Heating & Cooling Logo
Posted on Jun 12, 2011
My Daikin AC is showing an E7 error code! the indoor unit is FDYQ60DV1 and the outdoor unit is 7J-/060 Can you tell me what this error is?
Lisa Bowman
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 16, 2019
Lisa Bowman
Contributor
Level 1:
Answers
Questions
0
Helped
5110
Points
Hi there, we got the E7 code. The technician replaced the fan motors and they started turning but then stopped again and the E7 code reappeared. Any ideas? Thank you
Anonymous
Level 1:
New Friend:
  • Posted on Jun 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5110
Points
5
P.c.b feed bak signals is failed.probably,,temperature sensor or fan motor signal.
  • emslilmama_2
    emslilmama_2 Jul 08, 2012
    i hace a indoor unit with a drain hose it came with a rubber plug in it not the hose so i didnt know to take the plug out i got it second hand so it filled with water and it gave me e7 code i pulled the little black plug acsidently to unhook hose water pored out i drained it pluged it in e7 code was gone hope this may help someone out there
Voltas Cassette A/C 2 ton. The indoor light is blinking 8 times. Problem?
What is the error code E8 on Voltas cassette AC unit?
An E8 error usually indicates a fan problem with the indoor or outdoor unit. An E8 error is usually cleared by power cycling both the indoor and outdoor unit by turning power off at the breaker. Be sure to check the indoor air filters are not dirty and blocking air flow from the fan.
Or
https://www.republicworld.com/technology-news/gadgets/voltas-ac-error-codes-list-know-the-meaning-of-all-these-error-codes-right-here.html#:~:text=F8%3A%20This%20error%20code%20shows,with%20the%20outdoor%20DC%20fan.&text=P2%3A%20This%20error%20code%20shows,the%20Compressor%20phase%20current%20protection.
What is the error code F8 on Voltas?
F8: This error code shows up only when there is an issue with the outdoor ambient temperature sensor. F9: This error code shows up only when there is an issue with the outdoor DC fan. P2: This error code shows up only when there is an issue with the Compressor phase current protection.
Mar 24, 2021
Voltas AC Error Codes list: Know the meaning of all these
https://www.google.com/search?q=Voltas+Cassette+A%2FC+2+ton.+blinking+8+times
How to fix error code U4 and what PCB because I don’t understand it
U4 - Communication error between indoor and outdoor units/outdoor and BS units - A mistake with the interconnection wires, or an indoor/outdoor PCB fault.
Daikin Air Conditioning Fault Codes Explained [Infographic ...
H4 error code is shown on AC display what can i do to slove this problem
Full list of Gree Air Conditioner Mini Split Units Fault Codes. When error codes appear on the Gree air conditioner indoor display, this tells the user there is an issue with the Gree AC unit. The error code displayed will inform you of the issue or problem that is occurring with the air conditioner. Knowing what the error code means and its definition will help you to understand and troubleshoot the exact Gree air conditioner part that needs to be fixed, cleaned, repaired, or replaced. You can then clean, fix, or replace the Gree part yourself and save money. See below for all error codes that can occur on Gree Mini Split AC's.
Gree Mini Split Air Conditioner Error Codes - How To Fix
Gree Viero AC Mini Split PDF Owners and Troubleshooting Manual
GREE DUCTLESS AIR CONDITIONING & HEATING SYSTEM INSTALLATION MANUAL
Gree Mini Split Air Conditioner Part Names and Locations
INDOOR AND OUTDOOR UNIT
The Gree Air Conditioning Vireo System has onboard error code diagnostics. The outdoor unit will provide status indicators and the indoor wall unit and remote control will display error codes. The following is a summary of the codes with explanations...
GREE AC DIAGNOSTIC ERROR CODES
Gree Vireo Mini Split Air Conditioner Error Code F0
Refrigerant Leakage Protection
1) Refrigerant leak(s).
2) Indoor coil temperature sensor not calibrated.
3) Refrigerant flow is restricted (ex. valve, exv, debris)
Outdoor Unit Red Light Indicator - 9 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E1
System High Pressure
1) Over charged with refrigerant.
