Shutting off Filter Cleaning Message
I vacuumed all the filters on my NEC VT676 projector (well all the projector openings,) and the clean filter message hasn't gone away. I went into the menu screen but there was no way to reset the filter message that I could find. 304 hours on the filter, but no reset button or menu item. Is there anything I can do or do we just have to have the clean filter message disply for the first couple minutes from now on?
  • 2 more comments
  • Anonymous Sep 03, 2008
    We have 4projectors, all with the same problem!
  • Anonymous Dec 01, 2008
    vt590 filter cleaning message, vacuumed but message won't go away.
  • Samstuff Jan 20, 2009
    Same issue, i keep getting the message but now way to get rid of it. Can anyone help?
  • Anonymous Mar 23, 2009
    exactly the same problem!
You need to turn OFF the message function under the expert tab on the "on screen menu"
In the state of Power ON, press each key in the order of: HELP, UP, LEFT, HELP
Press the Menu Key to display the menu and confirm that Expert is displayed below the menu.
Once you go into Expert mode, go to the Expert2 tab in the onsreen menu and set the message to OFF.
Hope that helps.
Posted on Oct 02, 2008
How to clean filter for overhead projector?
use a vacuum cleaner to **** the dust out of the filter unit on the right side rear end of the projector (right side up directions).
Then reset the filter timer.
Apr 19, 2011 | NEC VT670 Multimedia Projector
What does a solid red status light on a NEC VT676
This could be a number of things. When I encountered this problem it was simply a burned out lamp. If you have not checked that make sure you do that first. Also there is a safety feature on the projectors that will not let you turn the projector on until the lamp cover is back in place. You may also want to ensure that the filter door is securely in place. After you have done this try to power up the projector (it will take a few seconds for the lamp to warm up.) If the projector starts up, go to the menu and clear the lamp hours. These projectors have lamp life's that will expire after a certain amount of time, irregardless of the functionality of the bulb. Hope this helps you out. :)
Apr 13, 2011 | NEC VT676 Multimedia Projector
I cleaned the filter, but keep getting "Clean the Filter" Message. Is there something else I need to do?
Hello :
In some projectors after cleaning the filter you need to reset the projector .
Please check this video .
Please don't forget to rate !
Apr 12, 2010 | NEC VT670 Multimedia Projector
Our Infocus sp5000 is shutting down because it is getting too hot. We had just cleaned the filter.
you also need to clean out the machine with canned air. also check to see that all of the fans are running. if they are not all running, they need to be replaced. also, the temp sensor near the lamp housing may also need replacing.
Oct 24, 2009 | InFocus SP5000 Home Theater Projector,...
Clean Filter - NEC VT700 projector
Need to go into the menu and find the option to reset. Choose the "reset filter hours" option.---Rick
Sep 04, 2009 | NEC VT700 Projector
My projector nec mt 1075 asks me to clean filter. How do i do it?
All you need to do is use a vacuum hose to vacuum the dust that collects on the filter. The filter cover is on the side of the projector with horizontal slits. You can vacuum through the slits, or remove the cover and carefully vacuum the filter itself. Then go into the menu and reset the filter timer. Find this reset button in the "setup" menu item. Then your clean filter reminder won't show until another 100 hours of usage.
Jun 15, 2009 | NEC MT1075 Multimedia Projector
My VT440 says this when it gets to it's pre-defined service life. (a certain amount of hours)
As long as you pop the filters out regularly and clean them (I use a vacuum cleaner) you shouldn't need to replace them.
After that, go into the projector options (with the remote control) and reset the factory defaults... otherwise it has no idea that you have actually changed the darn thing and keeps complaining no matter what! =-]
Aug 20, 2008 | NEC VT460 Multimedia Projector
"clean filter" prompt
Hi there
Not at all. This promp automatically appears after a certain amount of hours.
To get this message away , all you have to do is go into the Menu and reset the Filter Timer.
Apr 14, 2008 | NEC VT676 Multimedia Projector
NEC Model VT48 - need to clean filter
This is a solution for the VT 480 by NEC for filter clean. on the left side there are two slots that have dust filters which can slide vertically to reveal micro screens that one can blow, tap vigorously, or vacuum to remove any dust build up. I hope this helps you with your unit.
Nov 11, 2007 | NEC MultiSync VT48 Multimedia Projector
1,526 people viewed this question
