Question about Samsung SyncMaster 793DF 17" CRT Monitor
Samsung CRT Blank Screen
I have the same problem about a Blank Screen Green LED is Blinking.
But my CPU is working fine because it continues to boot infact I can hear the "Windows Welcome Sound"
Please help me I'm desperate!
  • 65 Answers
1.Check O/P Voltages that time If U find abnormal voltage of vertical IC supply Pl change supply Diode&IC
2. check 5V supply,change 5v Regulator.
Posted on Oct 15, 2008
Led bilinking
green LED blinking but no display, when disconect VGA cable from CPU than monitor displays cable disconected. CPU vedio card is ok
Jan 08, 2011 | Samsung 793S 17" CRT Monitor
Black screen and a blinking green led..
Have you tried booting the machine into safe mode? turn off the pc and try inserting a rescue boot disc to see if it will go that route.
Aug 27, 2009 | Samsung SyncMaster 244T Monitor
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
Does not startup or boot, displaying a blank screen
remove the battery and try to start the machine om AC power only
regards
Nov 26, 2008 | HP Compaq Presario v3000z Notebook
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung crt 591s blank problem
This eventually happens to all CRT monitors. Either the flyback transformer or some other critical componant has failed, and the screen cannot produce a picture. It might be an easy fix, but it would be better to get a new one.
Sep 09, 2008 | Computers & Internet
Blank Screen while Green LED is Blinking.
It's because I accidentally plug the cable to the built-in graphics card port. Now I connected it to the right one and my monitor is working great!
Aug 19, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Oversize Message
dear,
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
regards,
dont forget to rate
Jun 20, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Samsung color monitor
This problem may arise from monitor as well as from cpu.
First of all check it by unplugging the VGA monitor cable.
This will display the "Check Signal Cable" depending on the model of the monitor. But a message will appear rolling on the screen, if it is not a very old monitor.
If the message is appearing OK and green light is continuously on, that means ur monitor is working fine.
The problem may be with VGA cable or with the booting of CPU and probably the RAM. Recommended solution is to reconnect the RAM and then try, if u think u can do. Otherwise call a hardware engineer.
If there is no message and still the light is turning green and yellow. That means the problem is definintely in the monitor.
Thankyou,
Your well wisher
Nov 27, 2007 | SAMTRON 55V 15" CRT Monitor
Samsung SyncMaster 793DF 17" CRT Monitor Logo
227 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
