Question about Dell 1600n All-In-One Laser Printer
The machine won't reconize the phone line. So the fax won't work, I keep getting line error in the display
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Ahhh..now we're closer...so you are not even getting a dial tone, when you press the fax start button? did you check the connections in the back of the machine, to ensure that there is in fact a tone available to the printer?
I've had that happen, where the line was installed, but no tone. use a simple phone device to check that there is a dial tone.
I know, it's one of those really simple things, but sometimes that's what it takes.
let me know.
Posted on Aug 20, 2008
Fax won't work with new digital/internet phone system
True. ALL fax machines are analog devices. Internet phone lines are DIGITAL.
There is no way to make it fax reliably.
Dec 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Brother FAX-2920 sending-receiving problems
Make sure you are plugged into the LINE port of the fax machine.
Oct 22, 2008 | Brother IntelliFax-2920 Plain Paper Fax,...
Faxing error
Plug a regular phone into the wall outlet and listen for a dial tone.
Make sure the phone cord is plugged into the LINE port of the fax machine.
Oct 14, 2008 | Canon Office Equipment & Supplies
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Sharp UX- B700 getting a Line Error message
Verify that you have a dial-tone by plugging a regular phone into the wall jack
Make sure the phone cord is plugged into the LINE jack..
Dial the number from a regular phone and listen for fax tones.
Sep 04, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Error code com 0001
Hi-
Go to fax settings and try turning off the ECM, if its off then switch it on, chances are its a communication error on the line. Keep me posted for further errors.
Have a nice day!!
Jun 11, 2008 | Office Equipment & Supplies
Communication error
keep the window closed ok? that's more along the lines of the phone issues, than the fax machine itself..there are many ways to outwit the phone tree issues, but each number would need to be encoded directly.
solution?
get a dedicated inexpensive fax machine, or use efax.com
Apr 18, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Comm.error displayed
Answer to your problem is move out of Verizon service area, they stink
Jan 20, 2008 | Brother IntelliFAX 4100 Laser Fax
Hi, Remote Fax Error being displayed
As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX mode.
Press Select.
Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
Change the setting from Yes to No using the + (right arrow) button.
Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX.
Press Select.
Press Options 10 times until MAX SEND SPEED appears on the LCD display.
Change it to 9600 BPS using the - (left arrow) button.
Press Select.
Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
Press Select.
Press Options 11 times until ERROR CORRECTION appears on the LCD display.
Change the setting from On to Off using the + (right arrow) button.
Press Select.
Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes. The X6100 Series only supports 1-D MH encoding with the error correction. Fax transmissions without ECM and other ECM types can result in bad quality on the received page.
Dec 19, 2007 | Lexmark X5470 All-In-One InkJet Printer
Dell 1600n All-In-One Laser Printer Logo
113 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