2) Blocked or dirty outdoor coil.
3) Extreme outdoor ambient conditions
Gree Vireo Mini Split Air Conditioner Error Code E2
Indoor Anti-Freeze Protection
1) Low return airflow.
2) Indoor fan speed is too low.
3) Indoor coil is blocked or dirty.
Outdoor Unit Yellow Light Indicator - 3 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E4
Compressor High Discharge Temperature Protection
Please refer to the malfunction analysis (discharge temperature, overload) in service manual.
Outdoor Unit Yellow Light Indicator - 7 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E5
Overcurrent Protection
1) Supply voltage is unstable.
2) Supply voltage is too low and system load is too high.
Outdoor Unit Yellow Light Indicator - 5 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E6
Communication Malfunction
1) Communication cable is wired incorrectly between indoor and outdoor units.
2) Indoor or Outdoor control board malfunction.
Outdoor Unit Yellow Light Indicator - Continuous On
Gree Vireo Mini Split Air Conditioner Error Code E8
High Temperature Resistant Protection
1) Incorrect refrigerant charge level.
2) Refrigerant metering device malfunction.
3) Compressor malfunction.
Outdoor Unit Yellow Light Indicator - 6 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code EE
EEPROM Memory Malfunction
Control board malfunction.
Outdoor Unit Yellow Light Indicator - 11 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code C5
System Configuration Malfunction
1) No jumper cap inserted on the control board.
2) Incorrect or damaged jumper cap on control board.
3) Indoor and outdoor units are not compatible.
Gree Vireo Mini Split Air Conditioner Error Code Fo
Pump Down or Gathering Refrigerant Status
Optional Service Mode
Outdoor Unit Yellow Light Indicator - 17 flashes and 1 sec Off
NOTE: All of the Gree Air Conditioner Model Numbers below are applicable for the error codes on this page...
Gree AC Vireo Models: VIR09HP115V1A, VIR12HP115V1A, VIR09HP230V1A, VIR12HP230V1A, VIR18HP230V1A, VIR24HP230V1A, VIR30HP230V1A, and VIR36HP230V1A.
Gree Mini Split Air Conditioner Error Code Charts
Gree Mini Split AC Remote Control Button Names
Gree Mini Split AC Remote Control Icons Display Screen
Gree Mini Split Air Conditioner Air Filter Cleaning Procedure
Need help with error codes on your Gree AC? Please leave a question below and we will be happy to help.
How can resolved PJ error in daikin vrv 2
PJ is an error that has to do with the outdoor unit not matching the indoor unit. This means the outdoor board thinks it's a 2 ton unit and the indoor thinks it's a 1 ton unit. (Just throwing those numbers in)...but, the indoor is not matching the outdoor. You need to read the manual and go through the setup process.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Error Code E7?
Feature : E7 Error code on indoor unit display panel
  • Answer :Reason:
    Communication fault between indoor and outdoor unit
    Solution:
    This may be caused by:
    1.wrong connection of cable,
    2.indoor PCB, outdoor PCB fault, or power module fault
    3.cable connection loose
F8 error split air conditioner
F8 error isn't registered with my Daikin Airconditioner, though E7 showed up as a 'motor over-current' warning.
It might help if you find out the NAME and the MODEL NUMBER for your air conditioner.
Once you know this, then you can search for it like this...
Name - Model - error codes
E.g. 'Daikin Ft18k error codes'
Error message U4
Signal transmission error. Indoor and outdoor PCB's cannot communicate. Usually a faulty controller board in the outdoor unit. If the indoor unit otherwise functions normally (can control fan speed, louvres, beeps in replay to all remote buttons) then it is probably OK so check outdoor controller PCB.
2answers
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
Daikin reverse cycle air conditioner error U4
Signal transmission error (between indoor and outdoor units) which means a faulty indoor or (more likely) faulty outdoor controller board. Call a tech.
44helpful
4answers
U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
Top Heating & Cooling Experts
Paul Carew
john h
