Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Problem not solved
My machine doesn't have numericals button, for me to push "0" on it. The only buttons it has is for the # of copies, one for 10's or multiples & another for "1" & up . got any other suggestions?
  • 6,487 Answers
Hopefully everything will be working fine there after you replace that bad parts of your Xerox , feel free to contact us back here anytime thank you...
Posted on Aug 20, 2008
How can i remove error code c 448 in toshiba e studio 5540c
Step 1: Remove all the paper that is jammed in the machine. Follow the steps on the touch screen to locate the jammed paper.
Step 2: Turn off the copier with the power rocker switch on the right side.
Step 3: Hold down the 8 and 0 on the numeric keypad while turning the machine back on.
Step 4: Enter 400 on the numeric keypad and then press the Start (copy) button. As you type the 400 will show up in place of the D
Step 5: Enter 0 on the numeric keypad and then press the "Enter" button on the touch screen.
Step 6: Power down the machine with the same power rocker switch as in Step 2.
Step 7: Turn on the machine with the power rocker switch.
Dec 31, 2015 | Toshiba Office Equipment & Supplies
How do i reset SC542 error in Ricoh Aficio SP300DN?
FOR RICOH AFICIO SP 3400SF follow below steps.
1. To access Service Mode, On Control Panel press following buttons one
by one immediately.
Cancel Button (Red) ---> 1 (Numeric One) ---> 0 (Numeric zero) ---> 7
(Numeric Seven) ---> Copy Button (Green)
2. In Service Menu you will find Engine reset Menu. In that you can reset
SC 545 in Fuser Reset Menu. And you can also reset SC 542.
Feb 23, 2015 | Ricoh Office Equipment & Supplies
Error code cof32 & c0070 at bizhub 210 how con i fix it?
Solution for Error code C0F32
1-Turn the machine ON. 2-Press "Utility" button on front panel.
3-Now press these buttons "stop+0+0+stop+0+1" it means press stop button, then press 0,again 0, then again press stop button, then press 0, and 1.
4-service mode will appear on LCD screen.
5-Now with the help of arrow keys go to the 2nd option which is "ADJUST"
6-Now press "YES" button.
7-Again by pressing the down side arrow key go the option which is "ATDC ADJUST".
8-Press YES button.
9-Now increase the value, for example if the value is 145, you have to enter 155 or 160.enter the value with numerical key pad buttons.
10-After entering the new value press "YES" button.
Error Code C0070
Solution:
1- Open the front door and bring the bottle out.Now restart the machine.if the code appears then open the toner hopper section.Toner hopper drive motor is not working, Dis mental the hopper section.
Jan 27, 2014 | Toshiba E-Studio167 Copier
Konica minolta bizup210 call service error cof32
If you want to remove this code by yourself then please perform these actions attentively. 1-Turn the machine ON.
8-Press YES button.
11-Restart the machine.
Jan 23, 2014 | Televison & Video
My printer ricoh aficio SP 3400SF is showing service call error code SC542. kindly help to come out of this error. \r\nvr babu
by one immediately.
Jun 23, 2011 | Ricoh Aficio AP3800C Laser Printer
Canon Pixma MP 130/10 Waste Ink Absorber almost full
  • Printer on, press Additional Functions, Scan, Copy, Scan. Now you should be in service mode.
  • Select Test mode.
  • Select #8 Printer Test, push the + or - button until it says 8-3 then hit the select button.
  • The menu will say EEPRON Clear
  • Select Ink count which is option (0) and press set
  • Then press Stop/Reset Followed by the power button and then wait for it to restart.
If you need further assistance. feel free to ask. If this solves your issue, please rate it. Thanks, Joe
Feb 09, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Error code C2557
Error code c2557 means "ATDC Sensor abnormality".
It appears due to following reasons,
1-Imaging unit (Drum unit) parts life is expired,
2-Developer's life is expired,.
3-Developer tank is hard, gears of the unit are not moving
For best results and smooth functioning of machine, simply call your technical services representative and he will help you in this matter.
OR
if you want to do it yourself, you have to do this.
1-Press "UTILITY/COUNTER' button on the machine's panel.
2-Now press "check details" button. (appeared on the lcd screen)
3-Now press these buttons,
STOP+0+0+STOP+0+1
4-now press "Tech representative choice" button on LCD screen.
5-now press "PRINTER" button.
6-press "ATDC GAIN"
7-Now press the "c" button to clear the value, after clearing the value enter new value by using numeric pad.
Enter new value by adding 10 to the previous value. For example if the previous value was 150 you have to enter 160 now or 165.
8-Enter the new value and press the End button on the LCD screen and exit.
9-Now restart the machine..
Nov 04, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Minolta bizhub 162 error code 32
In Konica Minolta bizhub 210,162,211,163,182, error code "cof32" means "Automatic toner density control abnormality.
To remove this code or you want to get rid of this problem, simply call your technical service representative to solve this problem.
8-Press YES button.
Oct 04, 2010 | Konica Minolta bizhub C351 All-In-One...
I have the error C0F32 (Minolta - 210) on my display. I have to replace some parts ou just put some code?
Yes, you have to replace the parts which are necessary to be replace.If you do not want to replace the parts and also want to get rid of this problem then please perform these steps.....
1-Press utility button. 2-now press these buttons quickly stop, 0, 0 , stop, 0, 1. 3-You are now in service mode.here, scroll down and select ADJUST. 4-Now select ATDC gain. 5-Now increase the value shown on the display for example if the value is 145, increase the value to 165 or 170. To increase the value, press the C button to clear and now enter the new value by pressing the numeric keys on panel. After this press yes button and then press rest button.Re start the machine and start making copies..........
Aug 26, 2010 | Konica Minolta bizhub 180 All-In-One...
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
22 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
