result blinking curser at black screen)
u can use microsoft diskprobe to write mbr manualy which u found in windows xp cd supprot/support.cab/diskprobe.exe
u also found it help file undr support.cab
Jul 10, 2008 | Samsung SpinPoint M80 HM160JC Hard Drive
Computers & Internet Logo
David Payne
David Payne
