Question about Dell 946 All-In-One InkJet Printer
Printer won't communicate
It says the usb is not hooked up
  • headstorm14 Apr 24, 2009
    Printer will not comunicate with computer. it's only a year old and it just decided not to work anymore. I tried uninstalling it and reinstalling it and still will not work properly.
    Genius:
  • 1,124 Answers
Verify your printer is compatible with your computer.
The printer supports Windows XP, Windows XP Professional x64 Edition, and Windows 2000
Correct communication problems between the printer and the computer.
  • Remove the USB cable from your printer and your computer. Reconnect the USB cable to your printer and your computer.
  • Turn off the printer. Unplug the printer power cable from the electrical outlet. Reconnect the printer power cable to the electrical outlet, and turn on the printer.
  • Restart your computer.
Posted on Sep 24, 2008
Lexmark X1190 problem communicating with computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
Dec 20, 2011 | Lexmark X Office Equipment & Supplies
Printer won't download application list for scanning
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
Sep 28, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Won't print at all
I have the same printer. It can be hooked to a network using an RJ-45 cable - which looks like a wide modular phone jack - or a USB cable.
It can be hooked up such that both cables are installed, but it is much better to pick one type of communications method and stick with that.
If you use USB, it is better, simply because you need to choose a network (IP) address for the printer.
Follow the installation guide, and don't plug in the USB cable until that step is called for by the install guide.
Best of all, you can also plug it into an earlier USB link, like 1.0 or 1.1 and, of course, 2.0.
I have mine plugged into an older computer which uses a 1.1 USB jack, and the communication is perfect, and prints without any problems.
So, I would say that you may have missed one simple step in the install procedure which, when remedied, will allow that printer to work like a charm. You will love the quality of the output, especially when you use a good quality photo paper, either glossy or matte.
Make certain you choose a paper specifically for a color laser jet printer. Color paper for an ink jet printer, when used on a laser jet printer, may cause unnecessary smearing of the image.
-a.
Nov 23, 2009 | HP Color LaserJet 2600n Printer
Is hooked up to computer but says it not hooked op to computer will no print off computer
this could be a communication problem.
you need to make sure that the cable that you are hooking up is the one that came with the printer,also you may need to plug the cable into a different port and check if the computer detects it.
{take intensive care in case you follow these steps. }
there is an entry for USB printing support
and USB composite device in the device manager under USB devices, if you remove these entries. the computer will start detecting the plug and play device and hence will detect the printer.
Jun 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Lexmark 1200 Series
unplug your usb cable,uninstall printer then reinstall
Nov 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printer won't print says USB is not hooked up
Aug 19, 2008 | Dell 946 All-In-One InkJet Printer
Lexmark 1240...
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Aug 10, 2008 | Lexmark Optra Color 1200 Led Printer
Hooking up printer
Maybe your USB port or USB cable is not working? For sure you need to get the latest drivers for Vista, Try to download the driver from Lexmark website at http://downloads.lexmark.com/cgi-perl/downloads.cgi?category=Drivers&ccs=229:1:0:552:0:0&searchLang=en&os_group=Windows%20Vista If that still doesn't work, see if you can get another USB device to connect to your computer - like a USB Flash Drive (or "thumb drive").
Sep 03, 2007 | Lexmark Z845 InkJet Printer
Help me to print
Unplug your USB cable restart your computer let it load and then replug your USB cable and let the computer find it if you are running at least Windows XP
Apr 20, 2007 | Lexmark X7170 All-In-One InkJet Printer
Dell 946 All-In-One InkJet Printer Logo
368 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
