Question about Tefal UltraGlide Easycord FV4256 Iron
Response Hello I have checked what I can however I have not opened the iron but I am surprised that the water part is working fine but not the actual iron. Any other suggestions?
    Master:
  • 623 Answers
You have to open your iron to see what wires are disconnected or loose
Posted on Aug 19, 2008
How to open this rinse boiler for tefal pro express 2929 iron
Hello there. Place a coin in the groove running along the centre of the plug and twist it, or lie the end of a screwdriver into the groove and twist it. If the plug still will not move then it is jammed in with scale.
Please see below how I solved the plug problem when it was being held down and was immoveable due to scale.
NOTE: In future always use $2.00 litre bottles of distilled water from supermarkets in your iron, never use scale laden tap water.
Tefal pro express steam generator iron I need to drain '& clean the boiler but the boiler drain plug is seized I can't loosen it
Use a small tack hammer (its head covered with a cloth) they have a far smaller and lighter head than a standard hammer. Tap all around the edge of the plug and in the middle. My thinking is that the plug is in the grip of scale. The tapping loosens it and it falls off. This worked for me.
Also tap the end of a tiny screwdriver like watchmakers use, or the head of a fine tip kitchen skewer around the perimeter edge of the plug, go gently around twice, plus the other tapping and it breaks the seal formed by scale which is holding the plug down.
Next, fill and rinse the boiler out up to 6 times to get rid of all the sediment and the rinse water runs 100% clean. Always use distilled water from supermarket from now on (litre less than $3.00). No more scale, no more cleaning. WARNING: Make sure boiler is totally water free after final rinse- out. Refill water container on the actual iron itself with distilled water from now on.
Please let us all know if this worked for you and if my post was helpful. Good luck with it, Chris.
Feb 04, 2015 | Tefal Irons
Tefal repairs
follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in wat
Nov 29, 2013 | Irons
My steam cleaner was working, then when i refilled it, it didnt heat up. its a multipurpose with different attachments. could it be element gone?
Clean an iron:
  1. Unplug the iron.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Sep 30, 2013 | Conair Compact Garment Steamer Iron
How to open a steam iron severin
follow this principle.God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Jul 20, 2013 | Severin Steam Iron, 2500 Watt, White...
How to clean inside of iron
Please don't take Landsend advice, as it contadicts this whole "fixya" site! Let's keep it going by not giving in to this throw away world! Some people can't afford a $20 iron @ Wally's!
All the solutions above (besides Landsend) are on it!! Your City water is still too, hard for these delicate, devices. Filtered, as Alan Serna mentioned, is the way to go!! Dump your water out of your iron, when not using-maintenance is key, for everything, even your families!! : ) Have a G8 day!
Sep 28, 2012 | Sunbeam 3017 Iron with Auto Shutoff
My Rowenta Expert steam generation iron (seperate tank for the water type) is starting to spit ever so often brown water out. I only use filtered water. How can I clean the actual Iron, the water tank is...
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Mar 16, 2011 | Rowenta DG-980 Iron
Steam iron
time for a new iron, safety first , you will be surprised at what you can get on sale these days
Sep 01, 2008 | Irons
Water pouring out of my iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Aug 26, 2008 | Rowenta Powerglide DM273 Iron
Tefal UltraGlide Easycord FV4256 Iron Logo
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
