Question about Olympus EVOLT E-500 Digital Camera
Autofocus...images often blurry
I am having trouble outdoors getting my images sharp using the auto focus feature. I use a tripod when shooting HS seniors and I'm ususally shooting at 60th around f/5.6 Head and shoulders seems to be in focus, but 3/4 and full length are not tac sharp. I'm being careful when I depress shutter not to cause and vibration with my hand and I tell the kids that they need to stay still. What else could be causing this problem?
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Upper right of camera back side is bracket with 3 dots [---], press and change to center point for accurate focus ... also in tripod shooting, you can set a delay (timer) for 2 seconds to make sure that the camera is still while shooting
Posted on Aug 20, 2008
Photos are coming out blurry
There could be several reasons for this - pick the most likely !
If the entire image is blurry, with no sharp detail, it could be camera shake, or subject movement, especially at longer focal lengths (i.e. at the telephoto end of the zoom range). Try using a tripod or other firm support and see if that improves things.
If only parts of the image are blurry (i. e. the background is sharp but closer objects are not) then the autofocus system could be selecting the wrong area upon which to focus - try using lock focus on the subject, then re-compose.
The front element of protective filter could need cleaning - carefully!
The camera could have suffered a knock which has dislodged one or more of the internal lens elements - in which case, a visit to the repair centre is called for.
May 17, 2016 | Olympus Cameras
Why do I get blurry pictures on screen even when I'm focusing.
Go to MENU. Then TOOLS. Make sure Motion Detection is in AUTO.
If that is on AUTO then Put the camera on a hard surface (like tripod) and focus and see if image is still blurry. Lastly, it is difficult to focus in some conditions. Move the focus point, you can click on the screen to change it. Blur can be caused by: long exposures, camera motion during photograph, bad conditions unable to focus.
The focus routine in this camera gets confused often. It can be frustration. It will only be in focus when it is GREEN before you shoot and the camera is not shaking. At night it can take great night shots with a TRIPOD and Exposure set to -1 to -2.
Dec 07, 2014 | Nikon Coolpix S4000 Digital Camera
All of a sudden every picture I take with the 55-200 zoom lens is blurry and slightly out of focus. Pictures with the 18-55 lens are still sharp. I have been using that 55-200 lens for years for sports...
Simplest answer is that you may have accidentally flipped the focus switch (A/M) on the lens to M. This turns off autofocus for that lens (which you might need to do if autofocus just can't resolve the image). Try turning it back to A.
Another possibility is that you're using an autofocus target different from the one you're expecting. The problem would be apparent regardless of lens choice, by being in focus in a different part of the image. You can press the arrow keys (while holding shutter release down halfway) to change AF targets, or change a menu setting to simply choose the closest target.
The shooting modes have no effect on focusing ability.
The camera would likely detect other focus-related problems (like servo failure).
May 09, 2011 | Nikon D40x Digital Camera
When I take a picture with my 18-55 on a d3100 I hear and see through my visor that the image moves and a sound like a click, many seconds after taking the picture. It seems like it's still open and closes...
Giving the lens your using and depending on the shooting mode your in. I assume your shooting in a low light situation. The lens you have is not good for low light shooting because the F-stop is only 3.5 at widest, so minimal light gets in so the camera decides what speed to set it at to close the shutter. for example shooting in the school gym or church, the camera speed will be 1/20 second or even up to 1/2 second to get enough lighting into the sensor so the image is properly expose but for you to have a sharp image you will need to shoot on a tripod.
Without tripod and just handheld will create blurry images. I would suggest you bump up the ISO setting to minimum to 3200 or higher that way the camera speed will be higher and reduce handheld shakes that will create blurry images. But remember, increase ISO will increase in image grain.
That is why I suggest you invest into a 17-50mm F2.8 lens for low-lighting or 50mm f1.8 lens.
I hope this helps
Jet
Feb 23, 2011 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
I own cannon G9. I fail to get good sharp open outdoor pictures at night especially in place not well lighted. Do I all the time have to take pictures Manually to get sharp pictures as we do with focus...
If you have tried using the auto setting and it is still doing the blurry pictures it sounds like a problem with your camera not the settings themselves.
This blog http://www.teleplancamerarepair.com/camera-repair-blog/post/Got-Blurry-Pictures-Blurry-Image.aspx suggests a couple of the reasons might be:
"When your image appears distorted and with altered colors, in most of the cases there are two possible reasons:
- The internal shutter gets stuck , does not open completely or
The image sensor is damaged.... "
Jul 01, 2010 | Cameras
Brand new Canon EOS Rebel XS. Suddenly, image in the view finder is blurry. Auto focus seems to be working, and pictures are coming out fine. But sometimes, the autofocus focuses on the wrong thing, and so...
Next to the viewfinder ther is a diopter adjustment so you can change the focus in the viewfinder. this is so if you need glasses the camera can be set for you. Start by focusing the camera on something, then slide to turn the diopter adjustment until it looks sharp and try not to bump it.
Jun 21, 2010 | Canon EOS Rebel XS 35mm SLR Camera
The night setting results in blurry pictures
The grain is from underxexposure and the blur is from hand shake caused by low shutter speed. Try using a tripod. Also, change from auto settings and shoot in manual mode with a high ISO and low aperture setting. Good luck!
Jul 15, 2009 | Nikon COOLPIX S200 Digital Camera
Every time i take a picture with my nikon d-40 the pictures are blurry. the camera is on auto focus but i can't seem to get the picture to come out clear. any suggestions?
Is your shutter speed fast enough? If not, you'll need a faster shutter speed or a tripod.
Are you using the proper focus sensor? Is the entire image blurry or just portions of it?
What happens if you focus manually? If it comes out sharp, then there's a problem either with the lens or the autofocus system on the camera. Have you tried it with a different lens?
Is the AF switch on the lens set to A?
Jun 04, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Photoes are not sharp
Hi, I have never had focus problems with my FX7. I suggest you set the AF mode to 1-area-focusing. This mode is quicker than the 9-area-focusing. To eliminate any possibility that the blurry photos are caused by camera shake, I also suggest placing the camera on a tripod (or setting it down on a flat surface) and using the self-timer to release the shutter. At this point you can also turn off the image stabiliser. A well lit outdoor subject is probably preferable for this test, as low contrast scenes sometimes cause the auto focus problems. If the photos under these conditions are still blurry, then you probably have a defective autofocus. Otherwise...
Sep 04, 2005 | Panasonic Lumix DMC-FX7 Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
107 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
