Question about Falcon 4420
Falcon 4420 laser not functioning
Is there a reset or something that can get the Laser to function again? We have 40 Falcon 4420's and this happens frequently. Our solution has been to send them back and they fix them. There has to be a "trick" to it (or maybe not). All other functions work but the laser just does not come on. Thanks
  • Anonymous Jan 01, 2009
    its stuck on the main screen
How to restart falcon 4420
Falcon 4410/4420(52 Key) - Press and hold the power button and insert a paper clip into the cold reset button below the Alt key
Jan 07, 2012 | Falcon 4420
Copier is showing error E100
Hi,the most common cause for E100 is the drum unit. At the rear of the drum unit should be a small peg pointing into the machine. This gets broken off. It's purpose is to operate a laser cut off shield when the drum is removed so to prevent laser exposure. If peg is missing laser will not be detected by the system and give E100. Can be repaired or will require a new drum if it has done more than 40 to 60K copies.
"BD interval error"..
just enter service mode & reset ( CLEAR ALL )
Additional Function>>>28>>>>Additional Functions
Scroll through to find CLEAR Select all...
Rate me if it was helpful....
Nov 09, 2010 | Canon Office Equipment & Supplies
System error e100
Rate me if it was helpfull....
Nov 02, 2010 | Canon PC-D340 All-In-One Laser Printer
I have massage E000 what it is meen! can I fix it my self or i neen to call survice
The error E000 is something to do with temperature.
First thing I would suggest is to make sure, that there is no paper or any foreign objects that are stuck. If that is not the case then the best option would be the reset the printer. Follow the following steps:
Step1: Switch on the power
Step2: Press Additional Functions key
Step3: Press #
Step4: Press > to #7 Printer Function
Step5: Press Set
Step6: Press > to #4 Printer Reset
Step7: Press Set
Step8: Press <
Step9: Unplug power to the printer
Step10: Switch on the power again
This should solve your problem
Mar 25, 2010 | Canon imageCLASS D860 All-In-One Laser...
I have a 4420 falcon and it works only when the usb cable is connected to te computer in other words, the internet doesn't function when i disconnect it from the stand that has the cable connected to it....
I presume the PC you connect to has an internet connection. If so this is normal behaviour. When you connect to a PC via a USB cable and ActiveSync the connection is given an IP address via the host PC. If under the ActiveSync settings you are allowing the connected device to use the host PC's internet connection then the 4420 has access to the internet. simpuls.
To get a connection to the internet you would require a different connection, i.e. wireless.
You would also need a wireless access point or wireless router. Set the SSID and encryption on the wireless device and match it on the 4420.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Jan 17, 2010 | Falcon 4420
Can we upgrade our Falcon CE4.2 device to CE5.0
Yes....contact your rep. There is probably a cost to this. There is with every other manufacturer
Oct 29, 2009 | Datalogic Falcon 4420 Handheld Barcode...
Laser Stopped Working
if you have a reset button on USB push button
if you have a transmitter reset it
you can go into mouse settings in control panel and see they are set right
you can also update driver in device manager.
have you changed operating systems
please rate me
Jan 20, 2009 | Micro Innovations PD7250LSR Wireless RF...
Scanner doesn't scan all barcodes
these scanners are user configurable, to prevent scanning of an inappropriate barcode, only the required barcode schema are enabled, if you look in your code book you will find that there is a page with listings and examples of the various different barcode schemes, in the section before that there should be a list of barcodes that allow you to program the device to use whichever barcode scheme you wish (as long as it is compatible with the scanner)
so you can enable the scanner to read 128, code 39 or EAN and also you can configure prefixes / suffixes depending on your software's requirements
Oct 10, 2008 | Falcon 4420
Function key lock up
looks like a defective keyboard better return it
Sep 09, 2007 | Microsoft Wireless Laser Desktop 4000...
Falcon 4420 Logo
349 people viewed this question
Top Falcon Computers & Internet Experts
David Payne
David Payne
Are you a Falcon Computer and Internet Expert? Answer questions, earn points and help others
