Question about Samsung S630 Digital Camera
Can I transfer Pic to SD card
I have pictures stored on my Samsung S630 Is there a way to transfer them to the SD card in the camera. I can't find my cable.
Thanks
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
The "Copy to Card" instructions are on page 73 of this manual.
Posted on Jan 30, 2013
5 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: lost my usb cable
Your camera manual will tell if transfer from internal memory to card is possible.Some do some do not. Another USB cord should not be very expensive
Posted on Aug 29, 2007
dg9dotorg
  • 151 Answers
SOURCE: cannot retrieve pictures from memory card
try and see if you can download the pictures to your computer and preview them there. If you see them, then theres no problem, if not those are just backup files of pictures you previously deleted...
Reformat the memory after backing-up the pictures and it should show the proper image count again...
Posted on Dec 09, 2007
  • 3289 Answers
SOURCE: Camera doesn't recognize the sd card, bypasses it
1) This camera accepts SD cards up to 4 GB in capacity. Most 4 GB SD cards however, are "SDHC" types (check the label to determine which type you are using). If you are using a 4 GB "SDHC" card, it may be causing the problem, as it is not an "SD" card. Furthermore, any card greater than 4 GB is not compatible with the camera. Any SD card with a capacity less than 4 GB should work without issue.
2) Check the position of the lock or "protect" tab on the side of a compatible SD card to be sure it is in the unlock position. The camera will be unable to write to a locked or protected card.
http://www.moultriefeeders.com/Game-Spy-D40
I hope this helps!
Posted on Oct 20, 2009
  • 11967 Answers
SOURCE: coolpix s220 won't transfer pics via usb cable
If you can get the pics using a card reader, why are you insisting on using the camera and USB cord? Pros always use a card reader.
Posted on Feb 07, 2010
Will a 4gb sd memory card work on a s630?
Yes and no. According to the manual the S630 will work with SD cards up to 2GB in size and with 4GB SDHC cards. If the cards at the store are actually SDHC cards (most likely since 4GB SD cards are very rare) then they should work fine.
Jul 21, 2012 | Samsung Digimax S630 Digital Camera
Please Help
hmmm you should try the followings:
First insert your SD card and try to make a copy of your pics from camera memory to your SD card. And then use this SD card to your computer.
Or Using Camera manufacturer and model no. search some driver and software for you so that you can transfer the pics to computer.
if still not fix, let me know your manufacturer and model no.
Thanks
iqbal
Mar 23, 2008 | Samsung Digimax S630 Digital Camera
Hi there, my samsung S630 seemed to have a problem when the power is on, the picture is fine, but when I take a picture and preview, the picture have lines. It still the same when I transfer the picture...
This is likely happening because your cam's memory card is corrupted. This is common with SD memory that has been used extensively for a long time and it's likely not caused by any fault in the camera.
You can try formatting the card but this isn't likely to work really. You will have to buy a new card. Make sure you buy a good brand like Lexar or SanDisk. Good luck. Hope that helped.
Apr 25, 2011 | Samsung Digimax S73 Digital Camera
I accidently erased my memery card. When I went to take pictures using the memory card the camera reads "card error". How can I reuse the memory card?
follow the instructions on this site to reformat an sd card
http://www.ehow.com/how_4793481_reformat-sd-card.html
It is common for cheap SD cards to develop problems over time you may need a new card
Apr 08, 2011 | Samsung Digimax S630 Digital Camera
Hi, I have a Samsung s630 camera and connected it to my pc with the usb cable.. I have tried downlaoding the software but still nothing happens. How do I get the pictures off? K
Buy an SD card and go to settings and transfer all the pictures from internal memory to the SD card.... then you will be able to get them off.... Hope this helps :)
If there is something wrong with the driver, then you can go to the Samsung website and they might have a driver for you camera :) Write back to inform me if this worked :)
Jan 10, 2011 | Samsung S630 Digital Camera
TRANSFER PICS FROM ETERNAL MEMORY TO SD CARD
In the Setup menu there should be either a "Backup" or "Copy" entry that will copy your pictures from internal memory to the memory card. This does a copy, not a move, so you'll have to delete the pictures afterward (after you safely transfer the pictures to your computer, of course). The operation can also take a while, so make sure your batteries have a good charge.
Feb 09, 2010 | Samsung Digimax S630 Digital Camera
I took picture w/o SD card. Don't know how to transfer to SD
Search the menus for an entry for "copy". It should give you the option to copy the internal memory to a memory card. You could also take the camera and a usb connecting cord to a store like Walmart that has a Kodak picture maker machine. You can plug the camera into the usb slot and print the picture.
Sep 11, 2009 | Samsung Digimax S730 Digital Camera
Having difficulty with my new S630 camera. Connected it to my pc. the pictures have transferred to a folder on the pc but are not on the memory card (new transcend SD card). The computer does not read the...
hey did u cut and copy the pictures ??
or is the card formatted ??
1. insert the card and format the sd card within the cam
2. then use it it would be fine !!
Apr 10, 2008 | Cameras
Loading pictures
I know this may seem like a silly question, but did you turn the camera on? If the camera is not powered up the computer will not see it.
Assuming that's not the problem, did you install all the software that came with the camera? Here's a link to the Samsung support website where you can download the software and manual if you need it:
http://www.samsungcamerausa.com/support/downcenter.asp
Lastly, if nothing else works for you, you can guy a media card reader for less than $20 and remove your SD card from the camera each time you want to transfer pictures.
Hope this helps.
Dec 09, 2007 | Samsung Digimax S630 Digital Camera
Samsung S630 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
