Question about GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator
Fridge problems I have a hvac business for 30 years. but know little about fridges . my problem i have now is . it is fine and cooling but then just stops. when I put on gauges it has gone into a vaccum. prolly -20 on my gages in vaccum. when it is turned off it has about 50 lbs of pressure on gauges. I figured there was a blockage. I changed the filter drier. vaccumed down . filled with 134a . was doing great . running about 2 to 5 lbs of pressure low side. got freezer down to 15 degrees. I figured it was fine. brought it in house. and now it is running -20 in vaccum again . any suggestions? I am not sure if this is the model of mine but it is close haha.
  • 639 Answers
Friend,
ngfam1 At your service!
Sounds like a Thermostat problem!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Posted on Aug 31, 2008
After taking of the freezer back plate I can see the coils and thermostat but not the heater. Is there a video that shows where the heater is, how to get at it and how to change the heater?
the element is in the middle of the coil at the bottom they will burn but 30 years in the business tought me that the defrost timer is no 1 for defrost problemes and defrost thermostat is no 2 before and the element is rarelly defective
Jan 04, 2015 | GE Refrigerators
Large fridge & freezer in caravan. Works fine on mains electric but fails to cool on gas. The pilot ignites and fridge cools very slightly on gas
IN THE PAST I HAVE TAKEN THE UNIT OUT AND TURNED IT UPSIDE DOWN, AND LEFT IT SIT FOR ABOUT 1 MONTH. THEN REINSTALL THE FRIDGE, AND IT WORKS AGAIN.. .. REASON YOU MAY ASK ? THERE IS A LITTLE BULB THAT THE FLAME KISSES, AND IT SEEMS IT GETS TRASH INSIDE THE BULB, AND SLOWS THE HEAT TRANSFER .. YA I KNOW IT SOUNDS CRAZY, THAT'S WHAT I THOUGHT ALSO.. OH AND TO OPERATE THE UNIT NEEDS TO BE LEVEL (CHECK THIS FIRST !!) ..LAST ONE I DID WAS ABOUT 25 YEARS AGO..
JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jul 20, 2011 | Dometic Refrigerators
Any info on electrolux RA1300 gas fridge. Freezer works well but fridge compartment doesn't chill
If you had an electric fridge the problem is usually the evaporator fan motor ($30).
I suspect that you may have the same problem. Generally, freezers are cooled only, when the fridge needs cooling, the evaporator fan comes on and blows cold air from the freezer to the fridge compartment. The advice below is for an electric fridge but may also work for you, it's worth a try I suppose.
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Available from a parts supplier or electric motor company.
Unplug fridge, or disconnect gas etc. Fan should be located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Nov 10, 2009 | Electronics - Others
Fridge losing cool
If I was of assistance please vote, Thank you.
Dec 26, 2008 | Amana Refrigerators
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Fridge not working
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
Mar 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
Not refrigerating
DO you have a thermometer to check the temp in both sections? MY first guess at the temp problem is that the fan has quit OR the vent betwen the freezer and the fridge is blocked. I bet on the fan being bad. Open the fridge door and hold in the little switch that operates the light. YOu should hear a fan running . If not, then the fan is kaput.. JOhnno.
Sep 16, 2007 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
51 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
