This section explains the way to confirm the ink status and
the procedure to replace ink tanks. When ink runs out or other errors
occur, an error message is displayed on the LCD to inform you of the
error. See "
An Error Message Is Displayed on the LCD".
When printing from your computer, error messages appear on your computer screen as well.
NOTEBe sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder.
The machine will not print if an ink tank is installed in the incorrect position.
With the LCD of this MachineMake
sure that the machine is turned on, then press the COPY, FAX, SCAN, or
MEMORY CARD button. The current ink level will be displayed on the LCD
for a few seconds.
(A) Confirm whether any symbols are displayed here.
Color or black ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Color or black ink may have run out. See"An Error Message Is Displayed on the LCD".
REFERENCEThe ink status information is also displayed on the screen that appears during printing.
An error message may be displayed on the LCD during printing.
Machine detected ink out condition. See "An Error Message Is Displayed on the LCD" and take appropriate action.
(B) Empty ink tank.
With the Ink LampsYou
can confirm the status of each ink tank by the ink lamps. Open the
Scanning Unit (Printer Cover) of the machine to confirm how the ink
lamps light or flash.
The ink tank is correctly set and there is enough ink remaining to print.
Flashing slowly (at around 3-second intervals)
Ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Flashing quickly (at around 1-second intervals)
The
ink tank is inserted in the wrong position or it is empty. Ensure that
the ink tank is in the correct position as directed by the label on the
Print Head Holder. If the position is correct and its lamp flashes, it
is empty. Replace it with a new one.
The ink tank is not set properly or the function for detecting the remaining ink level is disabled.
If the ink tank is not set properly, press the
mark on the ink tank until the tank clicks into place. If it does not
click into place, make sure that the orange protective cap has been
removed from the bottom of the ink tank.
If the function for detecting the remaining ink level is disabled, replace the ink tank with anew one. See "
Replacing Ink Tanks".
If the lamps are still off after reinserting the ink tanks, there has been an error and the
machine cannot print. Check the error message displayed on the LCD. See "An Error
Getting the Clear Ink Status InformationClear ink is used only when printing on plain paper.
When
Plain paper (Cassette) is selected for Media type and printing begins
when clear ink (PGI-9Clear) is low, a message will be displayed in the
LCD.
(A) Confirm whether a symbol is displayed here.
The clear ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
The
clear ink tank is empty. See ""The clear ink tank is empty. Replacing
the ink tank is recommended." U045" and take appropriate action.
NOTE- The ink status information is also displayed on the screen that appears during printing.
- Clear
ink is used only when printing on plain paper. Therefore, it is
possible to print on photo paper, or any type of paper other than plain
paper, loaded in the Rear Tray, even if clear ink has run out.
The following error message will be displayed on the LCD when the clear ink has run out during printing on plain paper.
Refer
to "Replacing Ink Tanks"If you continue printing under the clear ink
out condition, see ""The clear Ink has run out. Replace the ink tank."
U165/U166" and take appropriate action.When the clear ink hasrun out,
printing on plain paper from the Cassette is not possible. The fax,
which is received under the clear ink out condition, will be stored in
memory.
NOTEIt
is possible to print on photo paper, or any media type other than plain
got the same problem...
