.User manual can be found here at this site.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Cooking/SY86P_19504580000.pdf
It's a PDF File so you will need a PDF Reader like Adobe and it can be found here if you do not have one.
http://www.adobe.com/pdf/
Before you go working too hard to get
you oven to go into the self clean mode(self destruct)....check out
this tip...
Self
Cleaning Oven Problem
heatman101
Wish I had read this first. I never would have used the self cleaning
option. Thanks for the info!!
this tip...
Self
heatman101
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
this tip...
Self
heatman101
Some
ovens are self cleaning During the cleaning process, the oven heats up
to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off
food and spills inside the oven, leaving ash that can easily be wiped
out. The oven door locks while it is cleaning to prevent the door from
being opened. Self cleaning ovens are better insulated than regular
ovens to keep the extreme heat inside.
