Question about Hotpoint Refrigerators
Hotpoint model #msz802df red triangle and both ice cube lights are flashing resulting in no water coming into ice cube making compartment
  • 35 Answers
SOURCE: KitchenAid Superba KSCS25FKSS00 SideXSide Refrigerator
Replace the ERC board.
Posted on Dec 09, 2007
Master_Tech
  • 770 Answers
SOURCE: hotpoint refrigerator water dispenser not working, while ice maker, works slower
Check or replace the water filter
Posted on Jan 26, 2008
  • 26 Answers
SOURCE: Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Posted on Mar 18, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
Water filter status has red light. Did not replace and now has green light and Ice maker stopped making ice.
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing.
Check the screen that filter debris, If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve.
Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If you find nothing the problem is definitely from the water inlet valve
Jun 04, 2015 | Refrigerators
Water works on door but ice maker isn't making ice occasionally hear noise like trying to dump ice cubes but no ice
the water valve located on the back of the refrigerator that the water line is connected to could be bad. if no water is coming to the ice maker then it shouldn't have any ice or water in the ice mold. if it is empty you can try pouring enough water in the mold to make ice cubes. wait an hour or so and see if the ice maker dumps the ice. if it does you probably have a bad water valve.
if your ice maker has ice in it but had been making small cubes you should check to make sure you don't have a jam. small cubes could be from low water pressure or a blockage. if your refrigerator has a water filter it may be time to replace it if the water dispenser water pressure is also low.
May 28, 2010 | Hotpoint HSM25GFRSA
Ice maker is not getting water to make cubes.
The red light should flash, the most likely suspect is that the inlet tube that carries the water to the ice maker is frozen. If you open the freezer door and hold the swinging door in front of the ice maker up you will see a black rubber tube coming down from the top. If it feels hard it may have an ice block in it.
The best way to clear the block is to turn off the refrigerator or unplug it, warm up the tube with a hair dryer or for quicker unthawing take a turkey baster and squirt hot water into the tube catching the run off with a towel.
It can take quite some time and several cups of hot water to finally clear the ice. Once done it will take about 2 hours for the ice maker to cool back down and start a cycle to test it.
Apr 18, 2010 | Whirlpool GD5SHAX Side by Side...
Ice maker does not make much ice. I just changed the water filter and reset the ice maker by turning it off. It just makes a few cubes in 24 hours.
Hi and welcome to FixYa. When an icemaker still makes ice but in a reduced capacity it is usually the result of other problems.
Either there is ice build up on the evaproator coils due a defrosting problem that you do not see or the evaporator fan motor is not running fast enough.
Here is a way to find out. Unplug the unit and use a fan blowing into the freezer compartment for at least 2 hours. This is a manual external defrosting that will rid the evaproator coils of any ice build up.
Plug the unit back in. Over the next 30 hours check to see if your ice made result is much more than before the manual defrost.
If this improves your ice made result then you probably have a defrosting problem with your unit.
You did not say if the cubes were smaller or not so I have to assume the cubes currently are normal in size and that water flow and ice maker fill timing are fine.
Kelly
Feb 28, 2010 | LG LFX25971ST Bottom Freezer French Door...
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not making ice
Sounds likw the water fill tubs is frozen shut, look where the tube comes into the freezer compartment and take a hair drier and thaw it out. Good Luck
Jan 07, 2009 | Kenmore 53642 / 53644 Side by Side...
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
