Question about Kenmore Elite HE4 Electric Dryer
Kenmore dryer model no. 110.85087400 won't start
The front panel lights come on but when i press the start button it just gives 3 short beeps but won't start. Also the light inside the drum does not come on.
From the earlier posts, sounds like a thermal fuse. If you think that is correct, could you please tell me where/hot to locate the thermal fuse and how to change it?
Many thanks,
Ash
    New Friend:
Hello
i have a kenmore model 110.85087400 that will not heat up i just replaced the heating element and still have the same issue.what do you think it can be...when i open it to replace the element i notice some lint that was burnt...help please.miguel
Posted on Aug 07, 2010
    Scholar:
  • 121 Answers
Hi! ashgm
If you have a volt meter and are very care-full, check the voltage at the receptacle. If this is ok, open the panel where the power cord is connected to the dryer and check the voltage with the cord plugged in. Warning 240 Volts between two main power terminals and 120 Volts to Neutral or Ground, is very dangerous.
InMrFixIt
Posted on Aug 22, 2008
2 Suggested Answers
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: Kenmore elite He 4 model number 11085087400
Sorry to take so long getting back to you. 4E is a door latch error code. It means your door latch is not working. Double check the wiring to make sure you don't have any loose or broken connections. More than likely, you will have to replace the switch. This is not one of your standard error codes that you will find in any tech sheet. I have experienced this problem before. If you go to searspartsdirect.com and type in your model number, you can find a replacement listed under the "Cabinet Parts" heading as item number 41 (part number 8519323). HINT: If you order this as item number 19 (part number 8283288) it also includes the wire harness. I hope this helps you. If you require additional assistance, please let me know. Good luck to you.
Posted on Aug 20, 2008
Control locked light is on on my whirlpool duet front load dryer and it won't do anything
This advice is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks
Nov 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet does not start, when I hit POWER all lights keep flashing and when I try to hit START Or any other button I hear a beep and all lights keep flashing and the dryer does not start. I did...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
else...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Whirlpool GEW9250 Electric Dryer
My HE5t front loader not powering on
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 10, 2009 | Kenmore Washing Machines
When I press start, it beeps, but will not start -- Kenmore HE-3
I pressed the reset button inside the dryer with my finger and then turned the dryer on with the door opened. After I closed it, it worked again.
Jun 16, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore front loader Model 48102 will not start
Mar 14, 2009 | Kenmore Washing Machines
I am getting "CI" on the display even with an empty load cycle?
Jan 12, 2009 | Kenmore 20172 Top Load Washer
4E problem on kenmore dryer
Same problem, no panel lights, nothing, but drum light works. Several postings on othe sites say the cuicuitry board is faulty. Sears, in the Phillippines, or India, do notheing. Paid lots for this dryer, live alone and really don't abuse it or even use it that much. Is the there a class action suit maybe? all I want is for it to work!
Aug 20, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 beeps three times when start panel is pressed and wont turn on
FWIW ... the Sears guy came by yesterday. The problem was apparently that the door latch was not operating to the extent that the sensors thought the door was open. He is replacing the latch next week. He adjusted the old one in the mean tiome and it appears to be working fine.
This kind of stunned me, since my wife reported an electric zap and the interior light burned out as the dryer went dead -- so I was sure it would be a fried circuit board -- but, no, a little jiggling of the latch seemed to clear it up....
Jun 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3
replace the power control board
Jan 21, 2008 | Kenmore 82822 Electric Dryer
Dryer turns itself on & beeps, then off again
aye, see if you can enter the diagnosis mode. What we are looking for is the F-02 code. This will flash when there is a stuck button or user interface problem and only displayed in the test mode. With the unit plugged in and all indicator lights off, select any button except stop. Press for 3 seconds, release for 3 seconds, press for 3 seconds, release for 3 secnds and press for 3 seconds. If you did it right 88 should appear. Press the same button again and if there is a error, it should show up. If no error code shows, open the consol and check the p-5 connector. This will be the interface ribbon to the board. Reseat it and see if the problem stops. Catriver
Jul 16, 2007 | Kenmore 67082 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
534 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
